3K and needing 4 new fuel injectors anybody else?
Discussion in 'Gen 2 Prius Technical Discussion' started by bvq, May 1, 2008.
  1. bvq
    bvq New Member
    Louisville, Ky
    LOVE my Prius... at 3K the check engine light came on, dealership checked and said...probably a speck of carbon, it's burnt off, shouldn't have a problem...at 4k check engine came on again... seems we are running on 3 cylinders and all four fuel injectors need replacing...thank heavens for warranty work!! anybody else have this problem..??
    got 68 miles to a gallon for two hours on vacation!! cool... musta been the 3 cylinders... thanks!!
    Kentucky
  2. Bill Merchant
    Bill Merchant absit invidia
    4,096
    82
    :welcome: Welcome to PriusChat, bvq! I haven't heard of this problem. Did you/can you get the trouble codes?
  3. patsparks
    10,664
    567
    Adelaide South Australia
    New to me, must be a dud injector. That is why there is a warranty.
  4. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    I don't think I've even seen anything go by on any of the forums
    about someone needing new injectors, i.e. the ones chosen for the
    rius seem to have been rock-solid reliable over the long haul.
    Except possibly as part of the occasional "oops, I pumped in
    diesel" stories. It seems fairly unlikely that a car at 4K would
    need *four* new ones unless something *really* wretched happened
    with your fuel supply...
    _H*
  5. richard schumacher
    7,663
    1,040
    United States
    Did the OP pour some cr@p.... I mean, use one or more of the many fine fuel additives before the injectors failed?
  6. Patrick Wong
    18,200
    6,479
    Hi Kentucky,
    What brand of gasoline do you purchase?
