4th generation coming 2015!
Discussion in 'Gen 4 Prius Main Forum' started by edmcohen, Nov 6, 2012.
Thread Status:
Not open for further replies.
  1. cmth
    cmth Active Member
    279
    142
    UK
    Well at least they didn't have the front shutters down with the driver wearing sun glasses and looking eagerly at whoever might be looking at the car. In all likelihood, this is a proper test mule with the person driving concentrating on the job at hand.
    The Prius test mule on the other hand, seem to have been driven around with shutters down and the driver at the wheel glancing at the public most of the time - there are a number of shots confirming this. These things might seem insignificant or irrelevant but in really, it says a lot and hence the reason why it is not worthwhile analyzing the Autoblog Prius Test Mule spy shots.
    #5201 cmth, Jul 17, 2015
  2. Felt
    Felt Senior Member
    1,624
    604
    Mountain West
    A question more than a statement:
    I suppose I have not put much credibility into the test-mule sightings because I do not understand the process, especially with a new "global platform."
    It seems entirely logical, and not very difficult to put the ICE, Hybrid system, even the suspension in a G3 and test those components. Computer modeling could answer most of the sheetmetal, and aerodynamic question without a test-mule.
    But there is this consideration of a new "global platform," which I understand suggest the same sub-structure will be used for several models of Toyota automobiles. Couldn't (and might) the spotted test-mule be a test of the "global platform," and not necessarily be a test solely of the G4?
    Do you suppose the test-mule was hand-built?, otherwise, Toyota would have needed to set up the "global" assembly-line first? I'm doubting they could set-up the assembly line between now and September, based on the findings of the test-mule.
    Until I can get my mind to accept all of the production ramifications of a new "global platform" I am left with doubts about what has been seen and identified as a G4.
    #5202 Felt, Jul 17, 2015
    SageBrush likes this.
  3. Trollbait
    12,829
    From my first exposure to the term, I have taken-mule to refer to preproduction versions. They could be a late stage prototype or another model in the case of testing a specific subsystem. Toyota could have, and probably did, stick the the new HSD into a gen3 body. People have been swapping engines and transmissions in cars for nearly as long as the automobile has been around.
    Road testing the suspension is going to take the actual body, since the car's weight, distribution of said weight, and even the flex in the body itself play a part in the final tuning of it.
    The Gen4 test-mules are also test-mules of the global platform. Platform sharing has been going on for some time. A global platform means the sharing a larger percentage of subframes of the body to reduce costs further. Before, a car company would have a platform for their small cars and one for their large cars. With a global platform, those two platforms share a lot more in terms of common parts, or are even now one, modular platform that can just put in a "spacer" for larger models.
    A global platform is one designed with more foresight into using it to design and manufacturer future models and trims. I've heard the Camry Solara took two years to come out after the release of the Camry sedan. If that Camry had been designed on a global platform, designing a convertible coupe version would have been less costly in terms of money, manpower, and time.
    The gen4 testers is testing the global platform, but the global part is going to be the bones, the internals, of the car's body. In theory, Toyota could be testing it under the skins of current models.
    Felt likes this.
  4. Netcub
    Netcub Active Member
    344
    170
    Kentucky
    And in theory they added a new front and rear Fascia to the Gen 3 Test Mules?
  5. nwprius
    nwprius Member
    227
    35
  6. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
  7. sillylilwabbit
    sillylilwabbit Active Member
    405
    118
    Los Angeles
    2014 Prius Plug-in
    Wow!!!
    Rated C's across the board (except economy, but that is expected for a hybrid)
    That is a pretty sh¡tty rating!
    Even more wow!!!! Averaging $3.00 per gallon for a hybrid... I think that is going to be more expensive than just regular gas!
    Gas prices has been steadily coming back down. US's deal with Iran's nuclear energy will flood the market with Iranian oil creating more supply of oil to the world market.
    With the US making headway with fracking technology and Sudia Arabia saturating the market with oil as well, these hybrids need to be more efficient or the price needs to be substantially lowered prices.
    #5207 sillylilwabbit, Jul 18, 2015
  8. El Dobro
    El Dobro A Member
    7,106
    3,282
    I've always liked his reviews.
  9. bisco
    52,855
    gas dropped ten cents here, yesterday. $2.65
  10. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    Hmm, well here, where it's produced, it went up about the same amount. And please don't complain about how much you pay in the US. Here it's running around $1.04 per litre. That's around $4 per US gallon! It -was- close to $5 a few months ago! I'll bet it's even more in the UK.
  11. Mendel Leisk
    42,345
    For me I don't care what the price of gas is; I just love the sounds of silence, at red lights and under light load. Couldn't go back, hooked.
  12. bisco
    52,855
    agreed, wish that worked for more people.
  13. lensovet
    2,615
    496
    Burlington, NJ
    it gets even better when the same is true @ 75 mph ;)
  14. Tideland Prius
    16,680
    Don't forget to multiply by ~1.25 exchange rate (Cdn$1.29 to the US$1 or 0.77¢ US to 1 CAD). So it's actually $4.92/gal (1.04*3.785*1.25). It's $6.43/gal here.
  15. vinnie97
    vinnie97 Whatever Works
    1,430
    277
    Somewhere out there
    I also agree...there's something nauseating (maybe the fumes? ;)) about an idling ICE when stopped at a traffic light or in backed up traffic. That's why the only way forward from the Prius for me is a PHEV or BEV.
    iplug and bisco like this.
  16. David Beale
    5,963
    1,990
    Edmonton Alberta
    I was going to do the conversion, but then realized the price of gasoline doesn't seem to be following the dollar's drop. The price went up -before- our dollar dropped. Gasoline is only -loosely- based on the price of crude. At least half or more of it is supply and demand/refinery capacity/refinery costs. Anyway, our gasoline is made from our crude, though the local producers keep -hoping- they get "world prices" for it. They don't. ;)
    Tideland Prius likes this.
  17. Felt
    Felt Senior Member
    1,624
    604
    Mountain West
    The price of crude is possibly the cause of large fluctuations in the price of gasoline, but the final cost is based on what a dealer can get. A friend, each morning drives around the neighborhood and checks the price of gas in the area. Then he post the price at his station.
  18. bisco
    52,855
    and then everyone else changes theirs.:p
  19. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I think this is the 4th gen Prius ...
    2016 Toyota Prius: Our best look yet
    and based on the shape of the car, I think Toyota took it in the direction it ought to go. When you have a successful formula, you don't mess with it too much: somewhat lower hood, angled up windshield, lower doorlines, still a Prius. Just like Toyota has been saying for years.
  20. vinnie97
    1,430
    277
    Somewhere out there
    Don't like especially after being treated to the much sexier Motor Trend demo from 2012.
Thread Status:
