50+ club
Discussion in 'Chevrolet Volt' started by bajapat, Jun 21, 2012.
  1. bajapat
    bajapat Junior Member
    72
    southington ct
    The name says it all and a picture is worth a thousand words.
    From work to home with ac on.
    austingreen likes this.
  2. gwmort
    gwmort Active Member
    985
    211
    Delaware
    I'm jealous.
    My personal record at the moment is 47.8 miles, and to get that I had to hypermile (almost no use of the brake, lots of coasting down way before stops, really gradual acceleration, etc...). I've been meaning to make another attempt at 50 but haven't had an opportunity where I wouldn't be annoying other drivers.
    What was your average speed? I had thought peak efficiency was around 45 mph, but then I saw a video with one of the engineers saying theoretical most efficient speed is 35 mph.
  3. bajapat
    72
    southington ct
    60-65 rolling New England hills
  4. dbcassidy
    dbcassidy Toyota Hybrid Nation, 8 Million Strong
    1,581
    289
    Middlesex County, MA
    Let's see you repeat the above display in colder weather when you are running your heater.
    DBCassidy
  5. drinnovation
    drinnovation EREV for EVER!
    2,027
    586
    65
    CO
    Nice good going if that is your first "50".
    I get 50miles per charge most of the summer, before my recent trip I have 8 days in a row of 50 Estimated range in the morning and 55ish (actual 40-45, remaining 15-10). My recent trip, we had 4 adults, 8 pieces of luggage:
    and still we managed to get 57.23205 miles (as reported from voltstats.net). I was taking it easy as i really wanted to make it with no gas.. so mostly 65 on the highway. Unfortunately the charger we were going to was 61.27299 miles so I failed and used gas ;-( (I don't take picks on failure..)
  6. scottf200
    scottf200 Member
    220
    61
    Chicagoland
    Hit 52 a couple days ago with the temps in the low 90s and had A/C on the entire time (but in ECO). 2/3rds fan was set to Auto and 1/3rd fan was set to level 1. I regularly get 45 for 2/3rds of the year here in Chicagoland.
    haha, I didn't even take a picture because I didn't think it was impressive with so many others doing it.
  7. timtim2008
    timtim2008 Member
    203
    Alpharetta, GA
    so far only 48 in a single charge.
    but i get 47 in range all the time
  8. andi1111
    andi1111 Member
    270
    63
    EU
    2012 Chevy Volt
    Today, on a single charge :)
    It would have been 115km on a battery charge, but my gf wanted to take a pee at the petrol station right before the long descent. I had 3km left in the battery and I turned off the Ampera.
    When I turned it back on, the battery was gone and the previous battery range was added to the gasoline buffer :-(
    Almost all driving after the petrol station was on a battery, using the long descent's regenerative energy, so that should be counted to the battery range, however the car moved the remaining 3km of battery range to the gasoline range and displayed 0km left in the battery after I turned the car back on and all the distance was counted towards the gasoline range instead to battery range :-(
    That's why the gasoline range is 30+km with 0.2+ litres used. If I hadn't turned off the car, the battery range would be aprox 115km.
    And the map of the trip (the color represents the speed):
  9. andi1111
    andi1111 Member
    270
    63
    EU
    2012 Chevy Volt
    And this is my today's estimated range meter after having driven 3 kilometers:
  10. drinnovation
    2,027
    586
    65
    CO
    Starting the day with 50mile (80k) estiamted range always gives me a smile, even after nearly a year.
    I smile a lot.
    And btw.. after a tad of regen you could have stoped and restarted and the miles would have been CD. The battery level often drops after you shut it off (floating voltage measurements can be off a bit), but if you have enough charge and restart it will switch back to CD.
  11. andi1111
    andi1111 Member
    270
    63
    EU
    2012 Chevy Volt
    Thank you! That's good to know. To bad I didn't know it earlier or 25 more kilometers would have been added to the battery odometer.
    I'm itching to try that route once again :) I've got to make it on battery alone.
  12. gwmort
    985
    211
    Delaware
    Still not a member of the 50+ club, but I did just set a new personal record with my first 2000+ mile tank (2003.6 miles of 8.4 gallons [what was needed to fill it back up]).
    It did mean going the last 200 or so miles listening to the low fuel warning everyday. I probably could have made it another couple of days but I was getting really tired of it.
  13. drinnovation
    2,027
    586
    65
    CO
    Congrats on a decent tank. I realize your driving demands a lot more ICE usage than many volt owners.
    I've had 50+ all week -- its easier if you can do trips that are < 65mph (high 50s need < 40mph).
    Best tank for me was just over 4000miles, and like you I listened to the annoying chime for a while to break that limit.
    I was just at the margin so some days it would warn, others it would be quiet because the gas expanded with temps).
    Last weekend I did a pikes peak climb and ended the day with 81miles of EV (tought the ICE did the hard work climing the mountain, 39miles of regen on the way down was nice.
  14. gwmort
    985
    211
    Delaware
    Thanks. I know lots of people do way better than the numbers I got but I couldn't be more pleased.
    Driving on sunshine and loving every minute.
  15. andi1111
    andi1111 Member
    270
    63
    EU
    2012 Chevy Volt
    So far I have driven 1700km (1000+ miles) and consumed 5 litres (1+ gallon) of gas :)
  16. gwmort
    985
    211
    Delaware
    Thats great!
    I imagine your gas prices are significantly higher than ours too right? Must feel good.
  17. andi1111
    andi1111 Member
    270
    63
    EU
    2012 Chevy Volt
    Exactly! Gasoline costs 1.5 EUR / litre = 7.4 US$ / gallon and that's cheap for Europe. In neighbouring Italy, it costs 1.9 EUR / litre = 9.4 US$ / gallon.
    I'm still driving on gasoline from the dealer :)
