55K - Injector + Mass Air Flow Service
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by jjtrindc, Nov 1, 2017.
  1. jjtrindc
    jjtrindc Junior Member
    Falls Church, Virginia
    2013 Prius v wagon
    About to take my Prius V into the dealer for an oil change. Overall everything seems to be running fine and no noticeable issues. When I had my car in at 50K they recommended the following three services:
    Toyota Injector Service
    AC Vent Service
    Now I understand Vent Service is the cabin filter. I can likely do that myself.
    In reading these forums, I get the sense that sticking with good gas and using Injector cleaner is enough if I'm not seeing any issues.
    Similarly, the Mass Air Flow Sensor is best protected by replacing the Air Filter regularly, but doesn't need cleaning unless the check engine light comes on.
    Please correct me if I'm wrong here. Doing my best to interpret from these forums with limited knowledge of the inner workings of these kinds of services.
    Anything I should be considering after hitting the 50K mark?
    Thanks!
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,918
    4,680
    Texas Hill Country
    Do the cabin filter and call it good unless the dealer can a) show you where it is in the maintenance schedule or b) if they can demonstrate performance or mileage problems. In reality the Warranty and Maintenance manual in your glovebox shows no major work until 100 k miles other than oil changes and air/cabin/oil filters. The rest makes the dealers owner happier than he already is... 4D83D07C-14F2-40E6-9F54-E064DB1A9DD2.png
    #2 rjparker, Nov 1, 2017
  3. Mendel Leisk
    38,651
    I'm not sure about that. Maybe they're meaning the AC passage cleaning, which is something to consider only if you're using the AC frequently, and it's smelling funky. A good preventative maintenance for that is:
    1. Use AC sparingly. Consider old school, shutting it down and cracking the windows for example.
    2. Run the vent system without AC for the last mile or two, with a decent fan speed, to get the humidity out.
    And regarding the Air Filter, for sure just replace it yourself. And, don't replace it till it's really warranted, forget the schedule, just check on it's condition.
    Toyota Injector Service I would pass, without hesitation.
    Mass Air Flow Sensor cleaning: something to do once or twice in the vehicle's lifetime. Get the correct spray (it'll say Mass Air Flow Sensor cleaner), watch a Youtube or two on how to use it. Very simple.
    I got a can of that stuff recently, did a cleaning. And bonus, I FINALLY got the volume control on our receiver's remote working properly, isopropyl alcohol had lackluster, short term results. The MAF cleaner was the naz!
  4. mikefocke
    3,692
    1,644
    Sanford, NC
    They are just trying to sell expensive chemical cleaners.
    Dealers frequently have a maintenance schedule different from that of the car manufacturer. Proactive yes. Profit filled, you bet.
  5. bisco
    49,387
    1) no
    2) no
    3) no
    Prodigyplace likes this.
  6. Air_Boss
    Air_Boss Senior Member
    3,940
    1,078
    New Yawk
    "Recommended" services outside of the manufacturer's maintenance schedule generally fall into the category of "customer wallet cleansing".
