6,000k color temperature light bulb
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by evebill8, Nov 22, 2012.
  1. evebill8
    evebill8 Member
    139
    16
    San Jose, CA
    Hi folk,
    I do not want to spend $1000+ to put the LED light. Do you know where I can get the 6000k head light bulb. The one on the amazon is 4000k which is not white enough.
    Thanks in advance!
  2. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    4300k really is the best for brightness. Amazon has 3 brands at least for 6000k. You need to search harder. I bought the mid priced Kensun. They were a pain to install. The bulb barely fit in the socket.
  3. Electric Charge
    Electric Charge Active Member
    545
    133
    Syracuse, NY
    XenonSupply seems to be a popular choice for HID kits, and they seem to be very high quality, several members here have them. I considered them myself, but 1) mine is a lease and 2) 6000K isn't as good as the OEM 4300K visibility wise, although they look nicer.
  4. evebill8
    evebill8 Member
    139
    16
    San Jose, CA
    Oh, I am sorry! I don't mean HID. I just want to swap a halogen light bulb with the color temp 6000k.
  5. JMT
    JMT Junior Member
    62
    SoCal
    Personally, I think that's a bad decision. Your lights will be worse than the stock halogen bulbs.
  6. evebill8
    evebill8 Member
    139
    16
    San Jose, CA
    K, I do not know that. Thanks!
  7. Tideland Prius
    16,675
    If you want the HID look, Silverstars are the way to go but the light won't be better (it just looks white).
    If you want a brighter bulb, Phillips X-Treme Power works but it's not as white.
    I've used both and prefer the Phillips.
  8. mmmodem
    2,732
    1,703
    Bay Area, CA
    The K color achieved with a standard halogen is by painting over the bulbs. You can imagine that light output will go down. You don't want that.
    10 years ago, I bought Silverstars and was very impressed with the light output and color. At the time, I thought I got such a good deal, HID look without the $250 pricetag. They blew out less than a year later. Let's say it's my terrible installation that caused such a short lifespan. I still don't recommend them though because they cost $40. There are HID kits on ebay cheaper than that. Even my admittedly low quality Kensun HID's are only some $15 more.
