$4k too much?
Discussion in 'Gen 2 Prius Main Forum' started by douggie, Dec 4, 2018.
  1. douggie
    douggie New Member
    flagstaff az
    Hello all, Noob question here:
    A local guy is selling a 2008 Prius with a few bad batteries - he doesn't want to pay dealer big bucks to replace it. He is asking $4k for a 2008 with 155k miles, clean inside and out.
    assuming the engine or transaxle isn't toast is $4k reasonable for a 2008?
    I can take care of the battery issue and other mechanical stuff but I don't want to sink a lot of cash into it as I have a tacoma with suspension issues that I am going to fix.
    I will exercise do diligence and check it out, may even take it to the dealer.
    I was thinking of offering $3k to the guy.
    Any sage opinions...?
    Cheers
  2. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
  3. PriusCamper
    PriusCamper Senior Member
    13,468
    5,438
    Pacific Northwest, USA
    Offer him $3k and let it cook for a while. The fact that he's admitting a problem is honorable. Most do all they can to keep the problem secret and get warning lights to not come on just long enough to sell it.
    If you have the mechanical ability and have done enough reading on here, you already have a sense of the work to be done and you know we'll do all we can to help you out and walk you through it.
    Somewhere between $3-4K seems reasonable, especially if the problems don't have many miles on them. If you find out the problems have been around for a long time and they've been ignoring it for too long, it's likely more expensive and you oughta look for something better.
    52,878
    welcome!
    find the cost of a new battery, deduct it from kbb value and make him an offer. but be prepared for a bad brake actuator, combo meter and other expensive repairs
  5. douggie
    douggie New Member
    flagstaff az
    Thanks for the welcome and the advice.
    I pulled a carfax report. Seems it has had 3 owners and was just traded in to the local dealer. I was thinking $3k was around the right price for it. From the pics the interior and body are super clean and carfax shows it has mostly been serviced at toyota dealers.
    Makes me wonder why the dealer didn't want to effect any repairs and then resell it...
    It actually has 188k miles on it, I misread his text. Aside from the battery are there any very common failures on these gen2 nearing 200k miles I should look for?
  6. VFerdman
    VFerdman Senior Member
    1,200
    1,221
    Western Massachusetts
    If the battery is known bad, $1500 - $2000 sounds more like correct price. New battery will cost you around $1600 - $3000. Replacing modules in the bad battery is no longer a good option as most of the used modules out there are nearing end of life and the fix will not last.
    Good luck and keep us posted. I am looking to buy my second Gen 2 right now and am also on a lookout for a car with a bad battery so I can replace with new. I would not pay $3K for a car with a bad battery, though. Carfax indicates that in my area a Gen 2 with close to 200K miles in good condition (that means GOOD battery) is worth around $3K retail and $2.2K in private sale. Subtract the cost of new battery and your $3K offer will be generous.
    Skibob and kenoarto like this.
  7. douggie
    douggie New Member
    flagstaff az
    Thanks VFerdman... gen2's are going for $5-$6k with 125-150k miles in my area. I am prepared to drop cash for a new battery, I just wonder how long the engines last.
  8. bisco
    52,878
    brake actuator
    multi information display
    hvac/radio display
    oil burning
    tranny
    a/c compressor
    James1964 likes this.
  9. Mendel Leisk
    42,364
    Reading between the lines: I don't think this would be a good buy for you. Regardless of price. Maybe just pick up a comparable Matrix, something like that.
  10. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    $4k it is too much. $1600-$2500 defines "a lot of cash". $3k for a dead car is still wishful thinking. Betcha the brakes and tires are shot, too.
    Skibob, James1964 and Mendel Leisk like this.
  11. James1964
    James1964 Member
    177
    83
    Vashon Island, WA
    What are the symptoms of a bad, or going bad brake actuator please?
  12. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Will the vehicle 'Ready' and drive?
    You need to be able to listen to the engine (at the very least), as the dealer will be no help.
    Grab a mini-vci cable and a copy of techstream, then scan it for codes to see what you're working with :whistle:
    Raytheeagle and Skibob like this.
  13. bisco
    52,878
    i have never experienced it. iirc, it starts by making funny noises, and can go quite a long time with no braking issues.
    then the buzzing sound from pressuring gets longer and more frequent due to leakage, then the pedal gets funky and the dash lights up with associated trouble codes.
    these may not all happen, or there may be more.
    don't quote me
  14. ETC(SS)
    7,571
    Project car:
    Yes.
    IF you can cash flow parts and are handy with tools and YouTube wisdom, have a place to work on it.....etc.
    Something that you depend on for turn-key transportation?
    Nope.
    YMMV
    frodoz737 likes this.
  15. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    The answer is quite simple. The dealer could not make a profit on a car with 188,000 miles after putting in a new battery. The dealer probably gave 1000 bucks for the trade in max. Have you seen the car in person yet, or just pictures? Could need new tires, brakes, who knows what else. Is this a dealer or a private sale? If it’s private how did he get the car?
  16. douggie
    douggie New Member
    flagstaff az
    Carfax shows the seller just acquired it from the dealer. I grilled him on it. I low-balled him with an offer. I'll see how far he comes down.
    I haven't seen it in person yet. I'm ready to pass on it if he is stuck on a high price.
    Tires and brakes I can live with... those things are regular maintenance on any car. I'm concerned with stuff that will kill it like inverter and other hybrid drive stuff.
  17. Skibob
    2,912
    1,505
    Northern California
    So a private seller then? My guess is he works at the dealer or knows someone who does and got the car for 1000 bucks or so. Just remember tires 500 Installed? Brakes 150 for a full set? (Don’t get aftermarket for a Prius) little things add up.
    You made an offer without even seeing the car? If I sold a car and someone lowballed me without even seeing the car I would put him on ignore and move on.
  18. Skibob
    2,912
    1,505
    Northern California
    Plenty of Prius in you area for around 4000.
    flagstaff for sale "prius" - craigslist
    Unless it’s so good sparks fly out of your A$$ when you drive it, I would not offer over 2500 if the tires and brakes are near new. Less if they are not.
  19. frodoz737
    frodoz737 Top Wrench
    4,808
    2,562
    33
    Walk away unless you have about $5,000 to put into it in the next year or so.
  20. MilkyWay
    MilkyWay Active Member
    823
    359
    23
    MI
    $500 to $2000 would be fair price for an 08 with 155k with a bad hybrid battery.
    They are very hard to sell in the 4 to 5000 range when everything is perfect.
