50MPG from Chevy Cruze Diesel
Discussion in 'Diesels' started by Troy Heagy, Feb 6, 2017.
  1. bwilson4web
    16,218
    Good point! I was briefly thinking of finding out what Macintosh he has and after an Ebay survey, make an offer.
  2. Troy Heagy
    Troy Heagy Member
    1,218
    I used my window. From the 120 volt plug, to the window, and into my Battery charger. The manager did come over & ask, "Having car problems?" and I just said, "Yeah unfortunately. The battery's dead," and then she walked off.
    If I owned a Tesla and was not within range of a supercharger (basically impossible because they are spaced at 150 mile intervals), then I'd find a hotel & charge off their 120 volt outlet overnight. It's slow but works.
    Okay now I'm curious. I'm looking at "Troy Heagy" and I don't see a ban marker. As far as I know the old account points to [email protected] where I no longer work, so it's inaccessible.
  3. Rmay635703
    Rmay635703 Senior Member
    2,669
    1,688
    Somewhere in Wisconsin
    2013 Chevy Volt
    Overnight 110vac gets you 40-60 miles depending on how late no your overnight is
  4. mikefocke
    4,001
    1,807
    Sanford, NC
    Since this is about diesels, check out the diesel price premium at your local gas station. I noted a 32% price premium at one station I gassed at today.
  5. bisco
    51,961
    i saw about 40 cent premium here in orlando.
  6. fuzzy1
    10,458
    Do note that if we shouldn't compare gasoline vs diesel MPGs directly, due to their differing energy content, then neither should we directly compare their per-gallon prices. Some adjustment is called for.
    If priced based on energy content (yes, I know, there are myriad other factors), diesel ought to be priced roughly 15% higher per gallon.
    #126 fuzzy1, Feb 27, 2017
  7. bisco
    51,961
    but it takes away the mpg advantage to some extent.
  8. Trollbait
    12,543
    Depends on region. Diesel is the same or a little lower in L.A. for example
    MPGe can be used for this.
