4kwh Enginer GenIII PHEV in UK
Discussion in 'Prius PHEV Plug-In Modifications' started by Flaninacupboard, Jul 25, 2010.
  1. Simtronic
    Simtronic Active Member
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
    I am getting mine soon, expecting ship to dock in a couple of weeks.
    As to the heat I am fitting a hot frog on a timer and a partial grill block, should be toasty by the time I get in the car in the mornings.
  2. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    I had to google hot frog, never heard that term before!
    Just as an update, i'm pretty sure i have a faulty BMS, just trying to sort out getting a replacement. I can't really use the kit without it, which is a shame :(
  3. Simtronic
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
    Good luck with getting the replacement promptly, it will be interesting to see how long hopefully without finding out for ourselves ;-)
  4. Simtronic
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
    A hot frog isn't a term as such more a make, it is an all in one solution made by a German company, they are reliable and simple to install, the best thing about it is the pump and thermostat is built in and can heat whole cooling system not just conduct heat from one point.
  5. ms15342
    ms15342 New Member
    Durham County UK
    Hi do you have a link to this product
  6. ms15342
    ms15342 New Member
    Durham County UK
    Hi GrumpyCabbie
    Good point about the insurance, I have a system from Dec 2009 and have re-insured twice now without problem or extra cost but you do need to explain what the mod does.
    You don't need to travel that far to find Enginer systems as I know of one in Yorkshire and mine just over the North Yorkshire border in Darlington.
  7. Simtronic
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
  8. Prius_London
    Prius_London New Member
    London
    I got the same problem but with charger. It just doesn't work. It alwas flashing red led.
  9. ms15342
    ms15342 New Member
    Durham County UK
    Hi Simtronic, thanks for the link it is just what I have been looking for and as I am in the UK I have just ordered one.
  10. Floyd2
    Floyd2 progressio per sententia
    106
    23
    Netherlands, Europe
    I had some amazing results with my first testdrive today and everything seems to be working just fine, short report here: http://priuschat.com/forums/prius-p...3-whats-enginer-like-drive-3.html#post1231252
    But in this cold my garage is around 0 to 1 degrees Celsius and that is too cold to charge without damaging the batteries.
    There is still some charge left in them (12%) so if I first switch it on to discharge tomorrow, would that not warm up the batteries so it is safe to charge them after a few minutes?
  11. AkustaVirtaa
    AkustaVirtaa Sähköistäjä
    198
    Finland EU
    I don't see a problem to charge them if temperature is over 0 degrees. Batteries will warm up when they are charging up. It is always better to have cool batteries than hot ones.
  12. Floyd2
    106
    23
    Netherlands, Europe
    Okay, thank you Akusta! The garage is alway a little above freezing, I will just charge them...
  13. Simtronic
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
    I have no garage and it is often below freezing at this time of year, if I put them on charge as soon as I get in the drive I know the batteries will be warm enough or does someone know something I don't?
  14. AkustaVirtaa
    198
    Finland EU
    There is about charging at low temperatures:
    Charging at high and low temperatures
    Maybe you can check with thermometer do they stay over zero Celsius? Or start planning some kind of thermal blanket… :rolleyes:
  15. Simtronic
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
    The more I think about it the less I worry, the battery is in the back of the car, I use the heater while driving and it would take a fair amount of time for the pack to cool down being inside the car. The charging process itself will keep the pack warm during charge. One question I do have though is about the charger. I am in the Uk and am being supplied with a 220v charger. Does anyone know the approximate charge time for a 4kw pack with this charger? I imagine it will be similar to the 110v decided by charger amp rating, anyone know?
  16. ms15342
    ms15342 New Member
    Durham County UK
    My early system (December 2009) takes an average of 4hrs to recharge on 220v
  17. Flaninacupboard
    1,297
    213
    Midlands - UK
    5 hours sounds about right. with the couple of charges i've done the most i've seen is ~800 watts being drawn.
  18. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Blimey you've got me intregued. Which system do you have? 2kw or 4kw? Am tempted once my warranty is out but I might wait for the official PHEV Prius and am even toying with a Nissan Leaf if I can get the council (or whoever) to install a 30 min fast charger.
  19. Flaninacupboard
    1,297
    213
    Midlands - UK
    Grumpy, don't know how far your nearest nissan dealer is, but if they want to sell leafs they MUST have 2 fast chargers publicly available...
  20. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    The official Leaf dealer is Leeds - 15 miles away! hmmm :(
