4kwh Enginer GenIII PHEV in UK
Discussion in 'Prius PHEV Plug-In Modifications' started by Flaninacupboard, Jul 25, 2010.
  1. madmarc
    madmarc Junior Member
    Graz / Austria
    hopefully enginer get rid of the problems with their conversion
  2. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    Yeah i hope so. My personal wishlist is pretty short:
    Double the output of the DC converter (you could stay in EV mode without runing down the HV pack, and blended mode MPG would be much greater, but a shorter range)
    Change the enclosure shape/size to fill the spare wheel well. Use the extra space for 8kwh of battery, and better cooling.
    Use a BMS that works.
    Double the output of the charger (it charges at one 6th C, takes six hours, should be 3)
    Monitor the HV SOC and CCL over canbus to make sure they are not exceeded.
    It then becomes a $6k-$7k kit which can run 40 miles in EV mode under 30mph, or 40 blended miles at 200mpg or so. you could even slect a "long range" mode which ran for 80 miles at 100mpg. If they can make that happen, i'll buy one. Once you've had a taste of electrons petrol just tastes disgusting.
  3. electric1
    electric1 Junior Member
    Tampa FL
    At that point you are getting close to PIS kit cost, which completely removes the DC-DC problems, has even larger 10kWh battery, "whispers" to Prius to get much better mpg, etc etc.
    The bottom line of current PHEV kit market is that you have a choice of "cheap" but "marginal" improvement kit vs. "significant improvement" kit, but at the higher cost. In the end, you get what you pay for.
  4. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    "Buy cheap, buy twice" as my Gran used to say
  5. Flaninacupboard
    1,297
    213
    Midlands - UK
    Your gran is probably right! But i spent probably more money on pointless things (adding heated rear seats, front spoiler, 5th alloy wheel, chrome fog lights bits, different front grilles, beesting aerials, subwoofer etc etc) on my last car, which to be honest no-one except me gave a shit about. At least with this mod i may eventually save some money, and i can talk to people, make them think about EV's, HEV's, PHEV's, and it sounds kind of cool that you did it yourself.
    I've also been speaking to the DVLA about changing the fuel type on my V5, which they are happy to do, but for a CO2 level change i need written approval from Toyota, so i have asked for that, but don't know if the car would have to go through NEDC, or they can just estimate based on their finding with the PHV.
  6. Flaninacupboard
    1,297
    213
    Midlands - UK
    I had to buy another tank of petrol! I could have gone a little further (835 miles, and only put 39 litres in) but we've got a busy week on and have to go out of the way to get fuel. As per the sig, the tank came in at 99.9mpg which i'm pretty pleased about.
    miniBMS still functioning well, still thinking about whether to do some upgrades (double pack size, two converters, cooling mods etc) but watching people like plug-in supply to see what they can produce at what price for gen3.
  7. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    835 miles to a tank? What speeds do you go to get this sort of mileage? Does the car perform in the same way mine does when I have a completely full HV battery after coming down a long hill, ie where it will run quite well on EV upto about 40 mph? Or is the car in a 'super' blended mode?
  8. Jands
    Jands New Member
    88
    UK
    Great results which will only get better with the summer days ahead of us.
  9. Jands
    Jands New Member
    88
    UK
    Flan - now that you get to 99.9mpg can't you get a more accurate mpg figure? ...not sure how though maybe Fuelly or scangauge (if euro compatible)...I'm sure someone here will say...
  10. Flaninacupboard
    1,297
    213
    Midlands - UK
    Grumpy,
    My average speed indicated on MFD is 31mph. To get to work, i have to go through my village and two others before reaching an A road, which is why the average is low. once on the A road i am doing 60. If on a dual carriageway/motorway i only do 60.
    As for how it drives, it's fairly normal. stealth up to 46mph is possible (if you're patient) and real EV up to 30mph is quick and easy. i am normally on 6 or 7 bars. If i do a lot of braking, or go down a big hill, i can sometimes hit 8 bars. when that happens the car does behave differently. When you go over the centre line on the HSI the ICE doesn't engage, you have to go about a third past the centreline before it does.
    I think my improved economy comes mainly from -not- using the ICE to recharge the HV battery after going through the villages (a real killer before) but secondarily from blended mode. with careful throttle control i can go 100mpg at 60mph.
    Jands,
    I did "miles travelled/gallons purchased" which gave me 97.something MPG, but i am using the MFD for me before and after data. I am considering a scangauge.
  11. Floyd2
    Floyd2 progressio per sententia
    106
    23
    Netherlands, Europe
    I also have a high C15. Between C15 and what do I put the 3.2 ohm resistor?
  12. lopezjm2001
    lopezjm2001 Senior Member
    1,146
    407
    Sydney Australia
    Hi Floyd,
    If you have a look at the wiring diagram of my MiniBMS you should be able to determine which wires of the 9 pin RHS battery plug are cell 15. Just connect a resistor across the cell. Be carefull not to overdrain the cell or you might damage it. The idea is to increase the driving range of your Enginer RFE battery pack by decreasing the charge of your overcharged cell. One cell at a time and highest charged cell each time until they are closely balanced.
  13. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    115
    Hey
    Just curious how your Gen3 Prius with Enginer kit is doing? If you can plz plz show images of rear kit install and other update new please/ Scangauge 2 with Xgauge for Gen3 can show alot Prius data just check out linear logic website..
  14. Flaninacupboard
    1,297
    213
    Midlands - UK
    It's still working fine, although I will shortly be selling the kit as I no longer drive the prius.
  15. Agape
    Agape Member
    378
    Ireland/Eire
    Hi Flaninacupboard
    How old is your kit?
  16. Flaninacupboard
    1,297
    213
    Midlands - UK
    Picked it up Nov 2010, so 18 months. It's one of the newer ones with less agressive BMS and the pouch cells.
  17. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    What you got instead Mr Flan?
    I thought you'd gone a little quiet on this forum.
  18. Flaninacupboard
    1,297
    213
    Midlands - UK
    A Y-reg Laguna estate :(
    The second hand iMievs are coming down in price rapidly, I think i'll get one when they hit £10k or so.
  19. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    You're kidding? Heck have you fallen victim to this economic downturn too?
    I'm out of the cabbie game and trying to use the ol' friend network for a job - any job, even minimum wage, but there's just nothing out there. It's dire. If it wasn't for the rapidly diminishing savings I'd be right up that certain creek already. As it is I think I have about 6 months left. :(
  20. Azzkhan
    Azzkhan New Member
    Birmingham
    Hiya mate.
    I live in Birmingham and am interested in purchasing the kit, if your still selling it. I am contactable on [email protected].
