450 Mile Club
Discussion in 'Gen 2 Prius Fuel Economy' started by gringostar, Nov 28, 2011.
  1. gringostar
    gringostar Junior Member
    46
    Santa Ana, CA
    I am happy to report that I drove 450 miles on one tank with the fuel light blinking for 75 miles. I refuse to fill up with 3.5 gallons left in the tank. I'm getting consistently 45 mpg and see no need to fill up when the light starts blinking (at 375 miles). I filled up with 10.1 gallons meaning I had a conservative reserve of 1.8 gallons.
    Having a reserve of 3.5 gallons (29%) seems a little bit absurd. I completely understand how the bladder works and still find it absurd to have such a large reserve.
    Anyone else like to fill up 10+ gallons? Any else here not afraid to push the blinking light?
  2. Gurple42
    Gurple42 New Member
    354
    Santa Monica, Ca.
    I'm not that brave, I'd rather avoid the hassle and fill up at 2 or 3 pips. No sense running to the bottom of the tank and risk damage to the fuel pump.:cool:
  3. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I foresee a wave of folk stranded by the road.
    Look for gas at 2 pips
    Get gas at one pip
    Get gas NOW if it starts to blink.
    Walk to gas if it quits blinking.
    Do NOT run down your HV battery trying to drive without gas
    Refill with at least 3 gallons before you try to restart.
  4. gringostar
    46
    Santa Ana, CA
    I drove 75 miles with the thing blinking.
  5. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Good luck...
  6. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Gringostar, may your guesses always be right.
  7. ngc4565
    ngc4565 Member
    193
    33
    Pennsylvania
    2023 Prius
    OK - I am confused. Why is 450 miles a big deal? 500 miles should be just a walk in the park.
  8. Rokeby
    Rokeby Member
    3,033
    710
    75
    Ballamer, Merlin
    So, I'm trying to "completely understand" why any one would find such
    a "double-dog dare" attractive. :noidea:
    Someone who typically drives in moderate outside air temps which
    don't result in significant tank bladder size reductions assumes that
    nobody else lives/drives in 0 degF weather which can have significant
    fuel volume reductions. :confused:
    Someone who apparently has a significant inclination meter
    misalignment assumes every Prius has the same issue and starts
    "blinking" the low fuel warning well before it should. :confused:
    In addition to these Prius specific anomolies, I see two general fallicies:
    Hindsight Bias: Using data currently available, tending to greatly
    exaggerate the degree to which events that have already happened
    were predictable based on the evidence available at the time. In
    general, events that have actually happened are routinely judged to
    have been likely, and events that failed to occur to have been highly
    unlikely, regardless of their actual probability.
    Overconfidence: A tendency to overestimate the reliability and
    accuracy of our own beliefs.
    Although it would be imprudent to play Russian roulette with the known
    to be unreliable combination of the Gen II guess guage and fuel
    bladder, prudence would be best served by a quick call for some
    roadside assistance insurance before playing this loser's game.
    +1
    babybird and Silver bullit like this.
  9. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    You have a Gen 3 with a fixed sized gas tank and better mileage.
    The OP has a variable sized gas tank, mostly dependent on temperature, and less mileage in most scenarios.
    Foolishly ignoring the pips and getting gas by mileage alone is less insane in a Gen 3.
    I have extremely mild winters, but hot summers, my gas tank is 2 gallons smaller in winter. The chemistry of gas changes with the weather, you want more volatile gas in winter to aid starting, so refiners add butane, but the Gen 2 Prius does not burn it as well as summer gas, with less volatiles.
    There are just so many reasons that "it worked before' is not the right way to handle range in a Gen 2. (or any car, but especially North American Gen 2s)
  10. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    Agree w/all of the above.
    I've never put in more than 9.975 gallons in my tank.
    It's bad idea to assume that you have 3.5 (or 1.8) gallons left in the tank or that you have 3.5 (or 1.8) usable gallons in the tank.
    Given that temps are colder now, you'll likely have reduced capacity as well (it's noted in the manual). You might also find http://priuschat.com/forums/other-cars/94001-gas-gauge-says-full-but-thats-not-quite-true-npr.html insightful, even though it's a Ford engineer talking.
    Unless your inclinometer is out of calibration, have fun verifying that you can always go 75+ miles w/low fuel light blinking.
  11. gringostar
    46
    Santa Ana, CA
    I see you have a 2010+ model. Just noticed. You don't count.
  12. fuzzy1
    10,706
    You are replying to someone who once ran dry a mere 7 miles after the thing started blinking.
    I seem to remember plenty of other Gen2 drivers having reported running dry at less than the distance you drove. With the magic of that bladder, you drew one of the long straws in a game where too many others have drawn short straws.
    While I also play this game, it is for shorter distances on the warning, and with the aids of extra instrumentation and no bladder.
  13. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    It is very simple. Your tank is not a tank. When you can only pump in 9 gallons, it may not be because there are 2 gallons left in the tank. It may be because the tank has folded or creased. Or it may actually have more capacity. You will never know.
    You cannot judge how much fuel you have left based on miles driven or average miles per gallon over the current fillup. When the Prius says you need gas, you need gas. Playing chicken will make you run out eventually.
  14. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    The GenII has a blader for a fuel tank and often holds less fuel than the Geniii. On average the Geniii also gets better mpg. The GenII was only EPA rated at 46mpg.
    As for pushing the limit, why? Bragging rights? Some have driven 100 miles with the light blinking and others less than 10 before they ran out of gas. If you like the risk then go for it but you shouldn't encourage others to do the same. It's not safe.
    FWIW I've only acheived a 544 mile tank at 57mpg. approx. 33 miles on the blinking light.
  15. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Without the fuel bladder (Australian model) my Gen II routinely gets over 600 miles per tank. I've even had a tank as high as 680 miles (1095km). But without the bladder I can pretty much rely on using close to the full 12 gallons (45L) every time. I usually refill between 40 and 44 liters.
  16. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Your non-North American domestic market vehicle with the actual tank also has a larger capacity of 45L. The USDM and CDM models with the bladder have an 11gallon capacity, fully expanded.
  17. stevemcelroy
    stevemcelroy Active Member
    873
    194
    Boulder, CO
    I don't know, I just do not get it. What is the big deal to some with driving until you are on vapors? The person who fills up with 8 gallons versus 10 will need to fill up one extra time every 4 to 8 weeks give or take. Figure a fill-up takes maybe 5 minutes and we are talking about a max of an hour or so a year. Honestly that does not seem too big a deal to me to be sure that I'm never stranded on the side of the road with no gas. That being said, I'm also one of those guys that has comprehensive auto insurance and added coverage beyond the state minimum.
  18. gringostar
    46
    Santa Ana, CA
    I am just stating the facts. You can't argue with math. A reserve of 2 gallons is enough. Why you all want 3.5 gallons of reserve is beyond me. (Obviously I'm not talking about cold environments.) 2 gallons is far from vapor.
  19. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    You don't get it. You don't know whether you have an extra 2+ gallons of reserve or not. If the bladder has shrunk or folder over then you do not have much of a reserve.
  20. ngc4565
    ngc4565 Member
    193
    33
    Pennsylvania
    2023 Prius
    Thanks Jimbo. My understanding of the Prius is limited our 2010 Gen 3 model. I was not aware of the limitations of the earlier models.
