7 years
Discussion in 'Gen 2 Prius Main Forum' started by Moving Right Along, Dec 22, 2023.
  1. Mendel Leisk
    42,273
    When I search a pdf version of the 2009 Owner's Manual, I find two instances of the word "synthetic", both relate to seat material. Pictures are a pain right now, but I've copied and pasted:
    Synthetic leather areas
    ● Remove loose dirt using a vacuum cleaner.
    ● Apply a mild soap solution to the synthetic leather using a
    sponge or soft cloth.
    ● Allow the solution to soak in for a few minutes. Remove the
    dirt and wipe off the solution with a clean, damp cloth.
    Similarly with "conventional", there are several instances on multiple pages, none of them related to motor oil.
  2. Isaac Zachary
    Isaac Zachary Senior Member
    2,779
    1,501
    Never mind, you are right, sort of:
    In the 2013 Avalon Hybrid owner's manual it says:
    0W-20 only comes in synthetic or synthetic blend that I know of. The term "mineral oil" is where I got confused and thought it was saying conventional vs. synthetic.
    Note that in the same manual there are other reasons for changing the oil sooner, even if it's using 0W-20 motor oil.
  3. pasadena_commut
    pasadena_commut Senior Member
    3,019
    939
    Southern California
    Unfortunately PDF searches are not always reliable.
    A PDF file contains a series of glyphs, not a series of letters. While in English most glyphs are one to one with their letters, some glyphs in some fonts are composed of two letters (a ligature). The search field may or may not convert the search text into a series of glyphs with a similar ligature. If it doesn't then the word may be present in the text (as seen by a reader) but also not present in the text (by a search).
    Strange Occurrence With "ti" when printed to PDF - English - Ask LibreOffice
    "ti" is a common ligature. The presence of a ligature can vary from one font to another within the same document, or even vary within the same font if the letter spacing is forced to spread out the letters more than in usual text. Some PDF printers have an option to disable ligatures, which may or may not always work:
    How to avoid Chrome "Save as PDF" encoding "fi" etc. as ligatures? - Super User
    Searching for "oil" as a whole word only might be more reliable, as I don't think there are ever any ligatures in it.
  4. Isaac Zachary
    2,779
    1,501
    Are you saying that the story of what oil to use and how often to change it ends in a glyph-hanger?
