3060 code
Discussion in 'Generation 1 Prius Discussion' started by bigblock67, Nov 7, 2021.
  1. bigblock67
    bigblock67 433K with new cells
    171
    35
    Indiana
    2002 Prius
    2002 with 445k has constant 3060 code
    Original cat converter. Stumbles and misses out. Replaced plugs and wires. No change. When code is cleared , reappears immediately Thanks
  2. ChapmanF
    19,037
    It's always helpful to include the P, C, B, or U at the front of the code; it's part of the code.
    Assuming it's a P, I only find one P3060 for Gen 1, and it is a problem with the temperature sensor inside the traction battery. It wouldn't have much to do with engine stumbling.
    How are you reading the codes?
  3. bigblock67
    171
    35
    Indiana
    2002 Prius
    Yes it is a P. I replaced main battery 20k miles ago as a complete unit.
  4. bigblock67
    171
    35
    Indiana
    2002 Prius
    Where is this sensor located?
  5. ChapmanF
    19,037
    I think there are about five of them, poked into the sensor wells of a few of the 38 modules. One of them might just be under the module stack, sensing the "inhaling air".
  6. babbles
    babbles Junior Member
    38
    seattle
    2001 Prius
    what about P3027? cleared the code but the engine still appears?
