5k Gen 3 Prime — Milky oil
Discussion in 'Gen 5 Prius Main Forum' started by Rafsdhc6, Feb 4, 2024.
  1. Paul Gregory
    Paul Gregory Senior Member
    2,154
    566
    Alberta
    2024 Prius Prime
    XSE
    That sounds like trouble to me. Condensation would never raise the oil level that much.
  2. Rafsdhc6
    Rafsdhc6 Junior Member
    17
    Ontario
    2023 Prius Prime
    XSE
    It’s about 2 inches. I tried uploading pics but error. It looks very similar to the pic in TSB about what looks like the same problem.
    https://static.nhtsa.gov/odi/tsbs/2021/MC-10206528-9999.pdf
  3. douglasjre
    douglasjre Senior Member
    2,181
    719
    Null, NL
    What do you mean by "blame it on them?"
  4. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    AND, oil should be checked warm, about 5 minutes after stopping engine after getting the engine oil to full operating temp. IMO, 7 miles driving with ICE is not sufficient to get oil to full operating temp. You wait 5 minutes after shutdown to allow the warm oil to settle back in the pan. Obviously you pull the stick out, wipe it off and then re-insert all the way down and pull out again for the reading.
    Also, you never want to see oil above the MAX mark. In the hybrid Prius, the spec is 4.4 qts with filter change, but I only ever fill with 4.0 qts. This leaves me about the middle between MIN and MAX lines.
  5. Zeromus
    Zeromus Active Member
    553
    307
    Ottawa Canada
    2024 Prius Prime
    SE
    Always leave it at the middle when cold and you fill 4q, then run the engine to temp, and then check the levels. If you want to top off at that point yeah.
    I think with the level being high, and the milky appearance, maybe the ICE isn't running long enough and it's slightly overfilled which means it will take longer to boil off condensation too?
    That or OP is super unlucky and got a coolant leak super early in the car's life. It's unlikely but it is *possible* if he's got bad luck.
    In the winter I think it's probably good practice to run the engine for a longer 25km+ drive once a week anyway. And most of us can probably do that on a commute
    Also, it can't hurt to run the defrost and idle the engine for 5 minutes if you have a shorter drive to start the day out, or on the way home in winter. Alternatively the thing isn't a monster car but it does have 220HP and isn't a complete slouch, so let it live a little every once in a while. That will probably help too.
  6. Trollbait
    12,543
    Because the heat pump allows the car to run more without the engine, and that is what most want, or think they want.
  7. Zeromus
    553
    307
    Ottawa Canada
    2024 Prius Prime
    SE
    It would be nice if Toyota tracked how often the engine ran, and in what conditions and had a sensor to watch oil quality and then give a little notice to the driver that its running in HV mode for engine maintenance reasons.
    The issue honestly probably comes from people not understanding the impacts of an engine never running, or running very rarely. They may get that this is an issue in a traditional ICE vehicle, and driving often enough self-solves that without much thought. But in a PHEV they *are* driving often, and not connecting the dots for EV mode meaning the engine does sit unused for long periods of time.
  8. Paul Gregory
    2,154
    566
    Alberta
    2024 Prius Prime
    XSE
    If you've got 2" of water in your oil pan, it's obvious you've been driving it that way already, so it probably won't hurt the engine much if you drive it to the dealer. Running the engine creates an emulsion, which looks milky, but still provides lubrication.
    douglasjre likes this.
  9. Rafsdhc6
    17
    Ontario
    2023 Prius Prime
    XSE
    The car came back from my dealer with a clean bill of health. Like everyone says, the engine is not run enough so from now on I’ll be keeping it in HV mode below freezing and even in CHG mode on shorter runs. It looks like they added a detergent and went on a hard joy ride (judging by app drive history) came back and changed the oil. Dude giving back my keys said it handles like an old GTI, lol.
  10. bisco
    51,955
    having blown the engine on my 2012 plug in due to years of engine going through warm up cycle then shutting down and driving ev, i think it's the worst part of the plug in hybrid design.
    DOHCtor likes this.
  11. Preebee
    Preebee Senior Member
    867
    771
    Midwest
    2023 Prius
    W.t.f. :cautious:
    daisy555 likes this.
  12. Rafsdhc6
    17
    Ontario
    2023 Prius Prime
    XSE
    I agree, this car is not for non car/tech people. You always have to judge and balance variables for either efficiency or longevity. Especially in 4 season climates. It’s probably best to stick to plain hybrid or a full EV if you just want to jump in and drive.
    vvillovv and bisco like this.
  13. Leadfoot J. McCoalroller
    8,088
    7,569
    Pennsylvania
    2018 Prius c
    Seems like most of the problems are related to short trips & limited usage.
    Hybrids (and PHEVs in particular) have always been at a disadvantage in terms of providing full value to drivers who operate less than 15,000 miles/24,000kms per year.
    Trollbait likes this.
  14. Zeromus
    553
    307
    Ottawa Canada
    2024 Prius Prime
    SE
    Is the financial break point 24k? I feel like its a lot lower when we ran our numbers. But in Canada there's also a 5k rebate on the car. which represents 12% the cost of the vehicle before taxes. Maybe 10% after tax of the MSRP (not including PDI etc).
  15. bisco
    51,955
    It depends on your cost of gas and electricity
  16. Leadfoot J. McCoalroller
    8,088
    7,569
    Pennsylvania
    2018 Prius c
    It's not just a single breakpoint; it's going to be a little different for every case and it will absolutely change with energy prices.
    But I would suggest that at recent average fuel costs, 15k miles / 24k kms per year is right about where any hybrid can save money vs. a cheaper/simpler gas-only car.
    When it's a PHEV, the math gets weirder, and even more savings are possible... but again, the extra cost of such a car over a basic hybrid means that you aren't going get to those savings without a lot of utilization.
  17. Mendel Leisk
    41,469
    Too, if a Prius plug-in battery ever needs replacing, vs regular Prius hybrid battery, it's a lot pricier. To be fair, don't recall ever hearing of o Prius plug-in battery replacement being needed,d at least not here.
  18. Gokhan
    Gokhan Senior Member
    6,218
    2,465
    Paramount CA
    You need to do regular fifteen-plus-mile HEV trips with the Prius Prime (or Prius) to keep the engine in good working order. The engine won't warm up unless it is driven over fifteen miles.
  19. Jabog6
    Jabog6 Junior Member
    32
    16
    CT
    2024 Prius Prime
    SE
    I don't have any data on this either, but I would hope that a prime battery would last longer than a HEV battery, due to much less of a charge / discharge cycle relative to a regular HEV (as a % of battery capacity).
  20. bisco
    51,955
    at 11 years old, the battery was the best part of my plug in.
    daisy555 and Mendel Leisk like this.
