4th generation coming 2015!
Discussion in 'Gen 4 Prius Main Forum' started by edmcohen, Nov 6, 2012.
Thread Status:
Not open for further replies.
  1. jdonalds
    jdonalds Active Member
    541
    225
    Redding, California USA
    I agree. I want my gauges behind the wheel. That's not a deal breaker but a major annoyance. We took a look at the V but that gauge setup was worse then the sedan. We didn't buy a V and the gauge placement had a lot to do with that decision.
    One thing is off my deal beaker list. It looks like the flying bridge is gone. We skipped Gen III for that reason.
  2. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Hopefully the 2016 Prius mpg computer will be more accurate than our 2010 Prius. Its still off after 130,000 miles by 2.5-3.5 mpg over read.
    So even if the 2016 Prius mpg computer is off the same amount mpg should be at least 53 mpg true....
  3. Trollbait
    12,829
    I don't knowledge beyond what I have gleaned from articles and discussions on test mules.
    I do know that the EPA allows hand built cars to be used for the emission and fuel economy tests. It gives an edge in the rest results because time can be taken to make sure all the pieces are perfectly aligned, with things like panel gaps made as narrow as possible. The official reason is likely to allow the manufacturer to submit results for review well before model production and launch in order to not have the review process delay anything.
    So it is entirely possible for several test mules to be built. They also might need pieces of the car on hand for the final design of the production line.
    Felt likes this.
  4. DtEW
    DtEW Active Member
    242
    137
    SF Bay Area, CA
    Call me slow, but I just realized that the steering wheel from the 4th-gen pre-pro proto is directly off of the Mirai.
    It is probable that the dashtop & driving instruments architecture is much like that of the Mirai as well: bi-level across the entire cabin, with the upper level terminating and blending into the A-pillars. The lower level terminates and blends into the door trim. No part of the dash will obstruct the view out the side and forward/down.
    cmth and Sergiospl like this.
  5. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    Agree! share parts with next Gen IV, also looking at center display, Nav/Radio unit, Gen IV screen has the HVAC below the nav/radio unit.
    Mirai also has 153hp e-motor/253 ft-lb, will see!!!!.
    #5445 Sergiospl, Aug 13, 2015
  6. civicdriver06
    civicdriver06 Active Member
    797
    324
    Germany
    I think what we are seeing here is the Plug - in and not the regular Prius !
    There are fuel openings left and right !
    Also for a car which is going to be uncoverd in just about a month it seems to look quite uncompleted !
    What really worries me though is where is the colour in the instrument panel ?
    Don't tell me it's going to be monochrome once again !
    Looks so outdated!
  7. vinnie97
    vinnie97 Whatever Works
    1,430
    277
    Somewhere out there
    What an early mule if that's a plug-in, which supposedly won't be ready until at least the 2017 model. Hoping they've come to their senses...
  8. Sergiospl
    3,938
    1,351
    28
    well, you also don't want it to light up like a Christmas tree. I think it will share center display, head unit and steering wheel with Totota Mirai.
    #5448 Sergiospl, Aug 13, 2015
  9. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    O
    Well, how many years has Toyota been designing and manufacturing cars? 60 Years? I would imagine they have the process of design and manufacturing engineering, pre-production testing and so forth well under control.
  10. Felt
    Felt Senior Member
    1,624
    604
    Mountain West
    Could be. But this will be the first year for the new (can't recall the name) "standardized" platform. I'd suppose there is very little in common with last years design.
  11. bisco
    52,855
    why has no one drug up the '3rd generation coming!' thread, so we can compare stupid comments?
  12. Navigare
    Navigare Active Member
    312
    138
    Netherlands
    I wrote earlier that the shape of the new Prius looked like the small brother of the Mirai and indeed: the inside has also similarities...
  13. Tideland Prius
    16,680
    New chassis designs come around every 10 or so years so it's nothing new in that perspective. The difference now is greater platform sharing (which Toyota already has done... take the Camry chassis... in recent years, it has underpinned the Camry, Avalon, ES, Solara, Highlander, RX and Venza).
    Volkswagen in the late 90s/early 2000s has one platform that served as the basis for the New Beetle, Golf, Jetta AND Passat! (until the Passat's redesign in 2000 or 2001)
    Felt likes this.
  14. Navigare
    312
    138
    Netherlands
    Is the Mirai on the new platform (TNGA)?
  15. bisco
    52,855
    probably hand built in someone's garage.:cool:
    lensovet likes this.
  16. Navigare
    312
    138
    Netherlands
    Uncle Toyoda's garage....
  17. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    Great way to put pressure on CARB to build the stations.
  18. Navigare
    312
    138
    Netherlands
    What is CARB? I am just a dutchman...
  19. cyclopathic
    3,292
    547
    2014 Prius c
  20. Navigare
    312
    138
    Netherlands
    Ahhh, ok. Thanks.
    I don't disappear in real life, i keep coming here.
    The only times i am flying is on the German autobahn in the holidays. 165km/h max in my Prius Wagon.
Thread Status:
