3rd Gen 2012 | solar ventilation system query
Discussion in 'Gen 3 Prius Main Forum' started by Johnny Canuck, Jul 12, 2012.
  1. NaptownPrius
    NaptownPrius Getting Greener....
    271
    Napolis, Merlin
    I can unlock my car, get in and can hear the fan running and feel the air coming from the vents on solar power. Only stops when I turn the car on.
    The remote A/C stops when you open the door.
  2. katiesdad7
    katiesdad7 Member
    172
    25
    Stuart, FL
    I live in South Florida and mine works all the time. You can hear it as you walk up to the car. Then you can fell it when you get in the car. But it shuts off within a few seconds after opening the door. The air only comes out the left front vent (from what I noticed). But it does keep the car a lot cooler.
    Take it back to the dealer and let them figure it out. But as one poster said the difference between the button in and out is very hard to see.
  3. WE0H
    WE0H Senior Member
    3,247
    528
    That button needs a green LED to indicate it is on.
    Mike
    Jerry Mcl and priusincc like this.
  4. Tideland Prius
    16,680
    It runs as long as there's solar insolation and you haven't started the car (or go to IG-ON) or press the Remote A/C button.
    The air comes out of all vents like it normally does if you have the fan running.
  5. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    A few thoughts:
    • Car does NOT need to be locked.
    • The solar ventilation system won't start for ~10 minutes to avoid blowing A/C cooled air out of the car
    • The air blowing in will be slightly above ambient thanks to the heating effect of the black intake cowling at the windshield. This is more prominent in desert temperatures.
    • The system won't operate if the interior is < ~70°F
    • The system only operates when parked as the solar panel potentially acts as a transmitting EMI antenna (interference) if allowed to operate while the vehicle is on. A relay disconnects the solar panel while the car is powered on. That said, turning off the switch while driving serves no real purpose.
    • There's no real reason to cycle the switch - just leave it on. The off switch is if you know you're parking next to something stinky, like a sewage treatment plant, and don't want to blow that air through the car all day, or will be leaving the car unattended for days on end where the ventilation would only serve to needlessly run the fan and possibly clog the cabin air filter more quickly.
    • The temp of the panels itself has nothing to do with whether it will operate, but cooler panels actually convert MORE electricity than hot panels, thus ironically, they're more efficient when we need them less.
    • The panels are at a fixed angle. Parking with your trunk toward the southern sky in the Northern Hemisphere will make them slightly more effective.
    • No matter how you park, the panels lose effectiveness 1-3 hours before sunset due to the extreme sun angle. The sun can and will continue to heat up your interior after this point, especially in the desert. Thus, finding shade is always better than solar ventilation.
    • During the middle of the day, my system will operate on an overcast day, but not at full speed. Thus, some partial clouds (if thinner) won't completely disable the system in all cases.
    MarvHein, Jerry Mcl, cwerdna and 2 others like this.
  6. LibertysSon
    LibertysSon New Member
    It sounds like a defective panel . I open my doors an can hear an feel the fan blowing.
  7. Texas-Prius
    Texas-Prius One more Prius to fight terrorism
    79
    32
    Austin, TX
    One more reason would be for those who live in areas where it gets real cold in the winter time. You wouldn't want cold air blowing in and cycling out all of the nice warm radiated air.
    - TP
  8. HTMLSpinnr
    5,341
    920
    251
    The system isn't design to operate if the interior temperatures are somewhere below 70°F (unsure of exact temp, but the ECU doesn't operate if the outside temp is too low). Thus, the switch really isn't needed in this case either.
  9. Tideland Prius
    16,680
    Yup. I can leave the switch depressed all winter and it won't operate and I'll get a nice gurgle in the spring on that one sunny day when it's still cold but the sun is strong enough to warm up the interior hehe.
    HTMLSpinnr likes this.
  10. Texas-Prius
    79
    32
    Austin, TX
    Good to know that Toyota had enough foresight to put that in place. I guess the switch is for those people who don't want their vehicle cooled off when it is maybe 70-80F. With varied humidity levels, 75F in Vail, Colorado can feel much cooler than 75F in Miami, FL. Also, you have people like my wife who starts to freeze when the temperature drops below 78F. Toyota probably figured that 70F took car of most of the people.
    - TP
  11. Tideland Prius
    16,680
    It's more for if you're parked on a dusty road or if you're need a BBQ pit, you may want it off to avoid clogging up the cabin air filter (or having the interior smell of charcoal or wood smoke). Or maybe you're going away on vacation and don't need the car to run the fan while you're gone.
  12. MarvHein
    MarvHein Junior Member
    63
    Las Vegas, NV
    Presumably the car is "transmitting" this interference since you used the word radiation before antenna. What would be the probable effect on the car, the occupants, others in the area (and at what range)?
    Is this interference all the time or just when running in EV mode, just in ICE mode, etc.?
    Sure would be nice to hack the system to at least run some of the time when the car is in use.
  13. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    There is no transmission from the solar panel or the car. You are replying to nonsense.
  14. MarvHein
    63
    Las Vegas, NV
    You may be right. So why is the panel disabled when the car is running?
    I just want to use it the way it's used when the car is off, which, presumably, doesn't do a darn thing from an emissions standpoint.
    So how do I convince it the car is off when it isn't?
  15. HTMLSpinnr
    5,341
    920
    251
    Nonsense or otherwise, this was a loose quote from one of Toyota's engineers when asked why the solar panel wasn't always active.
    There is indeed an RF noise filter between the panel and vehicle ground (ref: 2010 Prius Electrical Wiring Diagram). However, there isn't necessarily a filter between the panel and (+) of whatever you choose to plug into unless you install one.
    What exactly do you intend to do w/ the output? On a good day, you may get 60W out of the panel.
    You also probably won't get very far unless you completely isolate the solar ECU, or replace it with something else.
    There's a SPDT (single-pole, double-throw) relay that's affected by both the solar bypass switch and IG-ON. In the NO position, the solar ECU output is directed to the blower motor. In the closed position (energized by IG-ON or the solar bypass switch being switched off), the blower (+) is energized to the 50A Heater fuse. The solar output is never connected to the vehicle's battery system.
    The Solar ECU also has inputs for IG-ON, which would effectively disable the unit. Once IG-ON is dropped, a 1 and 10 minute timer start in the solar ECU (which is powered by the panel). 1 minute to direct the face/foot damper to face, and the fresh/recirc damper to fresh. The 10 minute timer triggers the blower motor assembly start if sufficient power is present.
    Point is here, you'd need to bypass that ECU entirely and find another method to connect solar output to whatever it is you're seeking to power. Make sure the panel voltage is compatible (it may not be 12V).
