3000 miles have not filled yet.
Discussion in 'Prime Fuel Economy & EV Range' started by muleman, Mar 21, 2018.
  1. muleman
    muleman Junior Member
    56
    49
    rochester ny
    Picked up the car Jan 2,2018. Have over 3000 miles and 1/8 tank of fuel left. 24 miles to work one way and I charge at work. And New York winter has been rough. But love the car (90% ev). 1521613248405.jpg
    Arctic_White, NDMinNH, Rob43 and 4 others like this.
    52,889
  3. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    Keep in mind that water is more likely to condense in the tank if it is near to empty.......especially spring and fall with temperature swings.
    And I personally wouldn't feel comfortable with gas in the tank over 90 days old.
    There is NO good reason to drive around very long with only 1/8 tank of gas.
  4. Mendel Leisk
    42,369
    I'm inclined to agree. The only reason for running the tank so low is to post pics here, lol. If you top up sooner, it doesn't change your mpg. We fill up infrequently due to low usage, every 3~4 weeks, and I figure anytime it's dropped below half full, pull in the next time you're passing your gas station of choice.
  5. muleman
    56
    49
    rochester ny
    I have 3 atv's, 3 motorcycles,1 side by side, 1 dirtbike, zero turn lawn mower ect. I dont swap the gas out after 90 days. Not in a hurry to fill the tank so it can sit in there all summer till winter time either.
    But thank you for your opinion.
    #5 muleman, Mar 27, 2018
  6. a_gray_prius
    2,927
    783
    IL
    I'm in the same boat, but my mileage is a little lower (and I have more gas in the tank). My gas is from the end of last Summer.
    muleman likes this.
  7. Rob43
    Rob43 Senior Member
    1,373
    1,050
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    Congrats OP, good work!
    Based on your incredible fuel mileage, consider a few ounces of "STA-BIL" fuel stabilizer for your next fill up. And because all of your toys & lawn equipment I'm sure you're already very familiar with STA-BIL products.
    Rob43
    #7 Rob43, Mar 27, 2018
    breakfast likes this.
  8. muleman
    56
    49
    rochester ny
    Yep already have STA-BAL
  9. amberlea
    amberlea Junior Member
    36
    Tennessee
    prime.jpg I made it 3991 miles on my very first tank of gas before I filled up today, on my birthday!
  10. muleman
    56
    49
    rochester ny
    That is awesome. You must be somewhere warm. Because it was -27f here a couple times and average low 20 low 30deg since i bought my car.
    #10 muleman, Apr 10, 2018
  11. benagi
    benagi Active Member
    525
    280
    Utah
    How many weeks or months went by before your first fillup?
    muleman likes this.
  12. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Keep in mind that a lot of PHEV engineering teams have put a lot of thought into this too. From software that monitors the time gas spends in the tank and burns it off accordingly to a pressurize and sealed fuel tank that greatly reduces gasoline oxidation/degradation, fuel condition is of little worry to this PHEV owner who's currently at 2,400 miles with 1/3rd of tank remaining. (y)
    muleman likes this.
  13. muleman
    56
    49
    rochester ny
    I just filled up. 3772 miles and it filled 10.04 gallons.
  14. bisco
    52,889
    sweet!(y) my last fillip was 4,000 miles, and she took 8 gallons.
    muleman likes this.
  15. OLO
    OLO New Member
    Scarborough,ON Canada
    Where does this supposed water condense from?
  16. OLO
    OLO New Member
    I have never had water in my gas tank. Either in my previous ice cars or my Prius C. Never had to buy gas line antifreeze either and yes I live in Ontario Canada we do get as low as -40 deg C in Winter. One more thing is when my tank is empty I have always filled it, never just put $10 bucks in till need again.
  17. CraigM
    CraigM Active Member
    208
    208
    Portland, Oregon
    Times have changed!
    Back in 1976 I had a Fiat 128SL and spent two winters just North of Chicago. I had several incidents of carburetor icing. Think it was caused by humid air, moisture in the gas, low temperature and the “Venturi Effect”. On one highway trip, the car just slowed, slowed, slowed to a stop. Sat there a couple of minutes and I think the ice melted enough and the car would restart. Traveled a short distance, and the car slowed to a stop again. Then, things improved and we were able to continue our trip.
    audiodave likes this.
  18. audiodave
    audiodave Active Member
    800
    272
    US
    Wonder if pulling air from behind the radiator would have help that.
