46 MPH is the new threshold for STEALTH
Discussion in 'Gen 3 Prius Main Forum' started by john1701a, Jun 1, 2009.
  1. JimboK
    JimboK One owner, low mileage
    2,817
    190
    49
    Chesterfield, VA
    Sort of a side issue to the point of the thread, but since you mentioned it ....
    Some time ago a few of us reported discrepancies between each other's LOD readings at various speeds and RPM. Between that discussion and some elsewhere (including this one, beginning at post #14), some of us have come to believe that Toyota changed the way it reports LOD somewhere between the earlier NHW20 models (2004 & 2005, at least) and the later models (by 2007 at the latest). It seems reasonable to assume that they chose the later calculation method for the 2010. If so, it makes LOD comparisons between 2004 and 2010 unreliable.
  2. jprates
    jprates https://ecomove.pt
    387
    42
    Moita, Portugal
    2017 Prius PHV
    On a 2004-2009 model there is an easy way to discover this via service menus on the GPS data screen.
    Is there a service menu on the 2010 as well? Does the trick to pop up the service menu on a 2004-2009 work on a 2010? As anyone tried it yet?
  3. DeanFL
    DeanFL 2010 owner - 1st Prius
    1,015
    355
    Leesburg Florida USA
    I now understand the terminology and awaiting the opportunity to put into practice. Thanks folks!
    More of a technical / operational question. Of course the ICE on/off is computer controlled.
    In general, how quickly does the ICE shut down, as in these examples (assuming normal drive mode, discounting A/C use):
    A. Driving 40MPH and you let up on the accelerator for about 5 seconds as the driver just ahead is a bit slower, to drop speed to 38.
    B. Typical city stop and go driving - does the ICE turn off immediately when applying the brakes for the quick stop&go for a stop sign? Or when stopped? Or a bit of a delay in the case of re-accelerate after the quick stop.
    C. Driving about 30MPH, need to slow for a 25MPH curve. Car coasts around the curve for 10 seconds then accelerate up to 30 again.
    Is the entire programming for the timing of ICE shut down factory set?
    Does the system "learn" an individual driving habits as some other vehicles (for elec transmission) advertise?
    No doubt a Prius engineering formula for fuel savings - keep the ICE running for X time -vs- shutdown and power up in X time.
    Just wondering how many times in general the ICE fires up and cuts off in typical driving situations.
  4. bwilson4web
    16,540
    I found the indicated speed to be 1 mph high compared to a Garmin nuvi GPS but the trip meter average is accurate.
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    On the same note as John's discovery, has anyone noted if the threshold for stealth when in S3 is the same as the 2G or if that has changed as well?
    What about the S4 dance, is that the same?
    My head is already spinning with ways I could take advantage of that extra 3-4 mph of stealth on my commute.
  6. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    There's more to it.
    STEALTH was termed as so for many reasons, one of which was because it is difficult at times to distiguish it from fuel-cut. It can be unpredictable too, since it is totally dependent on the emissions system being warm enough.
    Anywho, once we got devices like ScanGauge, it became easier. We could actually see the RPM at 0. That confirms STEALTH... when you continue to drive with the engine stopped and not engaged in "EV" mode.
    STEALTH is unique to FULL hybrids. They have a power-split device. ASSIST hybrids don't, so they lack the ability to stop the engine while still driving (thrust coming from an alternate source). It's a distinction commonly not understood.
  7. marzprius
    marzprius Junior Member
    92
    Northcoast
    Anybody noticed any increase in regen over Gen II? Either by feel or increased current on the gauges?
  8. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    That extra 3 mph of stealth matters not to me, but I'm sure many a person behind a G3 will appreciate it ;)
  9. ljbad4life
    ljbad4life New Member
    365
    24
    I am soooo glad that someone cleared up my own misconceptions. for some reason when I kept reading that ev only worked up to 25 mph, I thought that meant stealth too. hopefully I'm not the only one to make that mistake.
    2 people like this.
  10. Foulwx
    Foulwx New Member
    Eastern PA
  11. john1701a
    12,840
    5,312
    58
    Yes, by regen symbols on the MID.
    It's much like that with the Classic model, since the motor size increased (plus software/battery enhancements)... 33kW to 50kW
    From Iconic model to 2010... 50kW to 60kW
  12. bwilson4web
    16,540
    I'm 90% sure it is gone. Now some of the warmup still has me scratching my head. For example, on a 57F morning, the one minute display showed two, ~25 MPG bars, a 100 MPG bar, and a 25 MPG bar. Then there was ramp up to steady 65-75 MPG bars that took about 10 minutes. Without adequate instrumentation, I'm really not sure what is going on but I am very confident that final S4 "stop until engine stop" nonsense is gone.
  13. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    Hi Bob,
    Thank you for your response.
    My 2010 Prius will be delivered on June 5th. I'll try to find the offset on the Japanese model.
    Ken@Japan
  14. bestmapman
    bestmapman 04, 07 ,08, 09, 10, 16, 21 Prime
    1,289
    242
    Kentucky near Cincinnati, OH
    There is still a significant warmup phase although it is very different then the Gen II. We just need someone to document it.
    The good news is that I am very sure that it is not as severe as the Gen II,
  15. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    The above post has the potential to create some misconceptions for newer folks and how efficient Prius driving is done.
    Stealth, EV, glide and coast are not the same. Not at all. Each one of these is a very distinct and different forms of ICE-off movement of the Prius that are attainable by simple and small gas pedal manipulation.
    Stealth is electric operation below 42 MPH (yellow arrows from battery)
    EV is electric operation below 34 MPH induced with the use of an "EV" switch that some have installed on a 2cd gen. Prius.
    Glide is movement with no arrows (most efficient method) and easily attainable below 42 MPH with simple gas pedal manipulation.
    Above 42 mph this same technique will most likely result in Warp Stealth, where you'll have yellow arrow from battery only. Also, Basically electric operation although the engine in recipricating with little fuel burn.
    Simply taking your foot off the gas pedal results in Regen ("coasting" is not an applicable word in the Prius.) Regen is where the ICE shuts down and the rotation of the wheels in used to regenerate a charge to the battery. Neat, but it drags the car's speed down, so you would only use it when stopping, slowing, or speed midigation is necessary.
    Understanding these terms and putting it to efficient, common sense use is truely taking advantage of what a hybrid like the Prius is all about.
    Confusing these terms will cause someone to think they are doing something they are not. And cost them MPG
    So, it appears stealth and true glide ability have been raised to 46 mph in the Gen 3.
    5 people like this.
  16. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    So a EBH might help like the Gen II. The warm-up profile graph said you still have about the first 5 minutes of just engine warm-up before Exhaust Heat Recovery really kicks in, only without the thermos injection. I think I'll still be enjoying my hobby.
    Wayne
  17. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Warp Stealth - Over 47 MPH (42 for Iconic model), release the accelerator and feather it so the arrow flows from HV battery to wheels.
    A question about 2010 Warp Stealth....
    What RPM does the ICE remain at? The Iconic model stays below 1,000 RPM, around 960 RPM.
  18. xsmatt81
    xsmatt81 non-AARP Member
    522
    Vegas
    sweet 4mph gain is welcome, now 2010 owners can adequately keep up with traffic a bit easier when "stealthed "
  19. a priori
    a priori Canonus Curiosus
    3,083
    408
    23
    Chicagoland (West)
    I haven't measured this with a separate GPS unit, but I've been wondering at the reported "Set" speed on the cruise control. When I set the cruise control (and Radar is on, using the Adaptive Cruise Control), the reported "Set" number is 1mph higher than the indicated speed on the speedometer.
  20. charlieh
    charlieh Junior Member
    I have owned Gen I,II and now III. "Warp Stealth" seems to significantly more difficult to obtain on Gen III. I had it wired on Gen II, but the same stretches of highway that I could warp on in my 2004 are not NEARLY as easy to eliminate the "red arrows" on the gas engine side. However, the dang thing is so quite, I'm having trouble telling whether the engine is really turning/using fuel or not. Any opinions from the tech guru side on this issue? Is the 2010 harder to get into warp stealth or is the information feed different making me THINK it's harder??
