55w HID Xenon Conversion Kit - H11
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Noodleho, Sep 18, 2014.
  1. Noodleho
    Noodleho Junior Member
    32
    Sacramento
    I am waiting on my 55w HID Xenon Conversion Kit - H11 to arrive. It is pretty much plug n play, but does anyone know how to connect the relay (come with the kit)? Hybrid is new to me...
  2. mrbigh
    3,686
    699
    Long Island, NY
    Instruction should be posted on their website...
    Noodleho likes this.
  3. katiesdad7
    katiesdad7 Member
    172
    25
    Stuart, FL
    No relay should be required. Your normal bulb is 55 watts so why a relay?
  4. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    The operating power is 55w, but the ballasts can draw more than that upon startup/igniting the HID bulbs.
    SCH-I535
    sfv41901 and Noodleho like this.
  5. Noodleho
    32
    Sacramento
    will the HID lights flicker if no relay is install...
  6. xliderider
    8,140
    3,280
    Honolulu, HI
    If you experience any problems, it's usually a failure to ignite. Flickering is caused by a bad ground connection or a failing bulb.
    If you want to use the relay, attach the wire that goes normally to the battery to one of the open terminals in the rear of your engine fuse box. Here, it is the terminals with the red wires. Use a standard 1/4 inch push on type terminal:
    SCH-I535
  7. Noodleho
    32
    Sacramento
    Thanks, that is what I need pic and instruction.
  8. varun singh
    varun singh Member
    113
    Wayzata
    I just finished installing my 55w morimoto kit. For time being I just have zip tied the relay behind the driver side headlight.
    Where did you put your relay ?, I would appreciate a picture of relay mounted.
  9. Noodleho
    32
    Sacramento
    I should get my HID in a few days, then I will decide where to mount the relay...
  10. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    Been using 55w HID for 140,000 kms with no relay and no problems.
  11. Squirt
    Squirt Member
    204
    47
    Los Angeles
    2014 Prius Plug-in
    +1 for relay not being necessary. I have a 55w kit as well. No flickering, no fuss, no aftermarket relay. Plug and play.
    +1
  12. Noodleho
    32
    Sacramento
    Thx for your feedbacks. I am trying to install it in couple of days, let you know...
  13. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    let's say it like this: a relay for sure doesn't do ne harm, but gives quite a lot of peace of mind /
    BION
  14. Noodleho
    32
    Sacramento
    You are definitely right!
  15. Feri
    Feri Active Member
    761
    144
    Relay provides an extra layer of non OEM wiring where things can go wrong.
