2ZR-FTXE Teaser Photos
Discussion in 'Gen 3 Prius Accessories and Modifications' started by josh2008, Apr 30, 2010.
  1. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    That is the general consensus in the Mustang/Camaro/Corvette/LS1 Truck crowd as well. :)
  2. banshee08
    banshee08 Member
    284
    72
    El Monte, CA USA
  3. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
  4. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    The 14HP was not from the turbo and would be very difficult to quantify in terms of top speed. 14HP is not enough power to do much of anything in something other than a lawnmower or garbage disposal. :)
  5. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Mustangs read close to the conventional truth. Because of the amount of control the operator has over them he can run standard SAE tests.
    Dynojets read high (but with consistent results) and can only be used while accelerating the engine.
    Both are very good dynos when used as intended
    150 rear wheel hp is impressive, I can't wait until he gets the turbo on it.:rockon:
    I thought they were under rated. I just switched from a 100 flywheel hp VW TDI that weighs close to the same as a Prius. The Prius feels quicker than the TDI
  6. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    14 hp is a 10% power increase, that's not small. Top speed increase (even ungoverned) would be small though, about 3 mph by the numbers. The 160hp corrected is also rear wheel horsepower which is 10-15% less than flywheel horsepower which is where the factory rating it. So if his numbers are correct, he is getting something like 175+ hp out of the powertrain. That does make me wonder a bit about the Mustang calibration.
  7. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I thought it was because no one else would.:D
  8. jbumps wvu mntrs
    jbumps wvu mntrs PC Superfan
    51
    Morgantown, West Virginia
    Please tell me you are still working on the build and will have new pictures and videos soon!
  9. adrianblack
    adrianblack Member
    447
    187
    Los Angeles
    This thread is wild. Also the dyno results are very interesting. I wonder if the numbers are some side effect of the Prius drivetrain on the dyno?
    150hp to 98hp on the Gen II? The Gen II doesn't feel that much slower.
  10. kithmo
    kithmo Couch Potato
    2,404
    2,775
    47
    South Yorkshire, UK
    VERY impressive for a front wheel drive.... LOL
  11. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    xs650 owns a late model Corvette so, like me, he is used to writing rwhp and not fwhp. lol
  12. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    150 rwhp in addition to the stock fwhp would be impressive.:D
  13. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Well we are talking imports here so you can just add them together to find net HP. Just like adding HP gains advertised by performance parts manufactures. 20hp from a K&N cold-air intake, 30hp from GReddy exhaust, 10hp for the throttle-body spacer and Fernco coupler, 6hp from !MAF and TB coolant bypass, etc. etc. :p
    Prius Gang likes this.
  14. carbon//m3
    carbon//m3 New Member
    socal
    intresting, nice work!!
  15. a_gray_prius
    2,927
    783
    IL
    Don't forget the NOS sticker and the GT-R badge that add 20hp each.
    Some of us are used to saying AWHP....just saying...
  16. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Then there are us weirdos that are used to thinking in terms of 4WHP. :D
  17. peterjmc
    917
    189
    Clarksburg, MD
    Saw in a FS thread that you traded in the 2010... What happened to the turbo project?
  18. Flying White Dutchman
    4,376
    313
    yes ,.,. what happend!
    you blow the ice? ;-)
    love to see what MPG will do when trying to get better numbers with the turbo in uinstead of hp
  19. Nopho4u
    Nopho4u Senior Member
    1,007
    2,061
    Socal son
    fail
