4th generation coming 2015!
Discussion in 'Gen 4 Prius Main Forum' started by edmcohen, Nov 6, 2012.
Thread Status:
Not open for further replies.
  1. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    With the slightly angled down bar extending to rear wheels, I am thinking this new gen4 Prius might have a multi-link, independent rear suspension.
    #5041 cycledrum, Jul 8, 2015
  2. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    Or run A/C when it is 80F b/c the darn thing is a sun magnet. Or just see over it when parking in tight spot.
    From spy pics looks like the hood/windshield/dash height in Gen4 is similar to Prius C, which is a good thing.
  3. cyclopathic
    3,292
    547
    2014 Prius c
    Are you sure it is Prius not Hyundai?
    Toyota said it is going to be a double wishbone I am guessing similar to one used in CT200h and altis.
  4. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Isn't double wishbone heavier than multilink?
    Pretty much every midsize sedan has what they call a multilink rear suspension. Civic has one.
    Ins't it true that very few cars have a double wishbone suspension these days?
  5. DtEW
    DtEW Active Member
    242
    137
    SF Bay Area, CA
    The problem with double-wishbone is not so much the weight, but the packaging, i.e. space requirements for both the articulation and hardpoints. Peer into the wheel well of a car with a modern double-wishbone design and you will see that the upper "wishbones" do have to intrude farther into the passenger/cargo/engine bay space. This is obviously a significant concern for mass-market vehicles. If the leverage is high (as often seen in the double-wishbone designs for the rear wheel, where the wheel knuckle is short and not long-and-cantilevered-over-the-wheel as often is in the front), you have to attach the other end of the double-wishbone to a subframe, which too takes up space away from the passenger/cargo/engine compartments.
    Multi-links are only more difficult to design, but it is much easier these days with advances in computing.
    If weight was the issue, double wishbones would have fallen out of favor in racing. They are still dominant in purpose-built racing vehicles at both the professional and amateur levels due to the design's versatility, ease of intellectual grasp and hence tunability. Packaging is a much more secondary (tertiary?) concern except when they need to solve specific problems, and *then* they might bust out a multi-link design.
    #5045 DtEW, Jul 9, 2015
    cwerdna, cycledrum and Zythryn like this.
  6. cyclopathic
    3,292
    547
    2014 Prius c
    I think it is more of the cost/packaging issue, but it looks like Toyota had figured way to pack it. I think they prefer it for 2 reasons: 1) the attachment points are the same as for torsion beam they use now, 2) it frees the space in the middle for battery. Last gen Altis (and Scion iM when it gets here) is actually using both, with double wishbone on diesel and HSD variants. On HSD it creates space for battery, and on diesel for after-treatment equipment.
    From what I read in article comparing wishbone to multi-link both offer similar level of performance, with double-wishbone being better, but multi-link offering more motion range and adaptability to variety of conditions in street application. From the looks of it Toyota had figured out way to pack it, and the reasons they had chosen double-wishbone (which btw from the looks is more like 1.5 wishbone not double) is b/c the attachment points are similar to torsion beam, and in TNGA application it offers a better packaging for traction battery.
    If you look at the pic in previous post and this one, there is a wishbone at the bottom, but on the top there is one link and one trailing arm. Multi-links are usually designed with 5 links: 2 at the bottom, 2 at the top and trailing arm.
    So you could argue that this "hybrid" as much multi-link as double-wishbone.
    I would speculate that TNGA platform had incorporated enough strength into frame, so the cross-members you see on pic above are probably not needed.. we will see when it is released.
    #5046 cyclopathic, Jul 9, 2015
  7. SAronian
    SAronian Active Member
    334
    144
    Oakland, CA
  8. Arroyo
    Arroyo Member
    217
    45
    Los Angeles area
    Is This The 2016 Prius?
    by Jeff Cobb
    A report of what is presented as a sneak peek of a 2016 Prius Liftback (pictured top) and double-electric-range Prius Plug-in Hybrid are shown on a Taiwanese website.
    If the images are real, they may be the only ones known of the much-anticipated next-generation hybrid cars.
    Prius Plug-in Hybrid? The report says under JC08 it gets 50 kilometers range (31 miles). If true, this could be in the 20s under EPA
    The drawings look fairly convincing, having resemblance to the silhouette of black covering-draped photos of 2016 preproduction cars floating out there, although the report leaves open room for suspicion.
    It definitely is not the result of an official Toyota disclosure, and the company has taken pains to conceal the new cars’ identities. To date it’s been unclear whether the plug-in hybrid was ready to show, or would follow the Liftback.
    More at Is This The 2016 Prius? - HybridCars.com
  9. bisco
    52,854
    that's it! great find.(y)
    Netcub likes this.
  10. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    Too funny.
  11. ncases
    ncases Senior Member
    609
    672
    Chicago
    Don't like the tail lights.
  12. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    ....to me the raised hood looks like one under wraps one of our members captured (big thread under discussion). I thought maybe there would be a slot in there for air intake but OK its just raised up in the middle for some reason. I am thinking grills may be managed so we don't have to do blocking in there any more.
  13. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    Toyota Civic si hybrid.
    Hahahaha!!
  14. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Um, nope. Doesn't match the Autoblog camo shots from July 7th.
    Those photoshops are fake all the way.
    #5054 cycledrum, Jul 9, 2015
    lensovet likes this.
  15. bwilson4web
    16,535
    Prius or not, what is with those front driver windows. Does it actually have a guide or split glass?
    Perhaps for a prototype but production would be nuts.
  16. FriarNurgle
    FriarNurgle Member
    138
    53
    These rumored renders are not "sporty". If anything I'd say they make the Prius look more bland.
  17. cmth
    cmth Active Member
    279
    142
    UK
    >> Is This The 2016 Prius? by Jeff Cobb
    I don't think so.
    There are serious weaknesses in these images making them unworthy of detailed analysis, the overall design is sub-standard all the way. Just look at the 2015 Toyota Avensis which was revealed a few days ago
    2015 Toyota Avensis revealed - Toyota
    I find it difficult to imagine that Toyota would come up with a below par design for their highest profile car when their other cars look much better.
    The photos of the camouflaged car (which looks like the current Prius) is most likely Toyota road testing something but again, I would bet what they have done is take TNGA and dressed it up like the current Prius just for testing purposes. Just doesn't seem logical to go around openly in a camouflaged version of the final car.
  18. cyclopathic
    3,292
    547
    2014 Prius c
  19. cmth
    cmth Active Member
    279
    142
    UK
    Yes look at me I'm driving the new Prius, here you go I've lowered the shutters, take some shots of the interior too. Everyone is looking at me, super, life can't get better than this.
  20. bisco
    52,854
    that looks sporty.
Thread Status:
