37 degree alert
Discussion in 'Gen 2 Prius Main Forum' started by bstephens, Jan 3, 2012.
  1. bstephens
    bstephens Junior Member
    36
    Oklahoma
    I have not seen this discussed before, and while not actually a problem, it does puzzle me. As I am driving, should the outside temperature reach 37 degrees, the screen in the middle of the dash alerts me to that fact across the top of the screen. Not at 32 degrees or any other temperature, just 37. Can anyone tell me why 37 degrees is apparently so important? Thanks!
  2. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    I don't have any hard evidence to back this up, but I figure it is just warning you that temperatures are low enough to cause freezing on the road, such as on bridges, in shade areas, etc. Believe it or not, I get that warning sometimes in the early morning, even here in sunny California.
  3. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    My theory is that it is displaying a notice at 5 degrees above freezing to warn about the possibility of icy roads, although the air temperature usually has to be quite a bit below freezing for ice to form on the roads. It is a little puzzling.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    At 37°F your Prius may spontaneously explode. After several tragic incidents, Toyota wisely decided to warn drivers to seek warmer or colder conditions.
    A side benefit is that 37°F is close to freezing, so drivers should watch out for freezing road surfaces. It's an odd warning, but the intention is clear.
    Incidentally, if you believe my first paragraph, turn off your computer and sell your Prius.
    Tom
    5 people like this.
  5. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Maybe that's when ice can begin to freeze on roadways in which air can blow underneath like bridges etc. I do not know, but they did away with the light in 06' and above. I never thought it made much sense myself. I owned an 06' before this but had a had an earlier model there definitely would have been electrical tape over it lol.
  6. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    You'd really love the 04 and 05's where a little snowflake icon would light up and stay lite up just to rub salt in your wounds that it's getting cold out LOL
  7. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Just to be clear to the OP, the snowflake icon is what I was talking about, not the message I know he is referring to which pops down on the MFD real quick. I think even the Gen 1 had one of those dumb snowflake lights too.
  8. DallasGuy
    DallasGuy Junior Member
    25
    Palm Springs
    I never understood why 37 degrees, but all of my previous cars were set to give a warning at that temp for black ice, or ice on the road that you may not see.
  9. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Because of the climate here I've only seen the "snowflake" once in the three years I've had the Prius!
  10. Tideland Prius
    16,670
    It's at a temp warm enough that you think ice won't be on the road (but it's above freezing!) but can exist in shaded areas and on bridges and it's usually clear (black ice) so it's a warning to be aware.
  11. Dusty Chips
    Dusty Chips New Member
    85
    Laughlin NV
    ^ This
    My BMW did the same thing....
  12. cnschult
    cnschult Active Member
    772
    97
    Michigan
    bridges are exposed to more wind chill and do not receive any warmth from the earth, have you never seen a road sign that says bridges may by icy?
    its really nothing to fret about as most bridges are straight and relatively level and your prius is equipped with traction and stability control.
  13. qbee42
    18,058
    3,081
    Northern Michigan
    We wife and I frequently make a fuss about those signs, especially in the summer: "Oh God! We're gonna die! The bridge may be icy!"
    Tom
  14. Eoin
    Eoin Active Member
    593
    116
    Long Island
    Toyota phoned me some time ago and asked my advice as to setting the temperature for the snowflake to come on. I said "37 sounds about right to me" and they went with it.
  15. Stev0
    7,201
    1,074
    Northampton, MA
    2022 Prius Prime
    Simple math. Roads could be up to five degrees colder than the air. Water freezes at 32 degrees. What's 32 + 5?
  16. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Actually it's that one last tempting bit of information to get you to turn around and go back to bed. Sleep till the crack of noon, go back on the road. It should have warmed up enough by then to be safe to finish the last 4 hours of your shift!
  17. bstephens
    36
    Oklahoma
    Thanks for the answers guys. What I find odd is the warning only shows for a few seconds on the screen, and I do not hear an alarm with it (maybe because I am a little hard of hearing). So I think I frequently miss it. Oh well, I already know it's cold out!
  18. tv4fish
    tv4fish Member
    202
    46
    b: On my 2005 -- the little "snowflake" STAYS there until and unless the temp. goes above 37. Just a FWIW.
  19. PRPrius
    PRPrius Active Member
    327
    198
    I guess I am in the minority when I say I really like the icy road ligth. There is a lot of things about the 04-05 Prius that I am going to miss when I take delivery of my PiP.
  20. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    A good example of that is when the air has recently warmed up to near 37F and the roads are still cold from the previous night.
