6-50R to Prius prime 2017 adapter
Discussion in 'Prime Plug-in Charging' started by Tino, Jul 5, 2021.
Tags:
  1. Tino
    Tino Junior Member
    Lowell, MA
    I got an electrician installing a 40A breaker in my panel with the idea of getting a receptacle outside to charge my car at 220/240. I’m currently having problems finding an adapter for the 6-50 receptacle to the 5-15 in the universal Prius prime charger. Can anyone recommend an adapter for this situation? I bought a 10-30P to 5-15R by mistake should I consider changing the receptacle outside to a 10-30 if I can’t find an adapter. Appreciate any help!
    52,889
    i would just change it. shut off the breaker first
    Tino likes this.
  3. Tideland Prius
    16,683
  4. Tino
    Tino Junior Member
    Lowell, MA
    Thanks Bisco I will consider that the electrician has to come back to finish part of the job so I might as well ask him to change it.
  5. Tino
    Tino Junior Member
    Lowell, MA
  6. bisco
    52,889
    the less mechanical connections, the less heat and energy loss
  7. Tideland Prius
    16,683
    The charger is inside the car and it regulates the amperage. I don't know much about electricity (just basic university physics) but my understanding is that the car is the one controlling what comes in.
    E.g. I plug my Prime into a 6-50R with a 16A EVSE that has a 6-50P head
    Tino likes this.
  8. bisco
    52,889
    i think you only pull 12 amps at 240v?
  9. Tino
    Tino Junior Member
    Lowell, MA
    If you don’t mind sharing which EVSE did you get?
  10. Tideland Prius
    16,683
    16A Level 2 EVSE LCS-20 | ClipperCreek
    If you plan to go BEV in the future or as a second car, I'd recommend getting a faster charge than this one.
    This one outputs 3.3kW which is what the Prime accepts. Newer EVs accept anywhere from 7.2kW to 11kW (although 11kW require a hardwire connection. Plug-in EVSEs top out at 9.6kW which is fast enough tbh. One would have to have a unique situation [e.g. realtor or carshare] where they'd arrive home nearly empty and need a full charge in 8 hours the following day)
    Tino likes this.
  11. gene
    gene Member
    100
    NH
    I would recommend checking with your electric utility and state to see if they have any rebates on EVSEs.
    Where my parents live (NY state) they were able to get a $600 JuiceBox 30 or 40amp for the price of a cheap charger off of Amazon (< $200).
    While way more than what is needed for a Prime, it proves future proofing.
    Tino likes this.
