$360 for 120k service on a 2010....fair?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by slkjohn23, Jun 3, 2015.
  1. slkjohn23
    slkjohn23 Junior Member
    SoCal
    $360 out the door includes oil change, cabin, engine, spark plugs, and engine tune-up....I've changed the engine and cabin myself but is there anything missing from that list and is the price competitive? Thanks.
  2. JC91006
    16,939
    8,647
    The really more difficult service here is the spark plug change, other than that, everything else is pretty simple. I think it's in line with what a dealer would charge you.
    parts cost
    oil $30
    filters - $30
    spark plugs - $40
    So the labor is about $260
    At 100k miles you should also have changed your engine coolant, transaxle fluid if those haven't been changed.
  3. JJsCarAudio101
    JJsCarAudio101 New Member
    17
    Los Angeles CA
    Thanks for the info.
    iPhone ?
  4. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    Rotate the wheels, clean out the rear brakes, check alignment, check serpentine belt and change if necessary?
  5. Beachbummm
    Beachbummm Senior Member
    1,160
    393
    I order my parts on line
    air filter $9
    cabin filter $5
    oil and filter $27
    spark plugs $36
    serpentine belt $16
    total labor less than an hour and a half
    im cheap and don't mind getting under the car, its a good place to nap away from the wife :cool:
    Andyprius1 and SageBrush like this.
  6. rjparker
    rjparker Tu Humilde Sirviente
    11,150
    6,989
    Texas Hill Country
    Coolant should have already been changed
  7. CR94
    CR94 Senior Member
    2,840
    1,246
    Northwestern S.C.
    They can not replace imaginary parts.
  8. WilDavis
    2,493
    2,155
    49
    I'm not sure I understand your post. The imaginary part they replaced had a real part # (90916-02570) and a real part-description (Belt,V-ribbed), cost $20.68 and took an hour to replace and adjust ($107).
  9. JC91006
    16,939
    8,647
    gen 3 doesn't have a belt....that's what he's referring to
  10. WilDavis
    2,493
    2,155
    49
    Ah! …so does the Gen III have braces (or suspenders, as they're called here in the USA)? :rolleyes:
  11. rjparker
    11,150
    6,989
    Texas Hill Country
    No belts. The ac, water pump and power steering each have electric motors in the 2010 and newer models.
  12. Beachbummm
    1,160
    393
  13. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    The part you listed is for Gen II Prius. 2010 is Gen III. Different engine.
  14. Patrick Wong
    18,214
    6,531
    For G3, the transaxle coolant first change is at 150K miles.
    Responding to the OP's question, the price is reasonable for Toyota dealer service. However there is nothing to the engine "tune-up" besides replacing the iridium spark plugs. Since the OP can replace the engine and cabin air filters, why not ask for a service price that excludes those items.
    Andyprius1 likes this.
  15. Mendel Leisk
    42,383
    Engine change for $360, that's very good... ;)
    Some thoughts:
    1. Spark plug change is not trivial, due to inordinate amount of disassembly needed, and the plugs are pricey.
    2. You don't HAVE to replace filters at proscribed intervals, and yeah this is really a DIY item. Especially important to DIY since the dealership is more likely to just slam in a new one, regardless.
    3. "Engine Tune-Up" is really meaningless, totally. License to print money, right up there with "shop supplies".
    It's confusing to me, not sure if the filters were or weren't included, but assuming they weren't, I think what happened, and reasonable costs:
    Oil and filter change: $60
    2. Tire rotation: $20
    3. Spark plug change: $150 (Assuming around $50 for plugs and an hour's labour)
    If both filters were replaced, then $360 not far out of line.
  16. CR94
    CR94 Senior Member
    2,840
    1,246
    Northwestern S.C.
    Where exactly did they install that real belt, considering the 2010 of the thread title has no place for it? In some other car?
  17. WilDavis
    2,493
    2,155
    49
    Exactly where the real old one was located (in my real 2009 Gen II Prius) :rolleyes:
  18. bingee3
    bingee3 Active Member
    171
    105
    Michigan
    What do they mean TUNE UP ? I get the spark plugs , filters , oil , but Tune Up ??
  19. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    If by 'hour' you mean ~ 200 - 300 seconds, then sure.
  20. SageBrush
    11,627
    2,533
    Southwest Colorado
    • Trivial Maintenance
    • Labor at about 25 cents/second
    Sure -- Absolutely fair
