60,000 miles service: dealer quotes, reasonable?
Discussion in 'Gen 2 Prius Main Forum' started by ehuna, Sep 6, 2007.
  1. ehuna
    ehuna Junior Member
    Bay Area, CA
    Hello,
    A few weeks ago I asked some advice on the PriusChat.com about what to do after I ran out of service coupons. My 2005 Prius just reached 60,000 miles and the consensus seems to be that the following needs to be done:
    1) Oil change ($29.95)
    2) Rotate Tires ($29.95)
    3) Transmission Fluid change ($152.00)
    4) Inspect brakes and suspension.
    Above I have the prices my dealer is quoting me. Does this seem reasonable?
    If not, has anyone done a transmission fluid change in the Bay Area, and can you recommend someone? Peninsula or San Jose areas are prefered, but anything in the Bay Area is ok.
  2. J.Wilkie
    J.Wilkie 80 Mile Daily Commute
    157
    Behind The Orange Curtain
    I was told by a Toyota tech that most fluids, Tranny, Sparkplugs and Coolant do not need to be changed till 100K......
  3. jdenenberg
    jdenenberg EE Professor
    3,850
    1,843
    Trumbull, CT
    2020 Prius
    LE AWD-e
    <div class='quotetop'>QUOTE(ehuna @ Sep 6 2007, 04:05 PM) [snapback]508093[/snapback]</div>
    Not too bad
    A little high, but not bad as long as they rebalance your tires.
    About double what it should cost (I paid $85 at my CT dealer). If they are quoting a "Flush" go to a different dealer as a flush is for torque converters and you don't have one.
    Should be minimal
    You also need to change the engine and cabin air filters. This is easily done yourself in 5 minutes and the parts are about $40 at your dealer's parts dept.
    JeffD
    <div class='quotetop'>QUOTE(J.Wilkie @ Sep 6 2007, 04:14 PM) [snapback]508099[/snapback]</div>
    Mostly correct, but waiting till 100k for the tranny fluid puts you at risk for an expensive repair job a few miles later. A group of anal Prius owners (me included) have been doing lab analysis of used Prius ATF (type IV in the classic and type WS in the 2004+). Our results indicate that you should do regular ATF changes. The Classic seems to need it every 30,000 miles (some go for every 15,000 miles) and the current models (like my 2004) seems to need it done every 60,000 miles (I'm at 95,000 now).
    JeffD
  4. gawilson
    gawilson New Member
    I have a Prius 2005 that I've put a ton of highway miles on. I haven't changed the plugs nor the transmission fluid. According to the above posts, those should be done. Anything else that needs doing now and that I should watch getting screwed over on?
  5. gawilson
    gawilson New Member
    In a hurry, forgot to say that I have about 104,000 on it now.
  6. JimboK
    JimboK One owner, low mileage
    2,817
    187
    49
    Chesterfield, VA
    This should give you a good idea of what's needed.
  7. richard schumacher
    7,663
    1,038
    United States
  8. 4G63
    4G63 I quit boosting
    147
    Aurora, IL
    $30 for tire rotation is too much.. most places charges less than $15. if u get ur tires from discount tires, rotation is free
