5000 mile service -- some extra miles are OK?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by peter17319, Aug 27, 2012.
  1. peter17319
    peter17319 Junior Member
    Harrisburg, PA
    I just got my notification for the 5000 mile service. But at this time of year, it's very difficult for me to take any time off work. So by the time I take the car in, I could be as much as 300-400 miles over.
    It's not something I plan to do on a regular basis, but it's not the end of the world, right?
    FYI -- 2008 Prius, ~55,000 miles total.
  2. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    You'll be fine......u might notice a slight drop in mpg but no major harm will be done.
  3. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    Absolutely no problem the service interval in the UK and Europe is 10,000 miles for the same car.
  4. PriusCamper
    PriusCamper Senior Member
    13,420
    5,418
    Pacific Northwest, USA
    Use of full synthetic motor oil allows regular oil changes to be done half as often...
  5. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    When I had my gen2 I only used royal purple & went about 10k between oil changes
  6. peter17319
    Harrisburg, PA
    Would you hack the console to make the "Maintenance" light go away? Or did you let it stay there for 5000 miles?
  7. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I would reset it so that buy the 3rd time it came on I knew it was time to change it.
  8. PriusCamper
    13,420
    5,418
    It'd be cool to turn it off in a way that'd allow me to turn it back on once I sold the car to a new owner... Like a fuse or something? Or maybe I could wire in a switch if I ever have a reason to take the dashboard apart?
  9. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Why go through all that trouble when its so easy to reset it?
  10. AzWxGuy
    AzWxGuy Weather Guy
    1,078
    558
    Tucson, AZ
    2021 Prius
    1. With Prius on, make sure the main odometer reading is showing.
    2. Turn Prius off.
    3. Hold down the ODO TRIP (odometer) button, press the brake and the Power button to start the car.
    4. Wait until all the dashes clear and your odometer reading is displayed again.
    5. It will count down another 5000 miles before turning on again.
  11. PriusCamper
    13,420
    5,418
    yea... probably right... but if you add up all the time you spend resetting it every 5000 miles over the life of the car... That extra step adds up. Ideally, if I could change the value of how many miles before the light comes on, for example 10K for synthetic oil, I'd value it.
  12. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Dude that only takes about 5 secs....probably....times maybe 30 times. Thats 2 minutes over 8 years. :eek:
  13. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Why a slight drop in mileage?
  14. edthefox5
    10,096
    4,837
    Clearwater, Florida
  15. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Oil breaks down.......filter get less flow.....who knows. All I do know is that when it was time to change my oil, my MPGs were a lil less.
