32mpg?
Discussion in 'Gen 2 Prius Fuel Economy' started by f18cmech, Jan 2, 2019.
  1. f18cmech
    f18cmech Junior Member
    52
    San Diego
    Right, but I read somewhere in the vast expanse of the internet that mpg should never drop below 10 even flooring from a stop going uphill. Mine goes to 5 under these extreme conditions. Sign of things to come?
  2. f18cmech
    52
    San Diego
    I believe I need to start. As of now I have been relying on energy monitor, which has shown a drop of around 10 over the last month
  3. audiodave
    audiodave Active Member
    800
    272
    US
    52,761
    i have never red that, but i guess it is possible. have you considered battery conditioning while you can?
  5. audiodave
    800
    272
    US
    Mine shows that too sometimes. Reality I don't think it could burn that much fuel. Lol
  6. f18cmech
    52
    San Diego
    *UPDATE* Well I am back up to 41 mpgs, but I've had to drive the Prius like I'm conducting a symphony orchestra to get it, which I'm not sure if that's right either, but basically I'm doing Pulse and glide a lot, slow launches, keeping using energy monitor to keep the mpgs above 22 at all times, using coastal and braking regen, basically the key is keep it light on the throttle always. Never gun it. So, the take away is drive it like a Corolla, get Corolla mpgs. But if you want to get the rated mpgs like above 40 you have to use energy monitor. Unless some of you can chime in differently?
  7. bisco
    52,761
    only thing i can say is that i've always gotten 50+ mpg accelerating with traffic and driving the speed limit in san diego type weather.
    even recently in my daughters 2008 w/ 130k.
  8. audiodave
    800
    272
    US
    Still just using the meter? Is it calculated on fill up?
  9. frodoz737
    frodoz737 Top Wrench
    4,790
    2,557
    33
    As everyone has mentioned, there are many variables to consider. However. I think the elephant in the room is your pointing out lower mpg in conjunction with the increased charging and discharging "rate" of a GEN II 10 year old traction battery with 225K miles on it.
    #29 frodoz737, Jan 6, 2019
  10. f18cmech
    52
    San Diego
    Well aren't you driving a peachy little Prius. Your numbers are rare, my friend. Enjoy that!
  11. f18cmech
    52
    San Diego
    Ironically, your sig says fix it before it breaks right under your post/. lol
  12. bisco
    52,761
    you think? where are you getting your data?
  13. willakwin
    willakwin New Member
    NEW YORK
    2011 Prius+ MPV
    do they do winter gas in sd?
  14. bisco
    52,761
    only in winter
