65 mm 14 flute Oil filter housing 1.8l vs 3.5
Discussion in 'Gen 3 Prius Technical Discussion' started by 12n14V, Jul 11, 2017.
  1. 12n14V
    12n14V New Member
    SD CA
    RE oil filter housing...can 1.8 l housing be switched out with larger 3.5 housing to increase oil filter size. Or is this like monitoring engine with aftermarket gauges...rpm, oil pressure or temp, coolant and battery voltage ---just a waste of effort , time and money?
  2. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    You might be able to find an oil filter relocation kit that will fit this so you can use a larger filter:
    The 2016+ Toyota 2zr Engine oil filter conversion - Armstrong Family Blog
    As far as gauges, the Scangauge II from Linear Logic can monitor all of your listed parameters except oil pressure I believe.
    If you're going to mount an oil filter relocation kit, then mounting an oil pressure sensor might be done along with that.
