33.8 MPG and Toyota is telling me it might be the tires...
Discussion in 'Gen 3 Prius Technical Discussion' started by Edojidai, Feb 22, 2017.
  1. Edojidai
    Edojidai New Member
    Pasadena
    My car has been getting 33.8 MPG and I'm currently in the waiting room at Toyota. The service guy told me it could be the tires. I think that's BS. Thoughts?
  2. fuzzy1
    10,048
    It is probably multiple things. We need a lot more clues. You can help by reading the post below, and posting here as many answers as practical:
    Fuel economy complaints/queries? Please copy, paste & answer these questions, esp. if you're new | PriusChat
    In general, don't expect much help from the shop. They can deal with anything that sets off a Check Engine Light, but lack the time, expertise, motivation, and profit incentive to teach drivers about the myriad other factors the hurt MPG.
    #2 fuzzy1, Feb 22, 2017
  3. Edojidai
    Edojidai New Member
    Pasadena
    Thanks for the reply. I noticed the EV turns on intermittently so I think it's a problem with the temperature sensor. I just wanted to know if anybody thinks new tires of any kind can drag my car down by 27 MPG.
  4. Montgomery
    Montgomery Senior Member
    2,254
    2,234
    Orange County, CA
    Yep Fuzzy1 is correct. For some reason, your ICE (internal combustion engine) is running most of the time. Could be a battery issue with the ICE trying to keep the battery charged. But this issue could be caused by several reasons.
    Edojidai likes this.
  5. Edojidai
    Edojidai New Member
    Pasadena
    I understand. I'm questioning if it's possible that it's the tires.
  6. fuzzy1
    10,048
    Insufficient information. Do remember that this is a gasoline powered car, not an EV. Overusing it in EV is a common neophyte mistake that sabotages overall results. Until you are experienced, let the car make its own choice between EV and ICE. While not perfect, it is very very good at making the best choice.
    Both poor tire choice, and new tires in and of themselves (whether right or wrong choice) are factors that hurt MPG, but not by enough to trigger this thread. You have other factors hurting MPG too, but we lack clues needed to point you in the right directions.
  7. jerrymildred
    jerrymildred Senior Member
    11,491
    14,100
    Tampa, FL
    Yep, lots of possibilities in addition to the tires. They could be part of the problem, but it seems odd that they would do that much harm unless they were almost flat. For example, has there been a change in how far you usually drive? Short trips are a lineage killer. Could be it's working hard to try to charge a failing 12V battery. I'm sure there are others, but it's hard to get a handle on it without more info.
  8. Chodronish
    Chodronish Member
    170
    40
    Illinois
    Four Touring
    Since this thread is about tires, how do you all recommend choosing the best tires for your particular Prius? Owner's manual? Other? I remember from reading a tire thread when in 2014 I bought my now totaled 2007, and I believe slight over-inflation was recommended for better gas mileage. I'm getting ready to replace my wrecked Prius with another used one and appreciate suggestions. My 2007 Touring model was averaging 46-48 mpg.
  9. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    There's a sticky thread about low rolling resistance tires. About the only things we agree on are that the Prius should be supported with 4 tires on the pavement and that there should be some amount of pressurized gas in the tires.
  10. TMR-JWAP
    TMR-JWAP Senior Member
    6,102
    5,813
    Columbia, SC
    2005 Base Prius. 275,000 miles. Pep Boys cheapest stock size tires that were available. Son drives like a banshee and still is banging out 44 mpg.
    IMHO opinion of 35 years working on cars: if its a stock size/stock rim/no rubbing/no brakes dragging, no 30 degree toe in, then anyone saying the tires dropped your mileage down to 34 should take any paperwork they have for qualifications and flush it down the toilet.
    trickrazor, RRxing and thatoneraccoon like this.
  11. bisco
    48,996
    3-5 mpg at most. how many miles on her? what tyres did you put on?
    jerrymildred likes this.
  12. jerrymildred
    11,491
    14,100
    Tampa, FL
    Most of us probably also agree that rubber side down is usually best, too.
  13. Chodronish
    Chodronish Member
    170
    40
    Illinois
    Four Touring
    Lol :) I had 144,322 miles on my 2007 Touring. I actually don't remember what tires I had on it beyond that it was getting due for new ones.
  14. Toppcat
    Toppcat Member
    223
    69
    Northern California
    There many factors to consider before determining there a issue with the vehicle . Q: what was you previous mpg summer or winter ? What kind of tires? All bend of gasoline has various results, road and operational conditions . My mpg is down 6-8+ mpg during winter conditions
  15. wjtracy
    wjtracy Senior Member
    11,314
    3,588
    Northern VA (NoVA)
    Whole bunches of really short trips is the first MPG killer.
  16. Jerry Liebler
    Jerry Liebler Member
    177
    85
    Science Hill Kentucky
    2013 Prius Plug-in
    Is your instant MPG display like it used to be?
    Have you cleaned the Mass Air Flow sensor? Go to an auto parts store buy a can of Mass Air Flow Sensor Cleaner about $10. Find one of the online videos study it then open the hood unclip the air filter cover remove the connector on the MAF sensor, remove 2 philips head screws carefully remove the MAF. clean following directions on the can of cleaner, then clean again. Let it dry. Reinstal the MAF. Re install the 2 screws. Plug it back in. Put the air cleaner cover back on. Test drive, looking at the instant MPG bar graph if it looks better you may have solved the pblem
    Eve Barbanell likes this.
  17. Jerry Liebler
    177
    85
    2013 Prius Plug-in
  18. Jerry Liebler
    177
    85
    2013 Prius Plug-in
  19. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    NO, not possible.
    Well maybe if you put truck tires on it and ran them at 5 PSI.
    Note: it sometimes can be dragging brakes though.
    wjtracy and jerrymildred like this.
  20. bisco
    48,996
    i wonder if they sold him new tires.
