4th generation coming 2015!
Discussion in 'Gen 4 Prius Main Forum' started by edmcohen, Nov 6, 2012.
Thread Status:
Not open for further replies.
  1. Tideland Prius
    16,678
    You mean the engine is different :)
    Is it possible you're seeing the benefits of the increased torque from the larger 1.8 litre motor that the effects of a drained battery is not as apparent than in the Gen 2? (We have both generations in the household so I know what you're talking about. I've driven both up mountains, never mind hills)
  2. mozdzen
    mozdzen Active Member
    719
    295
    Phoenix
    2015 Tesla Model S
    I don't think so - when the battery indicator gets down to the purple bars after a long uphill climb, the engine charges the battery and you don't get to use the electric engine until you get out of the purple zone (3 bars?). With my gen III Prius, I've never seen the battery indicator turn purple, nor have I ever lost power from the electric motor. Maybe my car was defective? Anyone else with a Gen II notice that you'd have to get in the slow truck lane going 40 mph while climbing for a long time causing the famed purple battery bar?
  3. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    I drove a G2 Prius for 10 years and I now drive a G3 Prius vagon.
    This is a useful set to compare because the increased engine size in the vagon is offset by the increased weight. There is no doubt at all in our experience that the vagon has far fewer episodes of depleted battery and low power operation. At least to me, the reason(s) are obscure and likely multiple. Some possibilities:
    1. Effect of the reduction gear
    2. Control law changes.
    3. The 1.8L engine has an extended SFC range where it is highly efficient and thus does not require traction battery support
    4. The easily recognizable drop in power when the traction battery went into the purple zone in the G2 was as much from a small engine as it was due to shunting ICE power to the battery. I don't think the G3 does that mandatory recharge while the driver demand for power is high.
    Anecdotally, we lived in the Albuquerque foothills and would often drive the G2 into the valley, about a 1000 foot drop in elevation over 5 miles. On the way back (up) my wife would routinely enter the battery purple zone and experience the low power scenario. I learned to avoid the problem by being aggressive with the fuel pedal early in the climb to reach the top speed I wanted, and then I was able to take it (relatively) easy on the ICE and not require much additional battery draw. Only a set of red lights could foil me.
    I reasoned at the time that since the battery output was limited to 20 kW maximum, by leaning into the fuel pedal early I was forcing the car to use a higher fraction of ICE than it would have with its usual control laws had I accelerated gently.
    #2743 SageBrush, Aug 4, 2014
    Tideland Prius and mozdzen like this.
  4. GasperG
    GasperG Senior Member
    1,169
    601
    Slovenia
    2018 Prius
    Didn't own the Gen 2 but in Gen 3 both the battery and ICE are used only at full throttle when the engine is screaming at 5,000+ rpm. You would really have to abuse the car to drain the battery in an uphill climb. Maybe in that regard the Gen 2 was different and also used the battery power under lighter throttle?
    As for the battery tech, it must cope with high power to capacity ratio (10-20 C). A normal li-ion battery will not deal well with those high C values, those li-ion batteries in Prius+ and PiP are not your "normal" cheap cell phone or laptop batteries that Tesla can use in their cars. High power li-ion batteries are A123, I doubt those are as cheap as NiMh.
    For a efficient hybrid the most important factor is power rating and charge/discharge efficiency. Capacity comes as a collateral to rated power, if supercaps would be used something like 200 Wh of capacity would be enough, for a normal road driving conditions. It's the same with memory buffer in PC, when you come to a certain size there is really a small benefit to go even higher.
  5. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    With my 04 I can climb a 7% grade at 60mph at over 11,000 feet of altitude with a car full of people and stuff after the battery is totally depleted.
  6. westy72658
    westy72658 Jim Coleman Toyota in Bethesda, Maryland
    110
    67
    Louisa, KY
    Yes I do agree with what you have posted about my comment on "falling behind" from the perspective you explained above. Let me be more clear what I was trying to get accross. Prius is the number one selling hybrid out there. It is reasonably priced and offers the best value presently over all its competition. In my mind I am not comparing a Prius to a Tesla which is priced out of most Prius shoppers reach. When I say falling behind, I mean in the next 18 months while we patiently wait for the next generation Prius to be released, there coud be many buying choices from the competiton that offer equal or better fuel economy that draw "wouldbe" Prius customers away from Toyota . 18 months is a long period of time for Toyotas competition to catch up and potetialy knock Prius off the top in sales and drastically reduce their market share. I am on my second Prius and I want a third, but because of this delay I have been thinking of looking into a few other possibilities on my next car purchase. There are a few regular gasoline and diesel cars that have made great improvements in fuel economy and may even improve in the next 18 months. I am ready to buy now!! The question is for myself is ..I am willing to wait 18 months? Are you willing to wait? I am going to wait 18 months for now unless something else comes around that blows my socks off.
    mozdzen likes this.
  7. mozdzen
    719
    295
    Phoenix
    2015 Tesla Model S
    Me too.
  8. SageBrush
    11,627
    2,533
    Southwest Colorado
    Despite all the noise, no non-hybrid car reaches 40 mpg EPA combined. Improved highway economy is one thing, improved city fuel economy is a much harder nut to crack.
    westy72658 likes this.
  9. 70AARCUDA
    70AARCUDA Active Member
    845
    209
    Tucson, AZ
    Answer: higher power regeneration/recovery efficiency and rates!
  10. SageBrush
    11,627
    2,533
    Southwest Colorado
    In a non-hybrid car ?
  11. 70AARCUDA
    845
    209
    Tucson, AZ
    GM'S "semi-hybrid" used a motor/generator ALTERNATOR assembly which can both GENERATE (for storage) and USE electrical energy recovered during deceleration and braking...and 'add' power when useful...if the computer programming is similar to Toyota's use in Prius.
    It's just a bolt-on item, albeit with a VERY smart Regulator.
    #2751 70AARCUDA, Aug 4, 2014
  12. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Macro Economics show a different perspective. For Toyota to sell more Prius, the competition must first catch up. Put another way, a reduction of marketshare in the short-term can contribute to growth of marketshare in the long-term, since expansion isn't possible in isolation. There's a plateau to overcome which requires the cooperation of others.
    The problem is the consumer base cannot expand until the other automakers offer something actually competitive. Continuing to stand alone holds back acceptance. It's counter-intuitive, but that's how some aspects of business work. For the entire market to grow (more hybrids, less traditional vehicles), there must be first something in addition to Prius stirring interest of ordinary consumers... which means losing some sales.
    A simple survey of mainstream attitude toward hybrids in general makes that quite obvious. Heck, even here on this forum we see the problem play out on a regular basis. Just look at how often a "payback" message is posted. After all these years, you'd expect progress beyond that first hurdle would have been made. But with such a tiny presence from the other hybrids, there's little to help reach new buyers.
    In other words, competition is required.
  13. Tideland Prius
    16,678
    Yeah so the greater torque of the 1.8L engine and electric motors means the battery doesn't have to assist as much going uphill. Yes I've seen 2 bars more often in the Gen 2 than the Gen 3 (in fact up the steep part of the Coquihalla Hwy, the only time I'll drain the battery on the Gen 3 is if I'm accelerating up the hill to pass. If I'm just using cruise control, the battery won't be used in the Gen 3. Limit is 75mph/120km/h).
    If the engine is used to charge the battery, then less energy is available to turn MG2 to power the wheels so you're left with just a lack of power after a long uphill climb.
    SageBrush touched on a few good points too.
  14. Tideland Prius
    16,678
    Yes, with features such as what BMW (EfficientDynamics) and Mazda (i-ELOOP) are doing to minimise the use of the alternator to keep the 12V battery topped up.
    Excerpt from Mazda
    MAZDA: Brake Energy Regeneration System | Environmental Technology
    The link has more details and some images to help visualise.
  15. Tony D
    Tony D Active Member
    469
    132
    Dublin, Ireland
    Three guys in work have the new Mada 6 with SKYACTIV, I think it incorporates te I loop
  16. Tideland Prius
    16,678
    Nice! I do like the new Mazda6 (bloody wide door sill though!). The 2nd generation "North American" version was too bloated. I much preferred the 2nd generation "World" version that was slimmer and more stylish.
    In North America, the i-ELOOP system is only available on the top model (same goes for the Mazda3 - only on the top model with an option package).
  17. Tony D
    469
    132
    Dublin, Ireland
  18. Tideland Prius
    16,678
    It's not detailed in its specifications for each model but you do have the 2.0 litre petrol version in addition to the 2.2 litre diesel (both SKYACTIV engines). It's also interesting that there are different horsepower outputs for each trim level (Executive, Exec SE and Platinum).
    We only have the 2.5 litre, 187hp engine in North America. A V6 is no longer offered. The 2.0 litre petrol is offered on our Mazda3 and CX-5 models.
  19. SageBrush
    11,627
    2,533
    Southwest Colorado
    The highest combined EPA MPG I find for the Mazda3 is 35 mpg. Link please to the car that is 40+ MPG.
    By the way, I found one in the Mitsu mirage.
  20. drash
    drash Senior Member
    2,600
    1,339
    Upstate NY
    XLE AWD-e
    From the reviews, the Aussies hate the i-ELOOP and their Mazdas has an on/off button. It was pretty funny reading their comments, although I wasn't prepared for it being that bad. Apparently when engine restarts, there is some serious shuddering. They like everything else about the car, except that.
Thread Status:
