5th gen prius 0w8 vs 0w16 discrepancies
Discussion in 'Gen 5 Prius Technical Discussion' started by 2023p, Dec 23, 2025.
Tags:
  1. 2023p
    2023p Active Member
    165
    107
    Here
    2023 Prius
    I hear you and can see where the confusion (my errors and Toyotas show regarding all this) or misunderstanding is rooted.
    the 5th gen prius (engine) was engineered/designed for 0w8 oil. it also left the manufacturing plants filled with 0w8 oil.
    when i initially said other regions called for 0w8, i was referring to the factory fill engineering standard used at the plant in Japan.
    however, when looking at the printed manuals themselves (the physical books in the glovebox), you are correct: Toyota of Europe and Toyota UK, Japan also listed 0W-16 for the earlier runs.
    with that Even in Toyota's home market, the nationwide infrastructure for 0W-8 (JASO GLV-1) was not fully "universal" across every small-town service center at the exact moment of the 2023 launch.
    To ensure no owner was left without a service option, Toyota Japan printed 0W-16 in the manual—even though the engine designers had already finalized the car for 0W-8. They did the same thing NA did initially, it looks like.
    this is where the "lie/hedge/misinformation" becomes obvious. on many of those early 2023 Japanese units:
    the owner's manual said 0w16
    the oil fill cap on the engine said 0w8
    the radiator support sticker said 0w8
    this shows that the manufacturing plant in japan was building a 0w8 car, but the documentation department was still playing it safe with 0w16.
    what a country or region decides and then updated environmentally/certification wise and how a car manufacture navigates that is one thing.
    what this car and this engine are and were designed and manufactured specifically for oil wise, is another.
    that's the end of it for me.
    the roots and the fruit have been made clear, for me. the bruises and imperfections of finding clarity on it is par for the course. pretty simple.
    enjoy!
  2. KMO
    KMO Senior Member
    2,029
    751
    Finland
    2023 Prius Prime
    I know you really want to win your argument about it being okay to put 0W-8 in the car.
    And it's probably true that it is okay - that was widely surmised when the Prius first came out, given that other models with M20A-FXS were already specced for 0W-8, and it's even more likely now that they've changed to 0W-8 for the Prius since July 2025, with no obvious design changes, aside from the oil level sensor removal, which could be coincidental.
    But that's no reason to keep making stuff up. You've got a reasonable claim based on the engine type, but it doesn't help your credibility to invent things about the Prius production.
    The manuals and labelling for Japanese and European cars all said 0W-16. There's no evidence of 0W-8 ever being part of Prius production until July 2025 (aligned with the US 2026 model year).
    I know about the European labels myself, having one, and I just spent some time browsing Japanese YouTube for a shot, here:
    And sure, maybe the car could have been filled at 0W-8 at the plant, despite all documentation and on-car labelling saying 0W-16, but there's no evidence for that. It could also have been filled with 5W-30, right?
    The pre-2025 English and Japanese manuals do specifically say, "SAE 0W-16 is filled into your Toyota vehicle at manufacturing" (and "0W-16 は、新車時に工場充填されている推奨オイルであり"), so you're making a claim that the documentation is actually false, with no evidence.
    Personally, if I had to guess, I'd say that they were being cautious about the use of 0W-8 in PHEVs - they may not have had enough experience with it to see if it coped with the sort of short cycles it might get, so they wanted to stick with the 0W-16 they had more experience with, at least for the PHEV. And then to simplify the Prius production, both HEV and PHEV got the 0W-16, rather than using different oils for the two variants on the line. And then few years later they'd managed to do enough testing with 0W-8 to be happy with it.
    #22 KMO, Dec 31, 2025
    2023p and Mendel Leisk like this.
  3. KMO
    KMO Senior Member
    2,029
    751
    Finland
    2023 Prius Prime
    Above pic was from here, btw. A two-and-a-half hour review video :confused:
    2023p and VelvetFoot like this.
  4. 2023p
    2023p Active Member
    165
    107
    Here
    2023 Prius
    Weird. The cynicism and presumption you seem to be projecting is... strange. Truth and facts don't need affirmation. They aren't an argument, they are not up for debate.They remain true no matter what anyone does, feels, presumes or thinks.
    Win? Such a curious lens to approach discourse and reality with. I hope you continue to feel like a winner. Enjoy!
    SAE 2020-01-1425, where Toyota engineers specifically developed 0W-8 for the M20A engine family years before the 5th Gen Prius was even revealed. To cite a manual as proof of engineering intent is a logical fallacy; manuals are marketing and service documents, not blueprints. The physical bearing clearances of the M20A-FXS remain constant globally, yet the oil recommendation changes by region. That isn't 'caution' ... that's a supply chain compromise
    In plain English, the 0W-16 oil recommended in your 2023 manual lacks the specific chemistry Toyota's engineers designed to protect the M20A's tight clearances. By using 0W-16, you are essentially using "yesterday's tech" in "tomorrow's engine."
    In short, it's not just okay to use. The engine was engineered for and filled with 0w8 in Japan. Nothing you or I say, presume, feel will change that.
    Perhaps once Toyota is forced to correct their mistakes/choices on this you'll understand better.
    Thanks, and please keep your argumentative approach focused on people that want to argue with you.
    Otherwise, you're just harassing people.
    I'm not arguing with you or anyone else, I shared reality, truth and facts, albeit with human imperfection. Truth doesn't need to win. Winning doesn't define truth. Someone can feel like they win or that it's a game and still be wrong. Hence, truth.
    This will be my last response to you.
    Physics and facts, not feelings and gaps.
    Please just stop. ♥️
    Gokhan likes this.
  5. 2023p
    2023p Active Member
    165
    107
    Here
    2023 Prius
    Respectfully, for or anyone truly and solely interested in the actual discrepancies and the ultimate point:
    Observation bias won't change the engineering reality.
    Manufacturing labels and manuals are legal and logistical documents... they are designed to reflect what a company can support in a specific market at a specific time.
    They are not engineering blueprints.
    The physical clearances in the M20A-FXS don't change because of a sticker or a regional print run.
    Toyota is already in the process of aligning their global guidance for this engine as infrastructure catches up. You'll see.
    Not here to 'win' a debate or convince anyone to change their oil.. Here to ensure the full context is on the record for 2023 (etc) owners.
    Enjoy the car!
    PrimeDan likes this.
  6. Gokhan
    Gokhan Senior Member
    6,714
    2,672
    Paramount CA
    Regarding protection, chances are that you get a marginally better wear protection when you go to higher viscosities, as it increases the oil-film thickness. In particular, base-oil viscosity determines the protection in the valvetrain and parts of the cylinder rings. So, technically, you could see better and better wear protection when you go from 0W-8 to 0W-16 to 0W-20 to 5W-30.
    However, chances are that you won’t see much difference unless you are driving very fast. In fact, Toyota recommends using higher viscosities in the owner’s manual if you drive/accelerate fast.
    One nice thing about using the lowest recommended viscosity is that the oil is thinner when it is colder, which improves cold-engine fuel economy significantly. I don’t like pushing the engine to its limits when the oil is still too thick, as it could lead to air gaps (foaming/aeration) in the oil when the rpm is too high and the oil is too thick to flow.
    Regarding performance upgrades, ILSAC/API upgrade their specs roughly every five years. It is currently API SQ/ILSAC GF-7A/B, which came out in March 2025. The previous update was in 2020. I don’t know if TGMO 0W-16 has been updated to API SQ/ILSAC GF-7B yet.
    0W-8 is still not part of ILSAC/API but JASO. The new SQ/GF-7 additive package is actually better than the JASO GLV-1 additive package, which is because JASO GLV-1 was introduced earlier. However, JASO GLV-2 was introduced recently, and it should be comparable in protection to API SQ/ILSAC GF-7. I see that the 2026 Prius HEV/PHEV still specs the inferior JASO GLV-1; so, the GLV-2 update has nothing to do with the mid-cycle oil-recommendation change. I don’t know if the American TGMO 0W-8, which is made by ExxonMobil, has been updated to JASO GLV-2 yet.
    2023p likes this.
  7. Gokhan
    6,714
    2,672
    Paramount CA
    Actually, after reading the link I gave for the new JASO GLV-2 spec, it is a more watered-down 0W-8 that prioritizes fuel economy more at the cost of wear protection and oil consumption. What they did was that they further lowered the base-oil viscosity, which further compromises wear protection as I explained in my previous post, and added more viscosity-index improver (VII) polymers to have a more “flat” viscosity behavior so that the viscosity is less dependent on the temperature (meaning a higher viscosity index VII). While this sounds good to the ear, it compromises wear protection. It also compromises oil consumption as the base oil is further thinner now. To get around the volatility specs, they introduced a new volatility test instead of the well-established Noack volatility, which reduces the test temperature from 250 ℃ to 150 ℃. I am guessing the Noack volatility of JASO GLV-2 oils could be as high as 20%.
    So, use the new JASO GLV-2 SAE 0W-8 oils at your own risk. LOL
    2023p likes this.
  8. KMO
    KMO Senior Member
    2,029
    751
    Finland
    2023 Prius Prime
    Missed the above due to Christmas.
    Yes, the M20A engine was designed for 0W-8 oil, we all know that.
    The OP has filled the thread with paragraphs of true statements about the M20A engine, and false statements or hallucinations about the Prius.
    Most of the technical claims in the last two posts are true - the stuff about the M20A.
    This statement is misleading:
    The recommendation for the Prius does not change by region. 0W-16 initially globally, 0W-8 from July 2025 globally.
    It's possible that the recommendation for other cars changed by region, in the 2021-2022 period. I think this was the case with some Corollas? I believe there were supply chain issues meaning Toyota US were advising 0W-16 while other countries were filling the same cars with 0W-8.
    But that's not the case for the Prius - it used 0W-16 globally.
    I've seen no evidence that Toyota's claims to have filled the Prius with 0W-16 in initial production are wrong. The engine was engineered for it, yes, but engines don't come pre-filled with oil - they're fitted to a specific car and filled on its production line.
    On the evidence I can see, it's more plausible that the Prius line filled M20A engines with 0W-16, for some reason, than that they let tens of thousands of cars go down the line with mismatching on-car plaques and incorrect manuals. That's not the Japanese level of attention to detail!
    It would be very interesting to find out why they decided the Prius should use 0W-16, despite other cars with the M20A using 0W-8. (My guess above was that it was a PHEV thing, but that's just a guess).
    It would be even more interesting to find out that the OP is right and the Prius was filled with 0W-8 and all the documentation was wrong, and the July 2025 change was just a quiet manual correction. This is possible, if unlikely. (If the OP actually knows this from a source, it would have saved time to post it. Extraordinary claims do require evidence.)
    And it would be interesting to see if there was a retroactive notification to use 0W-8 on 2023-2025 Priuses in future. That seems perfectly possible.
    Now, I've gone through the thread one more time, looking for any actual evidence, and the only thing I can find that might be something is the reference to "T-TT-0692-23. This is the internal Toyota memo that tells technicians 0W-8 is the "new" standard for these engines."
    I can't find this document publicly - maybe someone can show it? My current guess is that it's about other cars with the M20A engine, not the Prius. I think it must be something issued in 2023 saying that Corolla Hybrids and other M20A cars that were filled with 0W-8 at the factory and recommended for 0W-8 outside the US should now be filled with 0W-8 inside the US.
    In which case not relevant to the Prius's global 0W-16 fill and recommendation from 2023-2025, which was dictated by Japan, and was hence nothing to do with Toyota US's already-obsolete 0W-8 supply reticence.
    All of this is a bit of pointless argument - I'm sure it's absolutely fine to use either 0W-8 or 0W-16 in a 5G Prius, and I bet any difference is barely perceptible. I would agree totally with the statement 'By using 0W-16, you are essentially using "yesterday's tech" in "tomorrow's engine."'
    But I'm not going to let statements of fact about something concrete like Toyota's production and recommendations go past if they're false (or at least extraordinary and unevidenced).
    #28 KMO, Jan 18, 2026
    2023p likes this.
  9. KMO
    KMO Senior Member
    2,029
    751
    Finland
    2023 Prius Prime
    Actually, I've just noticed the ambiguous wording on this quote:
    It's similar to the previous misleading quote, but I didn't parse this one carefully enough.
    I thought OP was restating the claim about the Prius being filled, but I think it's now a new true general statement about "the engine" - meaning M20A in general rather than the engine in the Prius. Certainly many M20A engines were filled with 0W-8 in Japan.
    Reading very carefully, I think maybe OP has conceded that the Prius wasn't filled with 0W-8, but tried to hide it in noise about the M20A generally.
  10. Gokhan
    6,714
    2,672
    Paramount CA
    This is actually simply false. The engines come prefilled with oil from the engine factory. They are not filled with oil during final assembly.
    How do I know? I wasn't sure what oil they had put in the factory when my new 2009 Barcelona Red Metallic Corolla XLE was manufactured in early 2008. Toyota had recently switched to 0W-20, but there was an ambiguity. So, I called the GM/Toyota NUMMI assembly plant, which is now the Tesla factory. They were very friendly, verified that it was 0W-20, and told me the engines came prefilled with oil from the engine factory.
    KMO likes this.
  11. Kenny94945
    Kenny94945 Active Member
    864
    439
    Sausalito
    2016 Prius v wagon
    Interesting thread.
    I have no insights to OEM original oil viscosity fill or the manual and "under hood" sticker viscosity statements.
    I've read 0-8 is better for cold weather and fuel economy.
    0-16 may be better for hot weather or prolonged highway speed or a heavy loaded/ cargo Prius.
    Which is preferred, I do not know :(
    Again, interesting thread.
    2023p likes this.
  12. KMO
    KMO Senior Member
    2,029
    751
    Finland
    2023 Prius Prime
    Good information - my mistake.
    So this goes back to the earlier assertion that all M20A engines are identical, with the suggestion that they hence will all be coming prefilled with 0W-8 regardless of what the Prius line thinks.
    But the Prius itself shows that engines aren't identical - HEVs and PHEVs get different engine variants, with the PHEV's variant having the balance shaft (and hence different fill capacity).
    So every engine coming out of the engine line is being targetted for a particular car - even down to subvariants of a model. There will be other minor details like auxiliary fitments and mounting points around the common core.
    So it's perfectly plausible that a particular production line can be asking for a particular oil pre-fill for their model along with the more fundamental stuff like balance shaft or not.
    Hassle for the engine line, but doable like the other variants they handle, and the sort of thing they would expect to have to handle - particular applications like PHEVs not being ready to go with the latest oil tech.
    2023p and Gokhan like this.
  13. Gokhan
    6,714
    2,672
    Paramount CA
    It is entirely possible to have minor engine variants from the factory, including different factory-fill oils, for different car models and even different regions of the world.
    That said, I don’t think Toyota gives too much thought to the oil viscosity, as I said before, in that they would be concerned with minor engine variations much.
    Thinner oil, of course, protects against wear less. That is well established. Its main advantage is improved fuel economy. However, for a car like the Prius, where the oil has a hard time warming up, I would certainly go with the thinnest oil recommended unless I am driving fast for long distances. If you are using the Prius regularly at 100 mph for long distances on a German autobahn, even 0W-16 is probably too thin, and perhaps go with 0W-20. If you use the car only for grocery runs, 0W-8 is definitely the best choice. That is because even 0W-8 is way too thick before the engine fully warms up.
    2023p likes this.
