3Gen 100,000 mile club
Discussion in 'Gen 3 Prius Main Forum' started by telmo744, Oct 29, 2010.
  1. Mendel Leisk
    41,317
    Just a thought: no need to post odo pics exactly at 100,000 miles. I know it's momentous to see all those zeros, but play it safe: a pic at 100,042 is just as validating.
    What's it in kms, roughly 160,000.
  2. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    I didn't post a pic of my car hitting 100,000 miles. I posted a screen grab of the video I took.
  3. SimplySandy
    SimplySandy Member
    73
    50
    Ocala,Fl
    I am now approaching 120,000 miles and everything's been great
  4. High Mileage
    High Mileage Active Member
    136
    237
    2018 Prius Prime
    2010 Prius, package 2. 195,000 miles
    Oil every 5-6K Mobil 1 and Toyota filter
    Tires every 60K
    Transmission fluid every 60K
    ICE and inverter coolant at 100K
    Spark plugs at 192K
    LR wheel bearing at 195K
    And lastly more headlamp bulbs than I can count. I drive a lot in the dark and they seem to last 6 months or so. I was running the Sylvania silverstars which were bright but died even quicker.
    My last car was a Geo Metro that I drove till 520K and sold. I hope the prius can beat it.
    arun2633, 04priusnow and Rebound like this.
  5. WolfpackBill
    WolfpackBill Senior Member
    349
    500
    Lexington, NC
    Mine just hit 100k miles a couple of days ago!!!
    I'll be replacing spark plugs soon along with tranny fluid replacement.
  6. trebordet
    trebordet New Member
    PA
    No history to report yet but, I bought a 2013 (Two) 2 days ago with 103,000 miles on it. (I traded in my 2004 Gen 2 that served me well for 8 years. It still runs perfectly but I wanted a newer car.) It has a complete service history at the dealer where it was sold new and where I bought it. And is was owned by a lawyer (little old lady) who apparently commuted every day on the turnpike to her office that is about 60 miles away. It appears to be in excellent condition except that the front bumper has some stone chips. I guess she likes to draft trucks.
    telmo744 and Mendel Leisk like this.
  7. m.wynn
    m.wynn Senior Member
    684
    1,229
    Queensbury, NY
    Turned 100k in October, 2014. Currently at 132k.
    1) Did you replace the HV battery pack? No
    2) Did you replace the hybrid transaxle fluid? Twice, using WS
    3) Did you replace the brake pads? Yes - all around at 97k
    4) Your lifetime MPG (if available)? Don't track closely but likely low 50's
    5) How often do you change your oil? What brand / product did you use? 5k, Toyota 0w-20 (the fabled TGMO)
    Both coolant loops at 97k using Toyota SLLC. I drain and fill the engine coolant bottle at each oil change and will replace engine water pump at 150k in an effort to go long term without head gasket failure. Driver's side transaxle seal and intake manifold de-sludge at 100k. Spark plugs and PCV valve 128k. Both the D0H and E0E have been performed. No oil or coolant consumption yet...
    #107 m.wynn, Dec 18, 2016
  8. Mendel Leisk
    41,317
    Can you elaborate on those, ie: what it stands for?
    (Believe they're recalls, but I'm lost.)
  9. m.wynn
    684
    1,229
    Queensbury, NY
    Brake booster and IPM recalls, respectively.
  10. Mendel Leisk
    41,317
    IPM is inverter something something I'd assume?
    Sorry, I'm just death on acronyms, lol.
  11. m.wynn
    684
    1,229
    Queensbury, NY
    Intelligent Power Module - inverter.
  12. Whiteyprius
    Whiteyprius Active Member
    389
    105
    North Carolina, USA
    I'm over 122K. My 2012 hasn't required any repair except for factory recalls and 10K mile suggested maintenance items. I continue to be amazed and pleased with my silver Prius. I've never reset the Trip 2 meter and am at 51.2mpg.
    telmo744 likes this.
  13. SimplySandy
    SimplySandy Member
    73
    50
    Ocala,Fl
    I just hit 120,000 miles, have been doing nothing but an oil change car still running perfect.
    1) Did you replace the HV battery pack? Nope
    2) Did you replace the hybrid transaxle fluid?nope
    3) Did you replace the brake pads?nope
    4) Your lifetime MPG (if available)? 53
    5) How often do you change your oil? What brand / product did you use? Dealership every 10k
    6) How about post a picture of 100,000 miles on ODO?
  14. Mendel Leisk
    41,317
    Change the transaxle fluid.
  15. ETC(SS)
    7,134
    Wow.....where has the time gone off to?
    I'm at 115,000 miles already.....
    My new work car is just getting broken in, and I'm no no longer driving the newest car in my work group.
    ......just the second newest. :p
    No leaks, creaks, cracks, or squeaks so far!(***)
    (***) OK....busted. :eek:
    It still creaks a lot but it did that when it was new.
    Rebound and telmo744 like this.
  16. BigBear2010
    BigBear2010 Member
    156
    65
    2010 prius II with 100,230 miles
    Still on original HV battery
    Original 12v battery
    Original brake pads
    Currently on FRS wheel, mpg around 39-44mpg
    Change transmission oil at 50k miles
    Oil change around 10,000 miles DIY
    Im the second owner at 22k miles. My prius now live the infamous cancer: oil consumption from 85k miles
    Raytheeagle likes this.
  17. Prodigyplace
    12,531
    11,750
    Central Virginia
    I notice your 2010 maintenance spreadsheet said just to inspect the transaxle fluid.
    What is your recommended replacement interval?
  18. BigBear2010
    BigBear2010 Member
    156
    65
    Do it every 50k mile (in my opinion)
  19. Prodigyplace
    12,531
    11,750
    Central Virginia
    Mendel's sheet had inspection every 30K I guess a compromise would be to change at 60K.
  20. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    What is your oil consumption rate? Did periodic monitoring catch it or did a dash light let you know? What rates of speed do you hit on the highways?
