3rd gen steering rack removal. HELP!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jonny Morrow, Nov 7, 2021.
  1. Jonny Morrow
    Jonny Morrow Junior Member
    33
    Hey friends,
    Trying to get the steering rack out of my 2010. It’s all disconnected. Trying to slide it out through the transmission bottom mount. I have removed the 2 bolts and the 2 nuts for the bottom mount but when I jack up from the transmission slowly, the engine doesn’t release from the frame. It’s like something else is holding it. What am I missing? Could the mount be frozen to the frame? I tried banging around but it won’t release.
    I’m dead in the water until I can get this mount to jack upwards. Thanks guys!
  2. Mendel Leisk
    42,289
    Might have some info that'll help:
  3. Tombukt2
    Tombukt2 Senior Member
    13,822
    2,508
    Durham NC
    Is the big long bolt that holds the exhaust down pipe to the engine loose . I believe the exhaust may be holding it down I don't know whether you need to undo the downpipe or whether it is attached with a bracket to the frame I can't remember on the gen 3
    SM-A715F ?
  4. Jonny Morrow
    33
    Thanks for the replies guys.
    Mendel, anything in the service manual showing how exactly engine/trans are mounted to the frame?
    tombukt2, not seeing any large exhaust bolt. Any more specifics?
    Thanks!
  5. Tombukt2
    13,822
    2,508
    Durham NC
    It holds the downpipe to a bracket that's on the engine I think when that's undone the engine can cock and move a little bit while still connected to the exhaust manifold I have to crawl up under my persona and take a look I'm about to pull the engine out of it
    SM-A715F ?
  6. Jonny Morrow
    33
    Got it. 2 more bolts than I thought under hood passenger side. 3 total. Phew!
    Man steering rack replacement sucks. Thanks for the help guys!
  7. Tombukt2
    13,822
    2,508
    Durham NC
    Ah front engine attachment points .. good ya got er
    SM-A715F ?
