3rd Actuator Replacement unable to bleed rear left
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by JC33, Sep 20, 2024.
  1. JC33
    JC33 New Member
    Fayetteville
    I have three Prius Gen 2. I replaced an actuator on the 2008 and bled through techstream last year. Bought part off ebay. No issues.
    On my 2007 I recently had a leak of brake fluid on the rear left. I changed pads/shoes out on the rear and the fluid was coming out of where the brake line attaches to the hub so I tightened that.
    Went to the bleed process and nothing. It wouldn't push fluid through the rear left. And this is using techstream utility. I ended up also replacing the actuator thinking that this was the problem. I am now on my third actuator and same issue, can't get fluid to go to the rear left during the utility bleed process. This is what is strange, I can push fluid to the rear left through the manual process in techstream where you specify the line to bleed.
    Brake light, abs lights on. 1203 and 1345 codes. Will not do the linear offset either. Typically it is supposed to flash the brake light and abs, those lights don't flash when I go through this utility.
  2. Tombukt2
    Tombukt2 Senior Member
    13,386
    2,409
    Durham NC
    So then you're saying you're talking about replacing the rubber hose that turns from metal to rubber and then back to metal at the wheel cylinder Is that correct usually when I have fluid leaking in the back like that it's usually a wheel cylinder leaking and it's running down on the break backing plate and all of that but you know where your leak is I do not so this is a new one for me the hose was leaking and you just tightened it and the flare squeezed up and there's no leak now? And by pumping the brakes you can actually pump fluid through the rear on that side so then I'm guessing if you were to suck on it with a mighty vac or something like that it would pull fluid and/or air because I've bled my generation twos a few times without text dream before I had the luxury and in the back once I get to the last step where I'm using the brake pedal and having my other half step on the brake that's where your activating the pump so you're saying you can't get the right rear or whatever side we're talking about in the rear to come out when you're doing it with the pump someone sitting in the car pushing the brake pedal and you cracking the fitting and nothing is coming out seriously? Do you hear the pump running when this is going on?
  3. Tombukt2
    13,386
    2,409
    Durham NC
    And you're in Fayetteville North Carolina or Arkansas or? You over at reliable towing?
  4. JC33
    JC33 New Member
    Fayetteville
    I'm in Godwin NC. Just a "diy" er, don't work for anyone. This is a personal vehicle.
    Yes so it was leaking down the back as you say. I fixed any leak, and I believe it had something to do with the pads wearing too thin. But regardless, I can press the brake down and no fluid will come through left rear when I crack bleeder screw, but if I do same thing on l right rear the actuator kicks on and fluid comes out.
    Do you know of any cut off on that rear brake line that is maybe causing it from allowing the fluid to come out?
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    It sounds like the safety feature has been activated, cutting off fluid to that brake section since a leak was detected. I had that happen one time and was able to reset it using techstream.
    Brian1954 likes this.
  6. JC33
    JC33 New Member
    Fayetteville
    I thought that this appeared to be a safety feature. Do we know procedure through techstream?
