40%-Efficient Engine, Really?
Discussion in 'Prime Technical Discussion' started by mr88cet, Apr 24, 2017.
  1. GT4Prius
    GT4Prius Active Member
    530
    412
    Cumbria, UK
    Excel
    Combined Heat and Power where much of the heat is recovered rather than wasted to atmosphere is a widely used and established technology. Can also be used on smaller scales for a smallish group of domestic properties, large hotels, for industrial purposes and for things like Public swimming pools.
    There has been plenty of debate about this as a way of improving electricity generation efficiency nationally, but most countries are too invested in terms of infrastructure and politics to large scale generation and national distribution grids which then make CHP impractical to fit that model and predisposition.
  2. Dale Leonard
    Dale Leonard Member
    66
    47
    Hartland, Wi
    An atomic power plant is 1% efficient.
    Talk about wasted heat.
  3. fuzzy1
    10,690
    By what measure?
    Certainly not by the usual definition of thermal efficiency, the conversion of thermal power to electrical power, where nukes are typically around 30% efficient.
  4. a_gray_prius
    2,927
    783
    IL
    I would also like to be able to change engines twice per season :)
    I'm very amused someone with the username Ferrarilover liked your post.
  5. AJDL
    AJDL Junior Member
    29
    Suffield
    How do you calculate the gasoline mileage? I am not able to find any option on the car to see, how much it is consuming or MPG. It shows MPG but that includes the EV.
  6. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    So what? When you are in Hv, especially if you are in Hv for a long duration or when you start and end with the same remaining Ev range, all the energy is coming from the gas engine, regardless of the Ev percentage.
  7. Trollbait
    12,816
    I think he means the MPG figure includes energy from the grid, which would make it inaccurate.
  8. Lee Jay
    5,850
    4,036
    But it doesn't.
  9. Mendel Leisk
    42,301
    @Tideland Prius and all, that intake manifold cross section through the EGR looks to illustrate that the passage goes from one, to two, to four, somewhat akin to a family tree. I can see the advantage there: more even distribution. Third gen has a single long passage, with a side branch at each cylinder port.
    OTOH, it looks to be near impossible to completely clean mechanically, to run pipe cleaners through. You could still do spraying, anyway. I believe the 4th gen EGR intake is moved further downstream, beyond the catalytic converter, reducing the need for intake manifold cleaning. Hopefully.
  10. Tideland Prius
    16,675
    Would a cleaner burning engine result in less potential soot in the exhaust gas that is recirculated?
  11. Mendel Leisk
    42,301
    Maybe. But I've got an undeducated hunch a lot of that soot is due to the PCV dumping oil from the crankcase. I found my intake manifold to be an oily mess, the MAP sensor more-or-less drowned in oil.
    Mark57 and Tideland Prius like this.
  12. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    At least based on the TDI world's experience with this, it's not the PCV, it's the EGR. (Granted, TDIs have a turbocharger that seeps a bit of oil into the intake, so removing the PCV doesn't remove all of the oil, but still, it removes a lot of it.)
    Reducing particulate matter in the exhaust pre-EGR - whether that's through more complete combustion, or through removing the PM from the exhaust pre-EGR, will help.
  13. bwilson4web
    16,519
    Same fuel, I suspect no. Change the fuel to higher hydrogen to carbon ratio, methane, methanol, or hydrogen, and soot can all but disappear. Although not designed as particle filters, their heat, 600C, and alternating reduction cycles should reduce soot too.
    The catalytic converters have been and remain a game changer.
  14. Tideland Prius
    16,675
    Question about Shell's "Nitrogen-enriched" fuel. Would that not result in more NOx emissions? Or do the benefits that it supposedly brings, offset that?
  15. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    My bet: "Nitrogen enriched" is marketing, not chemistry.
  16. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    Adding more nitrogen in the fuel won't have an effect on NOx emissions, I suspect - there's already an excess of nitrogen in the intake air, and the high temperature reaction between that nitrogen and any excess oxygen in the cylinder is what forms NOx.
    That's why gasoline engines tend to have better NOx emissions performance - the throttle plate means that excess air isn't entering the cylinder in the first place, whereas diesels run wide open. And, that's why lean burn gasoline engines aren't common - lean burn means NOx.
    telmo744 and Tideland Prius like this.
  17. Lee Jay
    5,850
    4,036
    Gasoline engines have lower NOx because of less compression leading to lower peak combustion temperatures than diesels.
  18. Tideland Prius
    16,675
    Would be curious to see how Mazda tackles the HCCI engine they have coming down the line.
    RonMc5 likes this.
  19. RonMc5
    RonMc5 Member
    89
    73
    Santee
    Like the 400 HP of the 60s was brake HP on a bench dyno. Now called (I think) SAE gross HP, newer is SAE Net HP, with like pumping it's own coolant and other accessories attached and in street trim. DIN HP was always like SAE net, and a more realistic figure. :)
  20. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    I think I recall that they compress almost to the compression-ignition point, and then ignite “normally” an extremely tiny amount of gas whose sole purpose is to tip the pressure over the threshold.
    Ah:
    benagi and Tideland Prius like this.
