350, 000 miles and head gasket has finally let go
Discussion in 'Gen 3 Prius Main Forum' started by taxidriver50005, Mar 12, 2023.
  1. taxidriver50005
    taxidriver50005 Active Member
    204
    170
    GB
    Excel
    Cheers, head has already been sent away for skimming-pressure test-valve lapping ect. Probably not in that order.
    CR94 and Mendel Leisk like this.
  2. taxidriver50005
    204
    170
    GB
    Excel
    That has already been spotted, can't even feel it with your nail so should still be good as it hasn't been burning oil before head gasket went poop.
  3. Tbkilb01
    Tbkilb01 Active Member
    216
    187
    Louisiana
    Throw a OEM gasket on there and drive her... Toyota ...easy process...DIY under patio!
  4. taxidriver50005
    204
    170
    GB
    Excel
    Garage has fitted head today with OEM gasket... Only problem Toyota forgot to send all the o rings so going to be middle of next week before she's back.
    Tbkilb01 likes this.
  5. ASRDogman
    ASRDogman Senior Member
    7,493
    3,882
    Did you get a Toyota head gasket kit? It's supposed to have everything...
  6. Mendel Leisk
    41,143
    Part no for gasket kit in attached.
    taxidriver50005 likes this.
  7. taxidriver50005
    204
    170
    GB
    Excel
    Toyota UK reckons they don't do a kit but supply parts separately instead..
  8. taxidriver50005
    204
    170
    GB
    Excel
    Well it's back, guy turned up for work Sunday to get boxed off.
    Fired up no problem apart from a death rattle till hydraulic lifters pumped up, sounds well now... Nice little 360 mile drive in the morning to test it out .
    How much I hear you ask... Not bad considering some of scary numbers I keep seeing on here. 20230514_204128.jpeg
  9. Mendel Leisk
    41,143
    Those are pounds? Still really good price.
    Keep your fingers crossed.
  10. taxidriver50005
    204
    170
    GB
    Excel
    200 miles in and checked oil and water...looking good so far.
    CR94, ASRDogman and Mendel Leisk like this.
  11. James Finch
    James Finch Junior Member
    69
    Whitehall, Mi
    What did they charge you for the head work, if any needed to be performed? Wondering if they replaced the valve seals as well?
  12. Tombukt2
    Tombukt2 Senior Member
    12,826
    2,306
    Durham NC
    So what's the two liter engine designation for that car It's not an A series engine right Is it an upfitted Z or what have you on the under hood sticker?
  13. Tombukt2
    12,826
    2,306
    Durham NC
    That's an E 210 right?? That's the engine I want for my prius.
  14. taxidriver50005
    204
    170
    GB
    Excel
    Yup e210.... Already had direct injectors fail which seam to be quite common at 20,000 miles... Warrenty job..... Newer isn't always better.
  15. taxidriver50005
    204
    170
    GB
    Excel
    Sorry late getting back to you.... Head work was £180... Head skimmed.. Pressure tested... Valves reground and new valve stem seals.
    James Finch likes this.
  16. taxidriver50005
    204
    170
    GB
    Excel
    Quick update.... 14,000 miles since replacement gasket and cars running great... No issues whatsoever.
  17. rjparker
    rjparker Tu Humilde Sirviente
    9,992
    6,183
    Texas Hill Country
    US mechanics could learn a lot from tradesmen in the UK. How in the world do you get those kind of miles in three months? That island is not all that big! East coast to west coast and back is a daytrip even when stopping for old castles.
  18. taxidriver50005
    204
    170
    GB
    Excel
    Averaging about 12-1400 miles a week.. Private hire taxi ( similar to uber / lift ect) mostly town driving.
