4 gal E85, 5.6 gal E10, 2.5 gal E10
Discussion in 'Gen 3 Prius Technical Discussion' started by bwilson4web, Jan 26, 2013.
  1. szgabor
    szgabor Active Member
    994
    175
    Oceanside NY
    Like Coca Cola ???? and other high fructoze corn syrup ????
    then it is better to burn it in our prii more renewable is the better ... those arabs will run out soon enough (even chavez will run dry some time in the future )
    I wish there were some more conclusive evidence that higher then E10 can be safely used !!!
    pichner and WE0H like this.
  2. WE0H
    WE0H Senior Member
    3,247
    528
    Give the testers time to gather data ;)
    Mike
  3. Former Member 68813
    3,524
    983
    US
    You guys didn't read the PDF I posted a link to. Problems were with valve seats and seals.
    dbcassidy likes this.
  4. WE0H
    WE0H Senior Member
    3,247
    528
    How does any Ethanol wear away a modern valve seat? The seals should be silicone which I don't believe alcohol affects.
    Mike
  5. dbcassidy
    dbcassidy Toyota Hybrid Nation, 8 Million Strong
    1,581
    290
    Middlesex County, MA
    ADM is in bed w/ the beltway bandits. E10 is a failure using valuable acreage to grow cropsfor thatjunk. The past servere drought should have people wake up and banish E10.
    DBCassidy
  6. bwilson4web
    16,552
    I fully appreciate there are materials tests that long term use requires a different testing protocol.
    My current interest is to find an E ratio that does not throw a P0171 code. Right now, I have a full tank of minimum E74 based upon my region and winter. Now that I'm at the maximum local ethanol ratio, I'm finding 4 of 5 trips throws a P0171 code. But I didn't see the first one until the temperature reached +50F.
    Actually you provided two references and only one was a PDF:
    • Paul Bedard's "Study: New E15 gas can ruin auto engines" - built around an American Petroleum Institute study, his lay interpretation left a lot of technical details out. Worse, his article about E15 does not answer my questions about E85 in a Prius. In fact, I started with E30 and E35, much greater ratios that appeared to work just fine in the 2010 and 2003 Prius.
    • "Final Report CRC Project: CM-136-09-1B Intermediate-Level Ethanol Blends Engine Durability Study" - the table of contents only goes to E20 and I'm already in the E85 range. Once again, not very helpful for my current study.
    Still, you might want to read this Bob Glicksman study:
    http://www.liquidsunenergy.com/learning/ppt/ice.pdf
    So far, everything in the "Ethanol and Internal Combusion Engines" by Bob Glicksman has been confirmed with my current studies. Feel free to read Bob's study. Meanwhile, my ethanol experiments continue.
    WE0H likes this.
  7. bwilson4web
    16,552
    Hi Mike,
    High power settings in the 2003 are supposed to go into an open-loop, enriched mixture. However, my hill climb test data shows there remains some closed loop operation. Still, at high power, the engine is supposed to use an enriched mixture and the oxygenated ethanol will make it somewhat lean . . . yet alcohol has a cooler combustion temperature.
    In theory, a hot, lean exhaust gas might lead to more exhaust valve erosion . . . literally eating the metal seat and exhaust valve. It remains on area I'm still thinking about how to get useful metrics. Regardless, this is something that will take more than the current test is likely to reveal.
    In contrast, the 2010 uses cooled, exhaust gas, recirculation to reduce exhaust gas temperatures. I have not modeled it but I suspect this will mitigate the higher oxygen content of E85 better than trying to use fuel-enrichment of the 1.5L 2003 Prius. However, this is a hypothesis and not a formal model nor hard test results.
    WE0H likes this.
  8. WE0H
    WE0H Senior Member
    3,247
    528
    Awesome article Bob :) I'm still reading thru it.
    Mike [​IMG]
  9. bwilson4web
    16,552
    No problem, I read it tonight:
    • GOOD NEWS
      • "2004 Scion xA, 1.5L I4, Tier 2 Bin 9, Direct Acting, Mechanical" pp. 23 - this is the same engine block as our 2003 NHW11 Prius and similar to the NHW20 1.5L engine. It has no relationship to the 1.5L 'Prius c' engine.
    • BAD NEWS
      • "The detailed results are masked in order to ensure OEM confidentiality, including their technical data. The provided vehicle list is not in order within the table below to maintain this confidentiality." pp. 37 - preserved exactly the formatting in the original PDF. Did you read this? What this means is nothing in the report can be traced exactly to our 2003 Prius, 1.5L engine with the possible exception of the common test configuration description provided in the earlier pages.
      • "The exhaust back pressure level can be considered equal to the vehicle as the muffler is not contributing substantially to the overall exhaust back pressure level." pp. 32 - yet we know from the New Car Features of the 2010 Prius, the 1.8L Prius, that the muffler has a spring operated, back-pressure relief valve. This report has removed itself from the performance of the 2010 Prius.
      • "Figure D.2.1: Durability Cycle" pp. 26 - the problem is their test cycle limits rpm to 3,500 rpm which does not follow the operating line of the 1.5L Prius engine in either the NHW11 (maximum 4,500 rpm) nor the NHW20 (maximum 5,200 rpm.) So their "Simulated 1-2-3 WOT accels" fails to follow the operating line of our Prius engine. Although not mentioned, the NHW11/NHW20 Prius use an Atkinson cycle engine with an extended intake valve period. This is a critical omission in their test suite.
      • "The additive treat rate was specified at a level three times higher than legally required to for deposit control to reduce the possibility of deposits affecting the test results and to compensate for the dilutive effect of the ethanol." pp. 20 - HUH? Here is a documented change in the test fuel mix without an independent analysis of the effects of these additives. A+ for honesty, F for failure to do the obvious, testing the additive effects!
    First I want to thank you for identification of this report. Sad to say, the report by its own words shows it has no relationship to my current experiments. The one possible link would be our 2003 Prius BUT they deliberately obscured their findings so the data from the nearest engine, the Scion xA 1.5L engine could not be found.
    You are reminded that I posted the URL for another ethanol study. Please, feel free to add your comments to this thread citing specifics in Bob Glicksman's study.
    WE0H likes this.
  10. WE0H
    WE0H Senior Member
    3,247
    528
    It appears it would be a waste of time to do any E85 soak tests. Nothing will happen ;)
    Bob, have you tried a converter yet on a 3rd Gen? It will certainly eliminate that LTFT lean burn code. Prius runs flawless on E85 with a converter :)
    Mike
  11. bwilson4web
    16,552
    Just to test the fuel pump. It has the greatest amount of contact with the ethanol.
    I have a converter but not yet installed. Looking at the kit and installation instructions, I'm thinking this only makes sense for those who really want to run on ethanol. Even before the pending MPG vs mph measurements, the preliminary numbers I'm seeing show ethanol is priced too high to be an economical alternative to E10. One might as well burn premium for an equivalent cost per mile.
    A couple of weeks ago, I was paying $2.95/gal for E85 while E10 was $3.15. Now E85 is $3.35/gal while E10 is $3.55/gal. The ethanol retail price is apparently 'locked' relative to gasoline and not relative to the energy or MPG equivalent nor the cost of production. In effect, the distributors have priced ethanol to support gasoline sales.
    From a practical standpoint, the converter doesn't make a whole lot of sense at these ethanol prices and I don't see it as technically that interesting. However, it can answer the question of whether MAF or injector timing is used or most effective to calculate fuel burn.
    My current question remains to find out how high we can go with the stock car. I understand there are reports of E50 and I have both cars at the maximum local ratio, at least E74 up to E85. So far, I've confirmed:
    • cold-start problem - after a cold-soak to just below freezing.
    • P0171, harmless - it sets the "Check Engine" light which inhibits seeing other codes
    My thinking is find what ethanol level works with the stock, Prius. This becomes the maximum level for those who like me are curious. Then use this ratio for my standard mph vs MPG test. Only then does it make sense to install the converter and repeat the mph vs MPG test on that ratio.
    I have used two methods to measure MPG: (1) MAF and the stometric ratio, and (2) rpm with injector timing. I need to quantify both before installing the converter. Then I can quantify the converter effects and go to the maximum ethanol ratio without codes.
  12. WE0H
    WE0H Senior Member
    3,247
    528
    Up here E85 runs from 40 to 70 cents a gallon cheaper than 87 E10. I have a few converters that I bought when E85 was even lower cost verses E10. The only one I have tested is a Change2E85 converter. I do own a few White Lightning converters but I haven't don't anything with them yet. All of them I snagged off eBay real cheep. My wife & I own a couple boosted cars which we use blends to bump up the octane level to prevent holed pistons :) My boosted car needs 92 minimum to survive and that is not available everywhere up here.
    It will be interesting to see what mpg's you get in summer air temps in your 3rd Gen running your blends. Our regular non-boosted gasser cars run well on ~E50 blends. No codes, decent mpg's. My SUV runs anything it seems. It will throw the lean burn code on straight E85 and run exactly like that article you posted describes a non-FFV running on straight E85. I have a converter for it but have to pop off the upper plenum to get to the injectors. It has a 10:1 cr so I don't run it on 87 E10. If the mid grade is jacked up in price I dump in a E85 blend to bump the 87 gas up a few clicks. When gas prices got jacked up a while back I just ran it on E85.
    Mike
  13. Former Member 68813
    3,524
    983
    US
    Here is my opinion since you asked. I found it a good read and I learned something new about history of alcohol as fuel. I found the story about early Model T being a "flex fuel" car (up to the prohibition) fascinating. But, that's about it.
    First, it's not empiric study per se, more like "literature" review or rather Mr Glicksman's take on the issue.
    Second, Mr Glicksman doesn't strike me as an engineering type. I searched more and he and his buddy John Kolak are activists on the Abe Shackleton's blog at OpenFuelStandard.org. You can see some of Kolak's writings here: http://liquidsunenergy.com/learning/ppt/Ethanol_Recommendations.pdf
    Third, there are factual inaccuracies in the Glicksman's paper. Lets look into them.
    It's my understanding that car makers refused to warrant issues arising from E15. Also E15 certification has been recently challenged.
    The author doesn't mention that hydrous alcohol increases wear in cold engines (via formic acid corrosion): E85_in_standard_engines
    The author has not proof for that. It is only his opinion.
    Very incorrect. Engines specifically designed for FFVs employ soft nitride coatings on their internal metal parts to provide resistance to formic acid wear in the event of water contamination of E85 fuel. From: E85_in_standard_engines
    Also, 3 or 4% of the parts in FFVs are different from non-FFVs. From: NTEP
    Incorrect, federal emission warranty is clearly limited. Source: Federal Emission Warranty: How It Works | Car Care People - The Warranty Specialists.
    The author neglects to say that the theoretical 40% efficiency figure is for turbocharged, direct injected engines with very high compression (diesel like) designed to run on 100% ethanol. From: ScienceDirect.com - Energy Conversion and Management - Towards 40% efficiency with BMEP exceeding 30bar in directly injected, turbocharged, spark ignition ethanol engines
    While engine starting/drive-ability attributed to alcohol fuel is minimal/negligible in hot climate like Brazil, USA spans from very hot to very cold.
    Like I said, it's not bad reading, but I would not take this "study" as gospel.
    Robert Holt and bwilson4web like this.
  14. kbeck
    kbeck Active Member
    420
    275
    Metuchen, NJ
    Bob,
    Had an interesting experience, non-Prius related, that may be germane.
    So, a year and a half ago, after the last high-school aged kid left town for college, my wife took a look at me and said, "You're not gonna have a heart attack shoveling on my watch. We're going out and getting a snow blower."
    So, went out, got one, had exactly one 4" snow fall that year for which it was used and no snow the following year. This year, 8" snowfall! Yeah, I get to go out and use it!
    Except it really won't start, even when jacked into 120 VAC to run the starter.
    Took it to the local shop, the guy gives me the evil eye and says, "Did you run it until it was dry after the last season you used it?". I hung my head in shame.
    So, I'm a little poorer, the carb's clean, and it runs now. Of course, no snow in sight. :)
    But the man says: Ever since alcohol-laden gas has been on the market, he and his friends at the motorcycle shop across the street have been having fun pulling gunk out of carburetors, injectors, and other fun stuff in order to get these (relatively) little-bitty engines going. So long as the engine's hot and the fuel is going through it, no problems. But let a motorcycle sit for a month with a half tank of E10 gas in there and it's $$ to get it degunked and cleaned out. He claims it's the alcohol doing it, and swears that non-ethanol gas never had the problem. He even said that running the engine dry might not be good enough because the dribs and drabs left in the carb afterward could gunk up. (At this point, however, he was pushing this $2 tube of stabilizing liquid, so YMMV.)
    So: Another vector for you. Fill up your Prius with the strongest Ethanol-laden gas you can find, then let it sit for a month. If this guy's right, you may be having a bad time afterwards.
    KBeck
  15. WE0H
    WE0H Senior Member
    3,247
    528
    I have never had an issue with my Toro snowblower in the 6 years I have owned it running E10 92 octane premixed gas thru it. Always starts on the first or second pull. My leaf blower runs the same gas & oil as does my line trimmer. They are over 6 years old and never had an issue even letting them sit in the garage with gas from the previous season.
    Mike
  16. bwilson4web
    16,552
    Already done that experiment using a 1 gal container of E85 that was unused for four months. It worked just fine, no problems. But the 12V battery discharge is more likely to cause a Prius problem after a month of nonuse.
    WE0H likes this.
  17. bwilson4web
    16,552
    One of the common threads is the engine should be tuned for the fuel and ethanol has some unique characteristics including high octane. Our 13-to-1 expansion ratio Atkinson engine is pretty close to the type of 'high compression' engine needed to exploit ethanol which is one area my current experiments are investigating. Sure, the engine could be better tuned for ethanol but I'm currently interested in how to operate a stock Prius on a high ethanol ratio.
    For my current tests, I not worried about the long-term, materials issues of E85. With the exception of some plastics, I am willing to take a short term, 2-3 month, risk. If the plastics are at risk, they are already 'toast' and the failure should happen any day now . . . to my cars.
    As for using E85 in the future, it looks like it would need to be ~75% of the price of straight gas to make economic sense. So $4/gal straight gas would need to have $3/gal E85 to make economic sense. Yet even $3/gal is at least $1/gal higher than the reported, $2/gal. manufacturing cost. Running E85 is a luxury I can't afford after my testing is done.
    The thing this paper provided was assurance that burning ethanol is not like trying to burn 'diesel' . . . nearly instant Prius death. The P0171 error is just the engine ECU seeing the long term trim has gone beyond the pre-defined limit. I'm not seeing them under high power operation so I'm going to take a different approach.
    The Prius takes a 'snapshot' when a code is thrown with a collection of data points. I'll start collecting them before clearing the codes. This is safe because it only throws one P0171 per drive. In a week or so I'll have enough points to see what is going on.
    WE0H likes this.
  18. Former Member 68813
    3,524
    983
    US
    No, it's not relevant here. You had a problem with carburetor that is open to the elements via vent tube and will go bad if gas is left inside for a long time. I also had carb problems recently in my rarely used boat despite using StaBil as directed. Unfortunately, you can't drain carbs or even run them dry completely in many designs.
    Sealed fuel system in modern cars are very dissimilar.
  19. Former Member 68813
    3,524
    983
    US
    Bob, don't get me wrong, you are doing a great job here, but one shouldn't forget that there are issues with running increases amounts of alcohols in cars not designed for it. The recent CRC study is a prime example. If one wants to see more, one can search for the 2004 Australian government sponsored Orbital Engine Company study on E20. We don't want to mislead casual visitors to this thread.
  20. WE0H
    WE0H Senior Member
    3,247
    528
    I say only run E10 87 octane gas in your Prius or the fuel system might magically melt away and your car will leave you sitting along a busy roadway late at night. That should be good enough for the general population :) All this talk about testing this or that fuel is just speculation and in theory, never actually done on a Prius [​IMG]
    Mike [​IMG]
