4th generation coming 2015!
Discussion in 'Gen 4 Prius Main Forum' started by edmcohen, Nov 6, 2012.
Thread Status:
Not open for further replies.
  1. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    It has always been about screen size (from a guy with a 63" flatscreen at home and a 100" projection screen in the basement "theater". ;)
  2. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    Also, a bigger screen configured to split in 3, stereo, phone, Nav
  3. Sergiospl
    3,938
    1,351
    28
  4. Stevevee
    Stevevee Active Member
    821
    224
    Vermont
    Why don't they really shake up the market after all these years?
    Make it sexy and gorgeous, and make the Plug In standard! Step it up a few notches and lead. Goodness knows, Toyota has enough experience with both, plus a long time between upgrades.
    garglo likes this.
  5. Felt
    Felt Senior Member
    1,624
    604
    Mountain West
    A couple of thought:
    I suppose Toyota thought they did that with the 2010, and I think they did. It has been the leader in the hybrid market for years, and certainly since 2010..
    I also suspect that cost is a major factor. I don't know that a "sexy and gorgeous' exterior would cost that much more, but certainly more exotic battery chemistry does, along with many of the other improvements that PC writers are asking for. Specifically, suspension, insulation, deeper seats and performance.
    The Prius has been optimized to achieve the highest fuel efficiency possible at the lowest cost. Weight, aerodynamics, tire friction, ICE, motor/generators, are all components of the design to achieve that goal. Environmental impacts on any of the above, reduce the fuel efficiency, for example standing water on the road during and after a rain shower, or temperature variations.
    I have wondered why Toyota didn't just put, for example, the Camry battery in the Prius. The EV range would be increased, the ICE would run less, and fuel efficiency would improve. Obviously, there is more to the equation that that, I just am not sure what it is.
    If you can get away from the notion that it is ALL about maximum fuel efficiency, the Camry is a much more comfortable, quiet, luxurious land cruiser than the Prius, and the milage penalty is minimal. Don't get me wrong, I have really appreciated my Prius, but I am tired of hitting every road obstacle ( low clearance), as well as worrying about every hail storm (high strength, thin hood and roof).
  6. Navigare
    Navigare Active Member
    312
    138
    Netherlands
    #5526 Navigare, Aug 20, 2015
    orenji likes this.
  7. Navigare
    312
    138
    Netherlands
    I kind of like both. Especially the left one is indeed the "little brother of the Mirai".
  8. inferno
    inferno Senior Member
    1,072
    405
    But people don't like the Mirai design, and I thought Toyota said that Mirai and Prius' designs are separate?
    Also 40km/l = 94 mpg ~ 79 mpg US. So huh?
    And what? 70km/l for the PiP which is 164 mpg UK? I don't get it...a Plugin Hybrid can be measured in mpg but are they really saying that it's almost twice is efficient? And yet leaving out how many electric miles? We'll...whatever, all points go to 2.5 weeks.
  9. Navigare
    312
    138
    Netherlands
    "People don't like the Mirai design"? What people? Has there been a survey?
    orenji likes this.
  10. Trollbait
    12,830
    That's pretty much how European numbers for PHVs are figured.
  11. Tideland Prius
    16,681
    The green one looks the same but the blue one looks a bit flatter than the earlier one (see below). It certainly looks fairly aggressive. The green one, not so much.
  12. Sergiospl
    3,938
    1,351
    28
    So, this is the real thing then!... and this is PIP2 or Prius Prime expected next year?
  13. Mr_mpg
    Mr_mpg Junior Member
    39
    Michigan
    Is the below new information or further speculation?
    "The automaker has fitted the new Prius with a 1.8-liter four-cylinder engine, producing an output of 148 horsepower, which is automated to kick in when extra power is required. Otherwise, it’s one and only electric motor fitted on its front axle allows the vehicle to run for 25 miles and above on electric power throughout. The latest hybrid also offers an impressive 57.5 miles per gallon combined."
    Toyota Prius 2016 Expected To Battle The Chevy Volt
  14. goldfinger
    goldfinger Active Member
    535
    403
    Buffalo
    Yet another spy shot.
  15. bisco
    52,858
    that's one of the dumber articles i've read.
    Felt and Netcub like this.
  16. bisco
    52,858
  17. goldfinger
    535
    403
    Buffalo
    Mad Max's fuel gauge. (the original)
  18. vinnie97
    vinnie97 Whatever Works
    1,430
    277
    Somewhere out there
    Tech News became a little overzealous in trying to paint the Prius as a "me, too" Volt alternative.
    Joke thread until Sept. 8.
  19. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I assume you are talking about the Camry Hybrid. Ok, but there is a BIG penalty to pay in terms of practicality going with Camry Hybrid over a Prius: Yesterday, I brought home a brand new 16 ft. extension ladder IN THE PRIUS. That thing is 100 in. length. That would be completely impossible to put in a Camry hybrid. You'd need to strap it to the roof. Said it before, but a Camry Hybrid probably cannot carry a simple 8 ft piece of 2x4 lumber. That would blow.
    I wouldn't consider a midsize hybrid with trunk unless the trunk was essentially as big as a conventional and the rear seats folded down really well. But, that is asking too much.
  20. orenji
    orenji Senior Member
    5,887
    3,489
    How many people are going to place a 16ft ladder or a 2x4 in their car?
    Netcub likes this.
Thread Status:
