3 buck alloy wheel center caps!
Discussion in 'Gen 3 Prius Accessories and Modifications' started by theloop82, Apr 14, 2010.
  1. geeter
    geeter Member
    208
    16
    Chicago
    Thanks OP for this one. I just went to Home Depot and picked up 4 for 80 cents each. Good to go! My second mod after taking off the covers!
  2. Smirv
    Smirv AkA: Ryan
    212
    Illinois
    I just took off my hubcaps and put on those center pieces. Looks way better and was a cinch. Rims definitley needed a bit of cleaning though. Your a genius.
  3. Trebuchet
    Trebuchet Senior Member
    3,772
    936
    43
  4. NY-Vmax-Joe
    NY-Vmax-Joe Junior Member
    Flowery Branch, Georgia
    Our second gen 08' Prius was a base model that came with, "No trim rings". If it was an air flow issue, they would have put them on our stripped base model prius, don't ya think?
    Now the 3rd gen prius base model does have the trim rings.
    Funny thing is that when we bought the 08', I noticed the wheels looked different from all the others and mentioned it to the salesman. He said it must be an option wheel and they are probably gonna charge you more for them wheels. I later found out all prius's had the same wheels but looked different with the trim rings, except of course the touring model.
    I'm loving our 2010 3rd Gen Blizzard white solar package!
    Gotta run to Home depot to get me some electrician caps!:p
  5. cit1991
    cit1991 New Member
    289
    95
    Tulsa, OK
  6. ckk527
    ckk527 Junior Member
    Southeast
    Way awesome! I grazed a curb after work today and the RF hubcap cracked. Initially crestfallen (1st ding on my 2-month-old Pri), I had a feeling I would find a solution here. Little did I know I would uncover such a great workaround. This weekend, I go to my local big box, and the hubcaps come off.
    Thanks, OP!
  7. Airbalancer
    Airbalancer Active Member
    892
    73
    Cobourg, On, Canada
    Cost me 4 dollars with tax at Lowes :D
    Also they have the same finish as the wheel bolts
  8. Whatis224
    Whatis224 New Member
    New Mexico
    That is a beatiful picture! Nice job :D :eek:
  9. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    It would be a good idea to shoot some clear coat on those Lowes caps. The original finish on most of them is very thin. They are still a great idea though.:thumb:
  10. Dan bo
    Dan bo Prius Fan
    116
    34
    28
    Canada, London
    Thank you Whatis224! :)
  11. koyhbae
    koyhbae Junior Member
    us
    Thanks!!!
    It really works.
    I bought a set(4) of 1-1/2"($4.10) and Aluminum color spray at OSH.
    Little bit expensive than Home Depot. (My home depot has only 3.)
  12. richard schumacher
    7,664
    1,043
    United States
    Wooden finishing plugs also fit, for that retro look. And no corrosion worries :_>
    Curiousgb likes this.
  13. n1n018
    n1n018 New Member
    L.A.
    Nice Find!! I've had my Prius since Sunday and ripped those covers off right when I saw this post. I bought 4 at Lowes for $.93 and a can of no rust textured metalic paint. Total cost $11. Im not a big fan of chrome. Here's how it looks. The paint blends in with the breaks...
    priuschat.com/forums/attachment.php?attachmentid=24865&stc=1&d=1281122462
    priuschat.com/forums/attachment.php?attachmentid=24866&stc=1&d=1281121767
    Heres the paint i used.
    priuschat.com/forums/attachment.php?attachmentid=24867&stc=1&d=1281122462
    3 people like this.
  14. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Those look good, the paint really improves the look. :thumb:
  15. n1n018
    n1n018 New Member
    L.A.
    Thanks! I wanted a textured look and have them blend in as much as possible...
  16. blueumbrella
    blueumbrella Member of Prius Regeneration
    294
    34
    Seattle
    My 09 came with wheel center caps which was a surprise to me initially. I laugh because I pulled into Home Depot to purchase the 1 1/2 in. and noticed my center caps as I got out of the car. Were there some years or models which have the center caps as standard equipment?
  17. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    AFAIK, The years/models that have the center of the wheel exposed.
    Did you have wheel covers that originally hid your center caps?
  18. blueumbrella
    294
    34
    Seattle
    No, I have the standard plastic outer wheel rim covers (if this is what you are referring to). My center caps have the Toyota logo and are not flat. I will try to take photos and post. I am assuming others have these also.
  19. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Yours are probably the caps I used when I took the fugly full cover 5 spoke caps off my Gen III Model II wheels.
    I suspect you had them stock on your Gen II because your outer rim covers didn't cover the center of the wheel.
    It was nice of Toyota to keep the same center hole on the 15 inch Gen III wheels.
    It would be interesting to know what the Gen III 15 inch wheels were originally intended for. They don't look like they were designed to be hidden behind a cheezy plastic wheel cover like they are on the Gen III 15 inch wheels.
  20. toyolover
    toyolover Member
    441
    67
    toronto, canada
    Would you be kind enough to share with us the UPC code of the paint that you used?
