3190
Discussion in 'Generation 1 Prius Discussion' started by bigblock67, Jan 25, 2019.
Tags:
  1. bigblock67
    bigblock67 433K with new cells
    171
    35
    Indiana
    2002 Prius
    3190 after 10 sec starting then dies. Clear code and same result for 3 or 4 attempts.
    424k with original 02s and converter.
    What would be most probable?
  2. bigblock67
    171
    35
    Indiana
    2002 Prius
  3. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    How’s the fuel pressure?
  4. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    P3190 Poor Engine Power
    - Intake system
    - Throttle body assembly
    - Fuel pressure
    - Engine
    - Mass air flow meter sub-assembly
    - Out of fuel
    - Engine coolant temperature sensor
    - Crankshaft position sensor
    - Camshaft position sensor
    - EGR valve assembly
    - ECM
    At that high mileage, a guess might be excessive engine wear. A lot of the stuff listed would be accompanied with other codes
    bigblock67 likes this.
  5. bigblock67
    171
    35
    Indiana
    2002 Prius
    Not checked yet.
  6. bigblock67
    171
    35
    Indiana
    2002 Prius
    That is a lot for 1 code. Cleaned throttle body and changed mass air sensor. Motor runs good no smoke or blow by
  7. Paul Schenck
    Paul Schenck Active Member
    524
    307
    Fresno, California
  8. ChapmanF
    19,038
    Depends on what the code means. P3190 means that the engine's producing less than 20% of the power it's being asked for, so any of the possible reasons for an engine to do that are possible suspects, and the human has a diagnosis job to do.
