3,400 Mile Road Trip. Anything else to do before I leave?
Discussion in 'Prius v Main Forum' started by 945 PIP, Jun 16, 2020.
  1. 945 PIP
    945 PIP Junior Member
    16
    2013 Prius Plug-in
    So, in two weeks I am leaving on a road trip to MO from Carlsbad, CA. The 2013 PIP has 117,00 miles. Last week I changed the oil, transmission oil, changed coolant, and ordered a spare tire. Any suggestions as to what else I should do or think of before I leave?
  2. john1701a
    john1701a Prius Guru
    12,119
    4,817
    57
    Wiper Blades
    945 PIP likes this.
  3. rjparker
    rjparker Senior Member
    3,184
    1,552
    Texas Hill Country
    An obd2 bluetooth module, Car Scanner app with the dashboard setting for cooling, Dr Prius with a couple of screenshots of your normal battery condition and maybe Torque app if you use Android. Dr Prius might be able run a battery condition estimate test (not sure on a plugin) and is easy to use to check codes. The bluetooth module can be left on the obd2 for easy access while driving by the passenger.
    #3 rjparker, Jun 16, 2020
    945 PIP likes this.
  4. Air_Boss
    Air_Boss Senior Member
    3,258
    822
    New Yawk
    Pack a roadside emergency kit. Flashlight, basic tools, hi-viz vest, LED flasher/flares, rain jacket, potable water.
    945 PIP likes this.
  5. 945 PIP
    16
    2013 Prius Plug-in
    All good advice! Thanks!
Loading...
