$4500 tax rebate
Discussion in 'Prime Main Forum (2017-Current)' started by geguia, Apr 6, 2017.
  1. geguia
    geguia Active Member
    207
    107
    los angeles
  2. dalcon95
    dalcon95 Senior Member
    512
    652
    Easley, South Carolina
    Top paragraph says that is the minimum you can get for a passenger vehicle. Bottom paragraph says that because it is the most you can get for smaller than passenger vehicles. The Prius Prime qualifies for $4502. The tax credit is based on the size of the traction battery in the vehicle. You will need the federal tax form 8936. In order to get the full $4502, you have to have a tax liability of at least $4502. If not, you will only get the tax credit amount of your tax liability under $4502. It is a non-refundable tax credit.
    #1 in Easley,SC
    Merged, use multi quote
    30D. New Qualified Plug-in Electric Drive Motor Vehicles – Toyota Motor Sales, U.S.A., Inc.
    #1 in Easley,SC
    #2 dalcon95, Apr 6, 2017
    FA6, EV-ish and priuscatprimeguy like this.
  3. geguia
    207
    107
    los angeles
    thanks going to my tax person this afternoon and want to make sure i have the necessary info for this.
    dalcon95 likes this.
  4. EV-ish
    EV-ish Active Member
    602
    277
    SW US
    That applies to two or three wheel vehicles.
    Merged. use multi quote
    Exactly right.
    One trick that might be available to people with too low a tax liability to take advantage of the full tax credit amount is conversion of an IRA to Roth. This way you get the conversion for free. It would have worked out nicely for me, but my Obamacare premium is tied to my income so the income tax (or Roth conversion cost) savings are offset by increased health insurance premium charges.
    #4 EV-ish, Apr 6, 2017
    Debgirl25, Merkey and dalcon95 like this.
  5. sumting77
    sumting77 Junior Member
    22
    So Cal
    2015 Prius Plug-in
    So does this mean that at the end of the year I have to owe the government $4502 on top of my regular withholding? Or is it enough that I paid the Feds at least $4500 and thus will get the full amount refunded?
  6. Pasaman
    Pasaman Active Member
    289
    110
    Southern California
    The latter. As long as you paid them $4502, you will get $4502. This is my understanding of it.
    sumting77 likes this.
  7. EV-ish
    602
    277
    SW US
    Neither.
    Reference line 44 on the Form 1040 and then subtract all your other non-refundable credits. If the result is less than $4502, the result is the EV tax credit you will receive.
    Addendum: Error corrected -- 'Reference line 44' originally said line 43.
    #7 EV-ish, Apr 6, 2017
  8. iskey
    iskey New Member
    22
    Ohio
    And if you're married filing jointly do both spouses incomes count toward the $4502 paid in taxes? Or do they only go by your own withholding?
  9. Pasaman
    289
    110
    Southern California
    I defer to EV-ish as my reply was not entirely correct.
  10. EV-ish
    602
    277
    SW US
    And in that vein I also add a disclaimer: I am not a CPA and have never bothered to learn how AMT affects the variety of credits any one taxpayer may try to collect. The answers that Dalcon and I provide are pretty accurate for reasonably uncomplicated, middle-class tax returns.
    dove, dalcon95 and sumting77 like this.
  11. sumting77
    22
    So Cal
    2015 Prius Plug-in
    Thanks for all your help thus far. My original plan was to change by deductions (to 14) in order to create an actual tax bill of $4,500 by not paying in every 2 weeks. It seems I may need to readjust.
  12. EV-ish
    602
    277
    SW US
    Tax pre-payments do not change your tax liabiltiy; they change how much you owe or are refunded when you file your 1040.
    Nothing in a tax credit -- refundable or not, prevents you from getting a check from the IRS. I know this seems like contradictory information, but it is correct. See if following my post #9 helps, and note that calculations related to amount owed/refunded are later down the form 1040; that is, do not play into your strategy decisions related to optimizing receipt of the EV tax credit.
  13. dalcon95
    512
    652
    If you want the full tax credit at the end of the year as a refund, you need the $4502 withheld from your pay to cover your tax liability and you would get the $4502 added to whatever you went over your tax liability. Or you can back off your tax withholdings throughout the year and essentially get the credit throughout the year before you file.
    #1 in Easley,SC
    They use both.
    #1 in Easley,SC
    #13 dalcon95, Apr 6, 2017
    iskey and EV-ish like this.
  14. Pasaman
    289
    110
    Southern California
    This seems like it wouldn't work for some reason. But let's let a tax person answer.
  15. EV-ish
    602
    277
    SW US
    I looked at Form 1040 again, and note that the EV tax credit is entered on line 54 and then the sum of all credits are subtracted from line 44. Line 44 is often referred to as 'tax liability.'
    So my post #9 should start from line #44, not line #43. Form 1040 does not distinguish between refundable and non-refundable credits but the difference surely exists. Somewhere ;-)
  16. sumting77
    22
    So Cal
    2015 Prius Plug-in
    Let's use last year's numbers with this year's EV tax credit.
    Line 44....... $9,036 (Tax Liability/Does not change based on prepayments)
    Line 54........$4,502 (EV Tax Credit)
    Line 56/63...$4,534 (Line 44 minus Line 56/Actual tax liability after tax credit)
    Line 74........$10,618 (Taxes paid throughout the year/from W2)
    Line 75........$ 6084 (Refund amount/Line 74 minus Line 63)
    Does that look right? If so, my approach of prepaying less per check still makes sense right? I just get the money each check vs at the end of the year.
    #16 sumting77, Apr 6, 2017
  17. EV-ish
    602
    277
    SW US
    This is exactly right if your only credit is the EV. You probably just have a typo here, but your
    Line 56/63 .... should be (Line 44 minus line 56)
    Exactly right about the prepayments.
    sumting77 and dalcon95 like this.
  18. sumting77
    22
    So Cal
    2015 Prius Plug-in
    You are right, fixed it! Thanks again for helping us out.
  19. Pasaman
    289
    110
    Southern California
    Since we are on the topic, will i get the rebate next year if this year my total I paid to feds was like 10k, and my total tax due was 7k, and I got a 3k rebate. If my taxes are the same next year I assume my total tax due will be 2500 with a 7500 rebate?
  20. dalcon95
    512
    652
    Correct!
    #1 in Easley,SC
    Pasaman likes this.
Loading...
