50MPG from Chevy Cruze Diesel
Discussion in 'Diesels' started by Troy Heagy, Feb 6, 2017.
  1. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    Toyota just surpassed the 10,000,000 mark for hybrid sales.
    There have been a total of 34 models offered.
    Availability has reached 90 different countries.
    An affordable plug-in model is being rolled out in Japan, the United States, and Europe.
    The timing is terrible... for diesel.
  2. El Dobro
    El Dobro A Member
    7,088
    3,270
    One of the things TDI owners would tout would be the distance between fill-ups on a trip. I used to drive them and I can tell you there was no way my bladder was going to hold out that long. ;)
  3. Trollbait
    12,543
    Yeah, and neither can you buy a direct bio-based replacement from a certain chain of stations in California like you can for gasol.....no, wait, I got that backwards:p
    Coal rollers are idiots, but idiots aren't limited to driving diesels. It is likely the same of gasoline drivers have modified their cars to emit more pollution.
    We get to see how ultra low sulfur gasoline effects gas prices this year.
    With a lot less sulfur, I don't see how new diesel can smell like rotten eggs. Perhaps you were behind a gasser with a bad cat.
    The regen cycles are for the DPF and LNT, not SCR with urea. Direct injected gasoline cars and some port injected ones would need an exhaust filter if we applied the particle emission limits to them. If the manufacturers feel lean burn is needed to meet future fuel economy limits, LNTs will also appear of gassers, the first Insight had one.
    The city value would improve, but the highway wouldn't change much. The first Cruze diesel already made use of grill shutters for higher speeds. A diesel hybrid would likely cost too much for the segment.
    wxman and thatoneraccoon like this.
  4. ETC(SS)
    7,178
    *sigh!*........
    We'll see how it sells.
    Personally, small diesel cars in America continue to be a solution desperately seeking a problem to solve.
    Almost as efficient as a hybrid.
    Almost as clean as an ICE powered car.
    Almost as reliable as an ICE powered car.
    Almost as cheap as an ICE powered car.
    It's "almost" a viable solution to a non-existent problem.
    The funny thing is.....if you take off all of the stuff that makes a diesel almost as clean as an ICE powered car, they can actually be fairly reliable.....but the thing is that people never keep small passenger cars long enough or put enough miles on them to make the initial buy-in cost worth it.
    Passenger cars just don't go to the junkyard because the motor breaks all that often.
    The one brilliant thing about the VeeDubbaya kerfuffle is that most of the diesel fanboys have gone radio silent....leaving us with the dolts in ragged out 4x4 trucks and 20-year-old emissions grandfathered-in Mercedes to perpetuate the diesel stereotype.
    hill, telmo744 and bwilson4web like this.
  5. wxman
    wxman Active Member
    636
    231
    Tennessee
    You must have misread; the automatic is also 37 mpg combined (31 mpg is "city" mileage).
    Cruze Diesel Sedan Sets 52-MPG Benchmark
  6. Samprocat
    Samprocat Active Member
    491
    297
    Lincoln, NE
    Crude Oil is what make biggest revenue in many Countries...and People that have power will not stop from promoting this.....
    Clean way is in hands of people that care less ...but profits....
    .If you really have own one of this green diesel car's..you will be greatly disappointed on how much fuel really use and what it takes to repair this car's once they get old...not mention the cost of emission parts that will make you go nuts how they will charge to replace defective part....
  7. john1701a
    12,818
    5,303
    58
    The report source could be wrong, but it doesn't change the point. 37 mpg is not worthy of celebration.
  8. El Dobro
    El Dobro A Member
    7,088
    3,270
    ULSD has been in use around 10 years now. If you got a rotten egg smell out of today's diesel, something was wrong. The new fuel smells better than gasoline.
  9. bisco
    51,994
    when the ionique is available, the vdubbers will have a better place to go.
  10. Troy Heagy
    Troy Heagy Member
    1,218
    Spoken like someone still living in the year 2000. Your statement was true then, but not any more. Diesels are CLEANER than gasoline cars. They must meet the exact-same standards for hydrocarbon, NOx, and carbon monoxide pollution emissions (example: No more than 0.1 gram/mile).
    PLUS they have soot filters to capture the dirt. Gasoline cars just spit their soot/particulate matter into the air so they are actually more dirty.
    The Cruze Diesel is certified under EPA’s Tier 3 Bin 125 classification. I consider the "city" test to be fundamentally flawed (does not match real-world driving), so I ignore it. The highway MPG is 52. Stop-and-go driving will obviously be less.
    And no $2500 battery to replace like I did on both my Honda hybrids (and will eventually have to do with my Prius).
    #30 Troy Heagy, Feb 15, 2017
  11. john1701a
    12,818
    5,303
    58
    Plug-In hybrids are CLEANER than diesel cars.
    Prius Pete likes this.
  12. bisco
    51,994
    i know this has been debated to death, and it only matters to some people whether the epa puts their blessing on it or not.
    if i have to live in the past to avoid diesels, so be it.
    i prefer to see us moving toward renewables, and hybrids are a better bridge. they've already spawned phevs and some bevs.
    bwilson4web likes this.
  13. Troy Heagy
    Troy Heagy Member
    1,218
    Well no duh. You know what's even more-clean than a plug-in gasoline hybrid? A plug-in diesel hybrid. (1) electric mode (2) low CO,NOx,HC emissions (3) No evaporative emissions because diesel fuel does not evap. (4) Includes a soot filter that the gasoline hybrid lacks. (5) Has lower greenhouse gases because its MPG is around 80.
    They don't sell plugin diesel hybrids in backwards America, but they have them in progressive Europe. They need to start shipping them here.
  14. wxman
    wxman Active Member
    636
    231
    Tennessee
  15. bisco
    51,994
    uh, 'progressive europe' where they ignored the cheating diesels for years?
    raspy and Prius Pete like this.
  16. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    Real mixed, heh? Not all gasolines are alike (some DI, with more soot, other Port Injected)...
    Talking diesels...How do you think soot gets cleaned in the filters?...How much do you think a DPF costs?...
    You are way off reality of diesels, as expected for anyone outsider Europe. But here we have a LOT of diesels, and their constant regenerations cycles (smoking blue/black), shaky start-ups, and horror stories of repairs, if repairing is enough to bring the car to a "as-new" emission state.
    Some of us have been giving you information enough, if we keep being ignored, you'll lose credibility.
    Just sharing (same engine): average fuel consumption of the equivalent car in Europe, Opel Astra
    Dieselverbrauch: Opel - Astra - Spritmonitor.de
    (5.83l/100km=40.3MPG=155gCO2/km)
    #36 telmo744, Feb 15, 2017
  17. Troy Heagy
    Troy Heagy Member
    1,218
    All gasoline cars make soot. But they don't get filtered, so the soot is just ejected into the atmosphere. I hear the EU wants to mandate filters for gasoline cars too, which I think would be good.
    I already have a diesel car, and love it. It's 13 years old and still no Hybrid battery to replace, so I saved $2500. :) Nothing else has broken either. Well that's not quite true. It's a Cheatwagen with typical VW build quality (crap) so the radio knob fell-off, and the window button stopped working, but that didn't affect the usability of the car... it still gets me to work.
    As for pollution controls, I'm very familiar with the "regen" cycle. Both my Honda Insight and Civic have the same thing to empty their NOx container. It burns more fuel, but only for 3 seconds, and then goes back to normal.
    That one guy is getting 112 MPG-US! I'd be happy with that. The average appears to be 40 mpg which is not bad at all. That's higher than the "combined rating" on the EPA sticker. I'm 100% highway, which is why my numbers are so high (see below). I expect to get high numbers in the Cruze too.
  18. john1701a
    12,818
    5,303
    58
    Same old rhetoric as back in 2000.
  19. Samprocat
    491
    297
    Lincoln, NE
    Then when you update your wheels to Urea operated emission ....you will see that if you have proper to watch passive.....
    Active....
    Stationary Regen
    Once you hit about 3.65 parts per million soot or triggered by Cat back pressure
    You will see that this happens for 20-40 minute and heat is controlled from 1180-1400 Fahrenheit.....
    And as emission components get older this cycle happen on a lot shorter bases....
    So all improvements in today's diesel engines are waisted on regen cycle...
    I can write really technical
    Why?
    How?
    Let me just say that applied technology for near zero emission to Diesel Engines are robbing power efficiency and MPG
    Once there is Another way to keep Cat at constant 1100 +/- Fahrenheit
    And this type of emission Cat filters are at least 3-7 year's away.....
  20. hill
    8,812
    not just fail emission standards, crash test standards too.
    but why is there such a difference between its 6 speed & 9 speed trannies -
    EPA Rates 2017 Chevrolet Cruze Diesel 37 MPG Combined
    Either way - the combined epa on both trannies, is 37epa combined.
    That's not too bad ... i guess. Sure, maintenance costs are higher but still, it's not too bad.
    City driving 31epa. Again. Not TOO bad. I guess.
