Featured 3 States Drop Gas Tax as Prices Soar
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by hill, Mar 25, 2022.
  1. bwilson4web
    16,225
    It turns out to be a flawed policy. Switch to registration fees and the problem is solved.
    Zythryn likes this.
  2. 3PriusMike
    3,100
    2,419
    Silicon Valley
    They are! It is called (partial) road maintenance.
    Mike
  3. 3PriusMike
    3,100
    2,419
    Silicon Valley
    Sure, except ..."social distancing" will be something that affects a high percentage of people for the rest of their lives in the same way that people born just before the Depression had their behaviour changed for their whole lives.
    Mike
    51,986
    times up:
    now-or-never-only-severe-emissions-cuts-will-avoid-climate-extremes-un-report-2022-04-04
  5. bisco
    51,986
    that just makes them buy hummers :rolleyes:
    3PriusMike and Trollbait like this.
  6. hill
    8,812
    you don't think THIS discourages driving enough?
    this was our station b4 we got out of soCal
    #46 hill, May 23, 2022
  7. Zythryn
    Zythryn Senior Member
    6,408
    4,407
    I don’t know, are people still speeding at the same rate as before?
  8. bisco
    51,986
    5 bucks isn't doing it here. is 6 doing it there? is gasoline usage down? i read memorial day weekend could break records
  9. Leadfoot J. McCoalroller
    8,093
    7,577
    Pennsylvania
    2018 Prius c
    That's what you get when everybody says everyone else needs to do something about this.
  10. Rmay635703
    Rmay635703 Senior Member
    2,669
    1,688
    Somewhere in Wisconsin
    2013 Chevy Volt
    US Refinery output is lower than normal, we have actually increased the amounts of imported finished straight run fuel.
    There is also an excessive amount of crude stuck at the depo waiting for refining.
    We might end up with out of gas signs during the holiday
    The local Marathon had bags over the pumps last week stating the fuel trucks were held up.
    I’m still of the opinion that if Refiners don’t want to do basic repairs the government should use imminent domain and have the military run the mothballed facilities as apart of national security concerns
  11. Trollbait
    12,543
    Would the refineries then be exempt from environmental regulations?
    Some were shut down because bringing them up to current codes was deemed to costly.
    fuzzy1 likes this.
  12. fuzzy1
    10,475
    Eminent domain
    I can already imagine the resulting explosions and fires.
  13. Rmay635703
    2,669
    1,688
    2013 Chevy Volt
    So no different than a BP run plant?
    A Former maintenance manager at one of their older facilities claimed they had daily unintentional fires every day he worked there, they were just very good at rapid detection and mitigation so no real damage occurred
  14. fuzzy1
    10,475
    In my region, a close relative worked her entire career at an ARCO / BP refinery. The biggest fire I heard about there was during her first month, long long ago, long before acquisition by BP. Spectacular but no injury. Though it should be noted that an investigation into a serious BP 'incident' elsewhere, much later, rated the legacy ARCO plants as significantly safer than the plants that BP acquired from other sellers. And this one was the safest of that ex-ARCO group.
    Essentially, BP didn't much alter the existing safety culture of the refineries it acquired. It bought refineries from three different companies, each with quite different cultures, and good or poor, each group mostly stayed on its previous course.
    The big fatal incident here was at a Texaco / Shell plant (now acquired by yet another new owner), where another close relative works. It occurred during a restart after a multi-day power outage.
    I'd expect the military to do much worse. Running refineries (and numerous other operations not under Admiral Rickover's purview) to civilian safety standards is not among their core competencies. And restarting retired refineries is much more hazardous than continuing operations of any ordinary current refinery.
    #54 fuzzy1, May 24, 2022
    Trollbait likes this.
  15. Rmay635703
    2,669
    1,688
    2013 Chevy Volt
    I guess it’s a moot point given the shuttered refinery’s want a bailout and exemptions to restart
    Government refineries in either event
    Hundreds of articles like this one every year
    Forget About Climate Change, America's Refineries Make Keystone XL A Bad Idea
  16. austingreen
    austingreen Senior Member
    13,677
    4,214
    Austin, TX, USA
    The military does not have the skills to do this, and socializing refineries has actually hurt production in countries like Venezuela.
    The problem is in regulated environments like California oil refiners have higher profits if they cut back on maintenance and simply pay fines. In 2020 with large losses Marathon closed down the 4th largest refinery in California instead of maintaining it. The investment back then looked bad when california regulation appeared to make that facility uneconomic.
    A past proposal was a higher gasoline tax, with some revenue going to refiners to keep excess capacity. Of course this never happened. Poor regulation and bad incentives are there. I expect the situation will get worse, but proper regulation and incentives could solve the problem, socializing the facilities has failed in other countries. Asian refineries look to be in worse shape than US right now, making importing finished fuel more expensive. In the meantime the few major oil companies are making large profits.
  17. Rmay635703
    2,669
    1,688
    2013 Chevy Volt
    Record profits can’t keep the refinery running because they might have to do maintenance?
    Solution is bailouts to the bad actors to keep the equipment running?
    That’s similar to increasing registration taxes because the budget never includes road funding.
    The threat of Removing said profits and placing them into repairs for them outside their will seems like it could motivate them
    audiodave likes this.
  18. hill
    8,812
    great .... more big guvm't - because when we ALL pay for military to run it - the pencils and toilets and office chairs can cost thousands. No efficiency necessary
  19. Rmay635703
    2,669
    1,688
    2013 Chevy Volt
    BP isn’t efficient they just put out fires and haven’t done maintenance in 20 years, and run the company into the ground to place big profits into a couple folks pockets.
    pick your poison.
    The problem is the government has never actually made anything in the last 30 when “it” runs a project
    Proper accountability and the government actually not contracting 100% out to private industry would remove most of the graft, the trouble is you need oversight and neither private industry nor the government have any oversight.
    Most businesses are so poorly run and dependent on bailouts they have no business existing.
    Sun capital and it’s ilk are the worst examples of this, couldn’t manage their way out of a paper bag but they do know how to rip off the public using legal usurpery to loan big profits into their pockets as everybody else is run into the ground
    The sad part is government is mirroring what is common in private industry, everybody is out to burn down the system if it puts a penny in their pockets because there are no legal repercussions against the individuals responsible.
  20. Trollbait
    12,543
    Isn't that basically American Capitalism?
