6000k HID's
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Smirv, Jun 4, 2010.
  1. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    It wasnt directed at you. :) Some spam Chinese company posted here and 3 other threads with wanting to be friends and they make HID bulbs/ballasts. Wondered if I would get a response from them before they were banned.
    Did you get D2S, D2R, D4S, or D4R bulbs? If not, then you did NOT buy Phillips bulbs. Many companies brand their crap as Phillips. You get what you pay for. Phillips does not and has never made bulbs for illegal setups.
  2. putty
    putty Member
    147
    39
    somewhere in the swamps of Jersey
    your probably right I bought crap, but check out this link
    http://www.lighting.philips.com.au/v2/automotive/productrange.jsp?id=1012984
  3. silentak1
    silentak1 Since 2005
    893
    28
    LA
    Yes, you should try better quality ballasts first.
  4. richwiller
    richwiller Junior Member
    St. Louis MO
    2015 Prius v wagon
    I have one main comment that needs review, the 2010 Prius if equipted with halogen lamps is equipted with a H11 55watt bulbs. Using OHMS law where 55 divided by lets say 13 volts is 4.2 amps, a slimline ballast is 35 watts divided by 13 volts or 2.7 amps. I truely believe that a fuse will blow before the wire melts, but we have all see the results of the radiant heating the halogen can inflict on the head light lens and bulb plug. The current draw on the factory wire should not be nor is a problem unless somthing else is going on. There is no real reason from a current required standpoint to worry so much. My experience with the German built "slimline" ballast is that as stated it is well filtered and has not provided me with any interference. The physical temperature of the headlight assembly seems to be barely warm compaired to the heat the halogens produced. I couldn't be happer using the HID 6000K bulbs which now have about 12 hours time on them. Maybe they will change color temp, but even if they don't they appear to be only slightly bluer when parked next to an "05" with factory HID's. The projector used in the 2010 really controls the low beam light pattern better than the "05" system.
  5. Smirv
    Smirv AkA: Ryan
    212
    Illinois
    error post
  6. andino
    andino Senior Member
    746
    551
    San Jose, CA
    I was under the impression that 5000k is the optimal kelvin rating for the most lumen power where as 4300k was used to transition from halogen bulbs to Xenon. Either way though, you're not going to see much everyday improvement going with 4300k vs 5000k as the lumen difference isn't enough for everyday drivers to differentiate.
    Has anyone had a chance to take apart their headlights yet? I'm curious to see if there's enough room to retrofit an s2k lens in place of the halogen one. Or at least a TSX lens.
  7. HI MPG
    HI MPG Active Member
    789
    133
    93
    Orange County, CA
  8. richwiller
    St. Louis MO
    2015 Prius v wagon
    Absolutely no interference! I have tried every band and no interference. The ballast are fitted with a huge line choke or filter between the ballast and the car wiring harness. I really think with the 35 watt slimline electronic ballast the interference is handled. These as previously stated are German not Asian in build and seem to be of a very solid design. HID Kits - Xenon Kit - Car Lights Is the supplier I used but their are no doubt others of equal quality.
  9. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Yup, I was thinking of a different type of bulb. The stockers are 55W halogen, so 4amps ish.
    I am not sure how the prius is wired, but it is common for wires to be shared. So if it has 16awg wiring throughout the hood/bonnet it can handle about 20amps. Well startup is going to be a killer, but then alot of that other circuitry under there could be pulling from the same source. So you have to add it all up. It could get pretty close to the limit if not over. And when it happens, heat + thin wires = less votlage which goes to flickering HID lights, browning out computers, and so on. Also once the HID ballast can't light up, it tries again putting you in a perpetual startup cycle giving you the flickering sometimes seen. This is where the danger is. In a car like the Prius, I don't know why you would use a $5 relay to save thousands in potential repairs.
  10. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    No, 4300K is optimal. However, the human eye perceives slightly blue light to be more aggressive and "brighter". So it may look like it is brighter with 5000K, but it is a trick of the eye. True most people cant tell, and if you live in an urban area where there are streetlights everywhere, it really doesnt make a big difference. That 5000k temperature will standout and make your car attract more attention if that's what you want.
    You can't just put a lens in. That is one part of a big equation. It would be like slapping the Toyota logo on a F150 and expecting 50mpg. You need the whole projector, which is called retrofitting. Yes it can be done. No it isnt easy. Yes it gives the best results.
  11. andino
    746
    551
    San Jose, CA
    ^^ Well that's what I meant by swapping the lens. I did a retrofit on my last car with s2k projectors so I'll probably be doing the same thing with this one once I get the funds. Just curious to see if anyone had already done it or had measurements to see if it was an easy swap or not.
  12. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Well swapping the lens has a different meaning than retrofit. For instance I swapped the lens on my RX350 AFS projectors with TSX lenses.
  13. Tideland Prius
    16,678
    Why you would or wouldn't use?
    I assume you mean "why wouldn't you use a $5 relay to save thousands..."
  14. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Foiled by those damned double negatives again...
    Yes, I don't know why you *wouldn't* spend $5 to save thousands.
  15. Tideland Prius
    16,678
    Cool thanks. Makes me feel better about the relay that came with my kit.
    Quick question. NOLA Prius had his ground installed under this bolt that appears to hold the front fender. I don't know if I feel comfortable unscrewing that bolt. Can I simply find another nut and bolt from Home Depot and screw the ground wire to the body somewhere else? Ther'es plenty of small round holes around the engine bay that are on the frame of the car.
  16. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Anywhere that is metal to metal is fine. If there is paint or lubricant, you have to scratch it off completely or wipe it away completely. You want shiny steel.
  17. Tideland Prius
    16,678
    And no risk of shock if someone were to lean against the fender?
  18. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Only if they were touching a voltage source tied to your battery's ground which is no different than now. And even then it wouldnt do much.
    Your whole car is grounded through the chassis. Evey car is. That is why when you jump start a car you clamp to the body, not the battery terminal. Same connection, but the spark is farther away from any explosive gases emmited from the battery.
  19. Tideland Prius
    16,678
    so even if they were touching a metal pole and the car, they're fine, just as long as they don't touch the +ive terminal under the hood or another 12V battery while leaning against the car.
  20. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    They have to share a ground.
    Meaning it has to form a loop. So positive of spare 12v, through you, through the car chassis, to... Nowhere. So it's a no go. Same with the pole.
    Your car, my car, and everyone else's car all have the negative battery terminal connected to the chassis from the factory. It saves a bunch of wiring when the return feed is the car itself.
