3rd Gen Inverter coolant pump
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mola, Apr 4, 2018.
  1. Mola
    Mola Junior Member
    West Mi
    I have searched before posting this and i can't find any details how to service inverter pump.
    I am thinking of preventative inverter pump change and ICE pump change.
  2. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,788
    Bay Area
    Are you talking about the water pump?
  3. Mola
    Mola Junior Member
    West Mi
    i already seen the engine coolant pump.
    Pump for the inverter coolant
  4. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    How many miles on your Prius?
  5. Mola
    Mola Junior Member
    West Mi
    140,+++ Miles
    Raytheeagle likes this.
  6. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Any reason for the early preventative maintenance:whistle:?
    I would consider the engine water pump before the inverter water pump;).
    In fact that is what I am doing this weekend on our 2010 with 176 k miles on it:).
  7. Mola
    Mola Junior Member
    West Mi
    That is what I am considering doing first. Just asking the "how to" cause i have seen how the Motor water pump is, and it is showing where the pump is.
    The inverter pump, I don't even know where it is.
  8. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    It’s behind the drivers headlight under the inverter;).
    Not easy access, but if you’re persistent, it’s possible:).
    Something I am considering doing down the line myself(y).
    Grit likes this.
  9. Mola
    Mola Junior Member
    West Mi
    Does it need to remove the whole inverter assembly? or just the front bumper and grill?
  10. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Loosening the inverter will permit access;).
