57 mpg! can't believe it!
Discussion in 'Gen 3 Prius Fuel Economy' started by kensiko, Jul 22, 2013.
  1. kensiko
    kensiko Member
    260
    58
    Qc, Canada
    2014 Tesla Model S
    I did 57 mpg on my last tank, at least 80% on roads / highways, in a hilly region and including 40km with a trailer! My gas consumption is constantly decreasing!
    Really satisfied![​IMG]
    jgilliam1955 likes this.
  2. xamnosidda
    xamnosidda Junior Member
    61
    Celebration, FL
    Nice job. I've had work commutes (37 miles) where I've averaged 62-63 mpg but my best tank ever (over two years) was 54. Can't complain about that though. My Xterra only got 15 mpg.
    Also, I've never had a tank cost more than $35 in the past two years either.
    49,490
  4. bnom31
    bnom31 New Member
    Nice! Mine has gone up as well with the nicer weather, although I can't stop myself from using Power Mode and driving like a normal car (no gas saving technique)... but I still manage 52mpg on my daily commute!
    Cjeigh likes this.
  5. kensiko
    kensiko Member
    260
    58
    Qc, Canada
    2014 Tesla Model S
  6. arnesto
    arnesto Junior Member
    24
    San Diego
    Is that in Imperial gallons or US gallons ( around a 20% difference)
  7. ChipL
    ChipL Active Member
    585
    85
    Reston, Va
    Congrats! Have hit 57mpg's or better 7 times so far in 37 fill ups. The Prius makes it easy to drive a lot more. Day trips to the shore or mountains are no problem now.
  8. kensiko
    kensiko Member
    260
    58
    Qc, Canada
    2014 Tesla Model S
    US
  9. Drdiesel
    Drdiesel Active Member
    585
    152
    Monterey CA
    My best so far has been 58.9 MPG on a tank :eek: I rechecked 3 times before I could believe it :ROFLMAO:
    Cjeigh and ChipL like this.
  10. kensiko
    kensiko Member
    260
    58
    Qc, Canada
    2014 Tesla Model S
    It dropped a lot with the decrease of temperature, don't know if everything is still OK. I suspect I may have a bearing getting old, I hear a noise when on smooth new asphalt, the noise is the same with the winter tires I just installed.
  11. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    Definitely temperature and tires will impact your fuel efficiency. Weather as well. Wind, rain, cold, standing water, snow, ice, non low rolling resistance tires, decreased tire pressures, cooler battery temperatures all conspire to lower your overall fuel efficiency. However, when the weather warms and dries up, the MPG's return (like migratory birds).
    What you are seeing is normal. There are things you can do to limit the decline, but not eliminate it. Still, 48 mpg as your lowest tank isn't too shabby, now is it?
    Cjeigh and retired4999 like this.
  12. kensiko
    kensiko Member
    260
    58
    Qc, Canada
    2014 Tesla Model S
    Hehe, but now it's around 0 degrees C, we will see how it goes when it's -30 C.
  13. Codyroo
    1,826
    515
    Pleasanton, Ca
    You are a prime candidate for grill blocking your lower grill. It will speed up engine warmup times and reduce cool down (especially when you are running the heater).
  14. kensiko
    kensiko Member
    260
    58
    Qc, Canada
    2014 Tesla Model S
    Interesting idea, I may try it if it's not too long to install.
  15. Les_PL
    Les_PL Active Member
    317
    248
    Gdynia, PL
    Altogether not more than 10-15 minutes by yourself for the first time.
    Next year with the foam insulation pipes already cut from previous season - 4 minutes :)
    Codyroo likes this.
  16. Codyroo
    1,826
    515
    Pleasanton, Ca
    Get some pipe insulation, cut to appropriate lengths, cut some vertical slits in the "seam" side so the insulation can slide between the vertical support bars on the lower grill, push into place. I found that I could get 3 pieces (1/2"?) wedged in there with no need for twist ties. The upper portion of one insulation wedged into the lower portion of the piece above it. Kept the whole thing in place. Worked a treat! I need to get it back in place this weekend, as our low temps are coming back, and I like getting the heater on sooner rather than later. And without twist ties, it is easy to remove when washing the car or if the weather warms up.
