$330 plus tax for key?
Discussion in 'Gen 2 Prius Main Forum' started by JLacy76, Sep 5, 2018.
  1. JLacy76
    JLacy76 Junior Member
    50
    West Palm Beach, Florida
    Popalock quoted me that price. Where can I beat it?
    52,854
    Dealer?
  3. MichaelKnight
    MichaelKnight Junior Member
    39
    22
    Westcoast
    For me minimum always get three quotes/estimates....
    Also are you simply adding a key/remote?
    If so you can order a key remote online and program it yourself....( this if its for a 2 gen with sks)
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    For just the mechanical door key hidden in the fob? If you have one that fits already (and it's Gen 2), any hardware store can copy it for a couple bucks. ACE Hardware made one for our Gen 2 several years ago.
    padroo and JC91006 like this.
  5. JC91006
    16,936
    8,647
    You can self program a new key (if you still have one to duplicate), buy online for around $175 and program it yourself.
    And if you have AAA plus or premium membership, they'll reimburse you back a percentage of the lost key.
  6. JLacy76
    50
    I need the Silver backed key. My key won't unlock the doors or start the car without the FOB being in the ignition. I put in a new battery but it still doesn't work. I use the valet key to open the door.
  7. JC91006
    16,936
    8,647
    There is a button under the driver's side dash, by your knee area that controls the SKS functions. It turns it on and off. Maybe you have the SKS functions turned off?
    Has your key ever worked before?
    If you bought the car used and the key never worked, then you probably don't even have the right key. What a dealer / locksmith needs to do is erase your key memory and program a working key (they can program the key you currently have)
    #7 JC91006, Sep 5, 2018
    jerrymildred likes this.
  8. golfmk681
    golfmk681 Active Member
    264
    105
    los angeles, ca
    Damn and they same European cars are expensive!
  9. bisco
    52,854
    they are. but the fobs aren't.
  10. Goodsteward
    Goodsteward Junior Member
    33
    Vidalia
    My keyfob lock/unlock doesn't work, but all other sks functions do. I decided to let a local locksmith program a new one for me. It's going to cost $260 after tax. Cheapest dealer price was $260 before tax, and it's an hour away. I recently bought the car, and it only has one fob (half working lol), so I felt it was just part of the purchasing cost like tag and taxes.
  11. JC91006
    16,936
    8,647
    you probably have a stuck button, nothing else wrong with it.
    If you have AAA plus or Premier membership, they'll reimburse you for part of the replacement key (lost key)
  12. Colin_S
    Colin_S Junior Member
    Toronto
    My wife lost her Mini Cooper key fob, I bought a blank online for $100 on eBay and had it programmed locally for $50. An automotive locksmith can program any key though I think you can do it yourself manually for the gen 2s. That's not possible for my gen 3.
  13. Goodsteward
    33
    Vidalia
    I've messed with all the buttons multiple times. I even took it apart and inspected the board (key fob is taped together currently lol!) how could I "unstick" the button?
  14. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I still had the mechanical key, new fob was $297 before tax
  15. JC91006
    16,936
    8,647
    Try to press the button, the one that's stuck won't "click" when you press down on it.
    To free a button that's stuck, you would just a very sharp knife (razor blade/exacto knife) and gentle pry it loose again.
  16. Goodsteward
    33
    Vidalia
    All the buttons click that I can tell. It was washed I believe
  17. JC91006
    16,936
    8,647
    You can still use the keyless entry and keyless start?
  18. Goodsteward
    33
    Vidalia
    All the proximity works. Wireless start and unlocks when I put my hand on the handle. Just be buttons don’t.
  19. JLacy76
    50
    The button under the dash fixed my key. Thanks! I still need a spare key but my key works properly now. Gee, who knew?
    jerrymildred and Prodigyplace like this.
  20. Prodigyplace
    12,712
    11,848
    Central Virginia
    That button reduces parasitic battery use when the car is going to sit unused for months. It is not continuously looking for a fob.
