3Gen 100,000 mile club
Discussion in 'Gen 3 Prius Main Forum' started by telmo744, Oct 29, 2010.
  1. potatoesLOL
    potatoesLOL Active Member
    145
    413
    Downtown Los Angeles
    2012 Prius Plug In Advanced (same thing tbh)
    1) Did you replace the HV battery pack? No
    2) Did you replace the hybrid transaxle fluid? Yes
    3) Did you replace the brake pads? Yes (didn’t have to though)
    4) Your lifetime MPG (if available)? 65 before I modified everything lol. Now it’s about 35-40
    5) How often do you change your oil? What brand / product did you use? 3-4 mo. 0w20 Mobil 1 AFE synthetic + synthetic oil filter
    6) How about post a picture of 100,000 miles on ODO? 102.9k mi (no pic at the moment)
    7. Others
    installed oil catch can via hybridpit. It’s crazy how much oil accumulates and is a MUST. Also got EGR cleaned etc @ hybridpit.
    mikey_t, telmo744 and Raytheeagle like this.
  2. Mendel Leisk
    41,516
    What mods? Sportier wheels??
  3. mikey_t
    mikey_t Active Member
    371
    391
    Los Angeles
    Is Hybridpit a shop? How much did it cost to get the OCC installed and EGR cleaned? And has that not been an issue with your smog checks?
  4. Greenteapri
    Greenteapri Active Member
    330
    387
    Cypress
    Crossed the 100k milestone a few days ago.:eek:
    A special thanks to PC and all of its members for helping me along the way.
    Here's to the next 100k!
    Robert Holt, mikey_t, RMB and 5 others like this.
  5. AzusaPrius
    AzusaPrius Senior Member
    2,184
    921
    Todays mileage while testing her after replacing one bad cell module and the waterpump. Also during this pandemic I replaced the clockspring and both rear wheel hubs. 20200612_133556.jpeg
    telmo744 and Mendel Leisk like this.
  6. Mendel Leisk
    41,516
    Up pretty early, lol.
    Raytheeagle likes this.
  7. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Not for us non-retired folks;).
    Early bird catches the worm(y).
  8. AzusaPrius
    2,184
    921
    Hah battery reset didnt change it at that moment during the afternoon.
  9. Mendel Leisk
    41,516
    That was my next guess lol.
  10. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    Can you share the symptoms, please? (y)
  11. AzusaPrius
    2,184
    921
    Even if you dont have any hybrid battery issues, the waterpump throwing the P261B code will show "check hybrid system" may also completely shut the car down while driving. No warning of temperature increasing at all.
  12. WolfpackBill
    WolfpackBill Senior Member
    349
    500
    Lexington, NC
    Had that happen before. I was driving 80mph on the far left lane when it happened. I lost the gas pedal but thankfully the brakes still worked. Scared the crap out of me. Read the code on the side of the highway since I had my ScanGauge plugged in and read the same code above. So for the next 40 minutes I watched the water temperature very very closely and used the car home. Engine coolant temp hovered 197 to 205 degrees. I ended up replacing the water pump. Only $170 and 30 minutes of my time to replace. Dead easy to do.
    162k now and counting!
    telmo744, Raytheeagle and AzusaPrius like this.
