3rd Flood LED in Headlight
Discussion in 'Gen 3 Prius Technical Discussion' started by Jonny Zero, Jul 1, 2012.
  1. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    From what I read online, there are three LEDs that make up the low beam for each side. Two in projectors, and one in a reflector as a flood lamp for the foreground.
    I have been looking at mine and I can't seem to find it. Has it been removed from the 2012's or am I just stupid? :p
  2. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    On a closer look, it does seem the flood lamp has been eliminated. The white car is mine and a 2012, the blue one I found online and is of an older model.
    The cluster in the space on top and between the projectors is gone.
  3. Tideland Prius
    16,683
    Yes, it's been removed. I guess they've found a way to provide near/wide illumination without the need of the flood lamp.
  4. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    I hope they improved the design / LEDs and can now achieve the same with less power. I hope this was an engineering decision and not a bean counter decision.
