5000 mile indicator to change oil popping up
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by prius_10, Mar 31, 2011.
Thread Status:
Not open for further replies.
  1. prius_10
    prius_10 Junior Member
    US
    Anyone know how to get rid of this message? I was told by dealer it means it's time to rotate the tires. You can turn it off by reading the manual.
    I looked through the manual and maybe I am missing something. I can find the menu on the display button on the steering wheel, but nothing relating to this and it's hard to move around and looks like you could accidentally turn something on or off in there.
    Any ideas?
  2. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    There's a sticky on this, I believe in the maintenance sub-forum.
  3. prius_10
    US
    Thank you so much for the quick response stream. I found it in maintenance like you said
  4. Mendel Leisk
    38,254
    Check page 428 in the Owner's Manual:
    n
    After changing the engine oil (U.S.A. only)
    The oil change system should be reset. Perform the following steps:
    Turn the “POWER” switch OFF with the trip meter A shown.
    Turn the “POWER” switch ON with the MPH or km/h button
    held down.
    Keep pressing the button until the odometer indicates “000000” and
    the multi-information display indicates that the reset is complete.
  5. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Thread closed as problem solved and numerous other threads about the same thing.
Thread Status:
